MHB Solve the a/b and 10/11 Problem: Understanding Quantity Relationships
  • Thread starter Thread starter CharlesLin
    Stuck
The discussion revolves around comparing the quantities a/b and 10/11 to determine their relationship. The initial approach involved converting the fractions to decimal form, but this did not yield a clear answer. After analyzing the inequalities, it was concluded that the relationship between a/b and 10/11 cannot be determined with the given information. The final consensus is that option D, indicating that the relationship cannot be determined, is the correct answer. Additionally, there were inquiries about using LaTeX for better representation of mathematical expressions.
CharlesLin
this is a nother problem from my study guide.
it starts with a statement
A) a/b
B) 10/11
based on this information you have to choose an answer:
a)quantity A is greater
b)quantity B is greater
c)the two are equal
d)the relationship can not be determined from the information given what I first try was was to change every number into a decimal number. for example 9/10= .9 and 11/12=.916. Then I know that a/b is between .9 and .910 but that did't helped because when I calculated 10/11=.90909 the decimal value is also between .9 and .916. then I'm not sure if the answer is d) the relationship can not be determinde...I suspect this is the answer but I'm not entirely shure.
how would you solve this problem?
I also try to picture the solution drawing the line where every fraction would be but I wasn't able to pictured well. Moreover, I had some problems trying to use LATEX there is any tutorial or guide to use it?
Mathematics news on Phys.org
If it would hold that $\frac{a}{b}> \frac{10}{11}$ then it would have to hold $\frac{10}{11}< \frac{11}{12} \Rightarrow 10 \cdot 12< 11 \cdot 11$, which is true.
If it would hold $\frac{a}{b}< \frac{10}{11}$ then it would have to hold that $\frac{9}{10}< \frac{10}{11} \Rightarrow 99<100$, which again is true.It also holds that $\frac{9}{10}< \frac{10}{11}< \frac{11}{12}$.
Thus I think that we cannot determine the relationship between $\frac{a}{b}$ and $\frac{10}{11}$ from the given information.
I see now
I feel more confident saying that D) is the answer.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
