Solve the given trigonometry problem
In summary, the conversation discusses a problem involving the equation x^2 = (1+sinθ)^2/(cos^2θ) = (1+sinθ)^2/(1-sin^2θ) = (1+sinθ)/(1-sinθ). It is suggested that another approach to solving this problem could be to use the equation x(1/x) = 1 and compare it to the trigonometric identity sec^2θ - tan^2θ = 1. Another variation is proposed, using the equation x = secθ + tanθ and showing that x(secθ - tanθ) = sec^2θ - tan^2θ = 1. Finally, it is suggested that the
chwala
387
If ##x=\sec θ + \tan θ##, then show that ##\dfrac {1}{x}=\sec θ - \tan θ##
Trigonometry
My take;
##x^2=\dfrac{(1+\sin θ)^2}{cos^2θ}=\dfrac{(1+\sin θ)^2}{1-\sin ^2θ}=\dfrac{1+\sin θ}{1-\sin θ}##
we know that, ##x=\dfrac{1+\sin θ}{\cos θ}##
##⇒1+\sin θ=x\cos θ##
therefore,
##x^2=\dfrac{x\cos θ}{1-\sin θ}##
##\dfrac{x}{x^2}=\dfrac{1-\sin θ}{\cos θ}##
##\dfrac{1}{x}=\dfrac{1}{\cos θ}-\dfrac{\sin θ}{\cos θ}=\sec θ-\tan θ##
there may be another approach to this problem. Your input highly appreciated...
How about ##x{1\over x} = 1## and comparing that with ##\sec^2 \theta -\tan^2 \theta = 1 ## ?
Likes neilparker62 and Ibix
That is fine, comparing may mean eliminating ##x## from the equation and end up showing that the lhs=rhs in reference to the trig. identities; but that is not what we want. We need ##x## to be part of the problem.
But it is ! If you need it spelled out:$$(\sec + \tan)(\sec-\tan) = x(\sec-tan)=1 \ \& \ x{1\over x}=1 \Rightarrow (\sec-\tan)={1\over x}\\ $$
Likes MatinSAR and chwala
Ok @BvU ....I will check. Thanks mate.
Or ...
A variation, inspired by @BvU :
##\displaystyle x= \sec\theta + \tan\theta##
##\displaystyle x(\sec\theta - \tan\theta)= (\sec\theta + \tan\theta)(\sec\theta - \tan\theta) ##
##\displaystyle \quad \quad \quad \quad \quad \quad \quad =\sec^2\theta - \tan^2\theta ##
##\displaystyle \quad \quad \quad \quad \quad \quad \quad = 1##
Thus: ##\displaystyle \quad \sec\theta - \tan\theta = \dfrac 1 x ##
Likes chwala
Thanks answer :cool:
use for my ticher
Likes chwala
or $$ (\sec \theta + \tan \theta)(\sec \theta - \tan \theta) = \sec^2 \theta - \tan^2 \theta = 1 \implies \sec \theta - \tan \theta = \frac{1}{\sec \theta + \tan \theta} $$
Likes chwala and SammyS
FAQ: Solve the given trigonometry problem
What are the basic trigonometric identities I should know to solve problems?
The basic trigonometric identities are the Pythagorean identities: sin²θ + cos²θ = 1, 1 + tan²θ = sec²θ, and 1 + cot²θ = csc²θ. Other important identities include the angle sum and difference identities, double-angle identities, and half-angle identities.
How do I solve a trigonometric equation?
To solve a trigonometric equation, first isolate the trigonometric function. Then, use inverse trigonometric functions to find the principal value. Finally, consider the periodic nature of trigonometric functions to find all possible solutions within the given interval.
What strategies can I use to simplify trigonometric expressions?
To simplify trigonometric expressions, you can use trigonometric identities to rewrite the expression in a simpler form. Common strategies include factoring, combining like terms, and converting between different trigonometric functions using identities.
How do I find the exact value of a trigonometric function at a specific angle?
To find the exact value of a trigonometric function at a specific angle, you can use known values from the unit circle. For common angles like 0°, 30°, 45°, 60°, and 90°, you should memorize their sine, cosine, and tangent values. For other angles, you may need to use trigonometric identities or special triangles.
What is the best way to approach solving a trigonometric word problem?
When solving a trigonometric word problem, start by drawing a diagram to visualize the problem. Identify the given information and what you need to find. Choose the appropriate trigonometric functions and set up equations based on the relationships in the diagram. Solve the equations step-by-step, and check your solution for accuracy.
