Solve the inequality and graph the solution a real number line
In summary: Indeed, and that is exactly what we did. By expanding and factoring, we were able to clearly see the common factors and simplify the expression. This allows us to arrive at the solution more easily.
megacat8921
5/(x-1) - (2x)/(x+1) - 1 < 0
How does one solve this inequality?
Mathematics news on Phys.org
you can multiply by $(x-1)^2(x+1)^2$ (kindly note squared to have it positive and get
$5(x-1)(x+1)^2 - 2x(x-1)^2(x+1) - (x-1)^2(x+1)^2 \lt 0$
expand and factor LHS to get the result
Getting a common denominator and simplifying gives \(\displaystyle \dfrac{-3x^2+7x+6}{(x-1)(x+1)}<0\).
Now construct sign diagrams for \(\displaystyle -3x^2+7x+6\) and \(\displaystyle x^2-1\).
You should arrive at \(\displaystyle x<-1,-\dfrac23<x<1\) and \(\displaystyle x>3\).
Why expand and factor? You can already pick out common factors...
$\displaystyle \begin{align*} 5 \left( x - 1 \right) \left( x + 1 \right) ^2 - 2x \left( x - 1 \right) ^2 \left( x + 1 \right) - \left( x - 1 \right) ^2 \left( x + 1 \right) ^2 &= \left( x - 1 \right) \left( x + 1 \right) \left[ 5 \left( x + 1 \right) - 2x \left( x - 1 \right) - \left( x - 1 \right) \left( x + 1 \right) \right] \\ &= \left( x- 1 \right) \left( x + 1 \right) \left( 5x + 5 - 2x^2 + 2x - x^2 + 1 \right) \\ &= \left( x - 1 \right) \left( x + 1 \right) \left( - 3x^2 + 7x + 6 \right) \\ &= \left( x - 1 \right) \left( x + 1 \right) \left( -3x^2 + 9x - 2x + 6 \right) \\ &= \left( x - 1 \right) \left( x + 1 \right) \left[ -3x \left( x - 3 \right) - 2 \left( x - 3 \right) \right] \\ &= - \left( x - 1 \right) \left( x + 1 \right) \left( x - 3 \right) \left( 3x + 2 \right) \end{align*}$
FAQ: Solve the inequality and graph the solution a real number line
What is an inequality?
An inequality is a mathematical statement that compares two quantities using symbols such as <, >, ≤, or ≥. It shows the relationship between the quantities and indicates which one is larger or smaller.
How do you solve an inequality?
To solve an inequality, you must isolate the variable on one side of the inequality symbol and leave the constant on the other side. You can do this by using inverse operations, just like solving an equation.
What does it mean to graph the solution of an inequality on a real number line?
Graphing the solution of an inequality on a real number line means representing all the possible values of the variable that make the inequality true. The number line is used to show the relationship between the values and their placement on the line.
How do you determine if a point is a solution to an inequality?
To determine if a point is a solution to an inequality, you can plug in the values of the point into the inequality and see if it makes the statement true. If it does, then the point is a solution; if not, then it is not a solution.
Can an inequality have more than one solution?
Yes, an inequality can have more than one solution. This means that there is more than one value of the variable that makes the inequality true. When graphing the solution on a number line, these values will be represented by a shaded region or a range of values.
