Solve the given problem involving integration
chwala
see attached
integration
This really cracked me up! Unless there is something i am not seeing!
part (a) is straightforward, using quotient rule:
##\dfrac{dy}{dx} = \dfrac{x⋅\dfrac{1}{x}- \ln x}{x^2}=\dfrac{1-\ln x}{x^2}##
From here i was able to see that,
##\int \dfrac{\ln x}{x^2} dx= \int \dfrac{1}{x^2}- \dfrac{\ln x}{x}##
## = -\dfrac{1}{x} - \dfrac{ln x}{x}=-\left[\dfrac{1+\ln x}{x}\right]##
on the other hand, using integration by parts( without using part (a) and (b)), gives me
##\int \dfrac{\ln x}{x^3} dx =\dfrac{-\ln x}{2x^2} + \int \left[\dfrac{-1}{2x^2}⋅\dfrac{1}{x}\right] dx##
##= -\dfrac{\ln x}{2x^2}+ \int \dfrac{-1}{2x^3} dx##
##= -\dfrac{\ln x}{2x^2}-\dfrac{1}{4x^2} +c##
but this does not satisfy my curiosity, as i did not use part (a), was there a mistake on the textbook or am i simply missing out on something?
So we have as you said
Equation 1
##\frac{d}{dx}\left(\frac{ \ln x}{x} \right) = \frac{1- \ln x}{x^2} = \frac{1}{x^2} - \frac{\ln x}{x^2}##
Which implies
Equation 2
##\frac{\ln x}{x^2} = \frac{1}{x^2} - \frac{d}{dx}\left(\frac{ \ln x}{x} \right)## This becomes important later
Starting with the integral
##\int \frac{\ln x} {x^3} \, dx = \int \frac{1}{x} \left(\frac{\ln x} {x^2} \right)\, dx##
substitute Equation 2 into the above
##\int \frac{\ln x} {x^3} \, dx = \int \frac{1}{x} \left( \frac{1}{x^2} - \frac{d}{dx}\left(\frac{ \ln x}{x} \right)\right)\,dx##
##\int \frac{\ln x} {x^3} \, dx = \int \left(\frac{1}{x^3} - \frac{1}{x} \frac{d}{dx} \left( \frac{\ln x}{x}\right)\right)\, dx##
Well the first term on the right hand side of the equals sign is easy enough to integrate readily
##\int \frac{\ln x} {x^3} \, dx = - \frac{1}{2x^2} - \int \frac{1}{x} \frac{d}{dx} \left( \frac{\ln x}{x} \right)\,dx##
Now use integration by parts on the integral on the right hand side of the equals sign
## v = \frac{\ln x}{x} ##
## dv = \frac{d}{dx} \left(\frac{\ln x}{x} \right) dx##
##u = \frac{1}{x}##
##du = - \frac{1}{x^2} ##
Plugging this all in
## \int \frac{\ln x}{x^3} \,dx = -\frac{1}{2x^2} - \frac{\ln x}{x^2} - \int \frac{\ln x}{x^3} \,dx##
## 2 \int \frac{\ln x}{x^3} \,dx = -\frac{1}{2x^2} - \frac{\ln x}{x^2} ##
##\int \frac{\ln x}{x^3} \,dx = -\frac{1}{4x^2} - \frac{\ln x}{2x^2} + C##
I get the same thing as you
chwala said:
... but this does not satisfy my curiosity, as i did not use part (a), was there a mistake on the textbook or am i simply missing out on something?
Yes. Firstly, you made a sign error. Twice, so that your result remained correct. Secondly, as @PhDeezNutz demonstrated, you missed a trick by not using part (a) of the problem. You solved it by integration by parts
\int (u'v)=uv-\int (uv')
which is faster and more suitable in this case. However, using part (a) would have meant to use
\mathcal{I}:=\int \dfrac{\log(x)}{x^3}=-\int \left(\underbrace{\dfrac{1-\log(x)}{x^2}}_{u'}\cdot \underbrace{\dfrac{1}{x}}_{v}-\dfrac{1}{x^2}\right)
which results in an equation
\mathcal{I}=f(x) -\mathcal{I} \Longleftrightarrow \mathcal{I}=\dfrac{f(x)}{2}
The trick to using the additive symmetry: an integral that shows up on both sides of the equation with an opposite sign. You do not "solve" the integral, you express it with another function: ##f(x).## A similar trick exists for multiplicative symmetries.
Likes chwala and PhDeezNutz
From a)
\frac{d^2}{dx^2}\frac{\ln x }{x}=-\frac{3}{x^3}+\frac{2}{x^3}\ln x
\frac{\ln x}{x^3} = \frac{1}{2}\frac{d^2}{dx^2}\frac{\ln x }{x}+\frac{3}{2x^3}
\int dx\frac{\ln x}{x^3} = \frac{1}{2}\frac{d}{dx}\frac{\ln x }{x}+\int dx\frac{3}{2x^3}
So the same result with you @chwala .
Likes chwala, fresh_42 and PhDeezNutz
anuttarasammyak said:
From a)
I really liked how you used the second derivative. Even though that’s not what the problem asked for I can still definitely appreciate it.
Edit: nvm you only used the second derivative so you could integrate it and get the first derivative and use part a) which is clever. Either way pretty cool.
Likes chwala, SammyS and fresh_42
I think it is fair that i fix the sign error, i will proceed as follows,
$$\int \dfrac{\ln x}{x^3} dx =\dfrac{-\ln x}{2x^2} - \int \left[\dfrac{-1}{2x^2}⋅\dfrac{1}{x}\right] dx + c$$
$$ =\dfrac{-\ln x}{2x^2} + \int \left[\dfrac{1}{2x^3}\right] dx+c$$
$$=\dfrac{-\ln x}{2x^2} +\dfrac{1}{2} \int \left[\dfrac{1}{x^3}\right] dx+c$$
$$=\dfrac{-\ln x}{2x^2} +\dfrac{1}{2} ⋅ \left(\dfrac{-1}{2x^2}\right)+c$$
$$= -\dfrac{\ln x}{2x^2}-\dfrac{1}{4x^2} +c$$
Likes PhDeezNutz and fresh_42
