Solve (t^2-1)y'' +4ty'+2y=6t, given two particular solutions
In summary, the problem involves solving the differential equation \((t^2-1)y'' + 4ty' + 2y = 6t\) with the provision of two particular solutions. The solution approach may involve techniques such as finding the complementary function and using the method of undetermined coefficients or variation of parameters to find the general solution, incorporating the given particular solutions into the final expression.
CGandC
326
34
Solve the DE ##\left(t^2-1\right) \ddot{y}+4 t \dot{y}+2 y=6 t ## if its two particular solutions are ## y_1=t ## and ## y_2=\frac{t^2+t+1}{t+1} ##.
method of variation of parameters ( possibly utilizing here Wronskian of linear non-homogeneous differential equation of second order order ).
I find a solution in math.exchange site: https://math.stackexchange.com/ques...neral-solution-given-two-particular-solutions
The way I thought about solving the problem is to somehow use the two particular solutions to generate a homogeneous solution, I couldn't figure out how to do so; but, the solutions proposed in the link above leave me with an uneasiness of mind because:
1. The first answer- i.e. that the linear combination of the particular solutions is one fundamental homogenous solution ( in which case, I can use the wronskian to find the other fundamental homogenous solution and then we're finished ) is a little bit tricky because how was I supposed to know that the sum of particular solutions may generate a homogenous solution? is there any theorem backing this?
2. The second answer - i.e. using the substitution ## u = (t+1)x ## will enable me to find the homogenous solution regardless of the given information about two particular solutions ( but i'll need information about one particular solution to generate a general solution ), so how does the knowledge of two particular solutions help me here? ( I only need one )
Thanks for the help!
This is a result from the general theory of linear maps: If [itex]\alpha(x) = \alpha(y) = b[/itex] for linear [itex]\alpha[/itex] then [tex]\alpha (x - y) = \alpha(x) - \alpha(y) = b - b = 0.[/tex]
Likes CGandC
Ah, I see that now, in our case, the linear map is the differentiation operator over vector space of smooth functions over reals? ( because we wish to find such a smooth general solution )
FAQ: Solve (t^2-1)y'' +4ty'+2y=6t, given two particular solutions
What is the general approach to solving the differential equation (t^2-1)y'' + 4ty' + 2y = 6t?
The general approach involves finding the complementary (homogeneous) solution and a particular solution. First, solve the homogeneous equation (t^2-1)y'' + 4ty' + 2y = 0 using methods such as reduction of order or special functions. Then, find a particular solution to the non-homogeneous equation using methods like undetermined coefficients or variation of parameters. The general solution is the sum of the complementary and particular solutions.
How do you solve the homogeneous part of the differential equation?
To solve the homogeneous equation (t^2-1)y'' + 4ty' + 2y = 0, you can use techniques such as reduction of order if one solution is known, or look for solutions in the form of power series or special functions like Bessel functions, depending on the nature of the equation. If specific solutions are provided, they can be used to construct the general solution.
What methods can be used to find a particular solution for the non-homogeneous equation?
For the non-homogeneous equation (t^2-1)y'' + 4ty' + 2y = 6t, methods such as undetermined coefficients or variation of parameters are commonly used. In undetermined coefficients, you guess a form of the particular solution and determine the coefficients by substituting into the equation. In variation of parameters, you use the solutions of the homogeneous equation to construct a particular solution.
How do you combine the complementary and particular solutions?
The general solution of the differential equation is the sum of the complementary (homogeneous) solution and the particular solution. If y_c(t) is the complementary solution and y_p(t) is the particular solution, then the general solution is y(t) = y_c(t) + y_p(t).
What are some common pitfalls when solving this type of differential equation?
Common pitfalls include incorrectly solving the homogeneous equation, choosing an inappropriate form for the particular solution, and algebraic errors during the process. It's also important to correctly apply initial or boundary conditions if they are given, to determine the specific constants in the general solution.
