Solve the given problem involving parametric equations
chwala
##P,Q,R## and ##S## are four points on the hyperbola ##x=ct, y=\dfrac{c}{t}## with parameters ##p,q,r## and ##s## respectively. Prove that, if the chord ##PQ## is perpendicular to the chord ##RS##, then ##pqrs=-1##.
My take;
##y=\dfrac{c^2}{x}##
##y+x\dfrac{dy}{dx}=0##
##\dfrac{dy}{dx}=\dfrac{-y}{x}##
##y-\dfrac{c}{t}=-\dfrac{y}{x}(x-ct)##
##yt-c=-\dfrac{yt}{x}(x-ct)##
##xyt-cx=-yt(x-ct)##
##c^2t-cx=-cx+yct^2##
##c^2t-cx=-cx+ytct##
##c^2t-cx=-cx+c^2t##
##⇒-cx=-cx##
##⇒cx=cx##
Therefore it follows that,
##\dfrac{c}{c}=\dfrac{x}{x}##
##x=c##
##y## will be given by,
##y=\dfrac{c^2}{c}=c##
point P will have co-ordinates ##(x,y)=(c,c)## and point Q will have co-ordinates ##(x,y)=(-c,-c)## where gradient is given by;
##m=\dfrac{c--c}{c--c}=\dfrac{2c}{2c}=1##
It follows that the perpendicular to the chord RS will have gradient =-1.
I do not have the solution to this question...your input is highly appreciated...
Non-calculus solution:
The 4 points are: ##P(cp, \frac cp), Q(cq, \frac cq), R(cr, \frac cr)## and ##S(cs, \frac cs)##.
Start by finding the gradient of ##PQ##: ##m_{PQ} = \frac { \Delta y}{\Delta x}## where, for example, ## \Delta x= cq - cp = c(q-p)##.
Take it from there !
Ok i am getting the following;
Gradient of chord ##PQ=\left[\dfrac{-1}{qp}\right]## now if ##PQ## is perpendicular to chord ##RS## then the product of their gradients =##-1##, therefore,Gradient of chord ##RS=\left[\dfrac{-1}{sr}\right]=-1, ⇒sr=1##
...therefore ##pqrs=-1##.
Correct final conclusion but the method is wrong.
##RS=\left[\dfrac{-1}{sr}\right]=-1, ⇒sr=1## doesn't work. For example the gradient of SR could be 3 and the gradient of PQ could be ##-\frac 13##.
Remember, you are being asked to prove "that, if the chord PQ is perpendicular to the chord RS, then pqrs= -1".
I do not seem to get it...
Ok, let ##m_1## and ##m_2## be the gradients of ##PQ## and ##RS## respectively;
##m_1=\left[\dfrac{-1}{qp}\right]##
##m_2=\left[\dfrac{-1}{sr}\right]##
we know that ##m_1×m_2=-1## therefore,
##\dfrac{-1}{qp}×\dfrac{-1}{sr}=-1##
##\dfrac{1}{qp}×\dfrac{1}{sr}=-1##
##\dfrac{1}{pqsr}=-1##
on cross-multiplying we end up with;
##pqsr=-1##.
Likes Steve4Physics
The vector from P to Q is ##(q-p)c\hat{i}+\left(\frac{1}{q}-\frac{1}{p}\right)c\hat{j}##. The vector from R to S is ##(s-r)c\hat{i}+\left(\frac{1}{s}-\frac{1}{r}\right)c\hat{j}##. For these chords to be perpendicular, the dot product of these two vectors must be zero.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
