Solve the initial value problem
In summary, to solve the initial value problem for $y$ as a function of $x$, we can first separate variables and then use integration to find an equation for $y$ in terms of $x$. By using the initial condition $y(0)=12$, we can determine the constant of integration.
karush
MHB
3,269
\begin{align*}\displaystyle
\sqrt{16-x^2} \, \frac{dy}{dx}&=1, \, x<4, y(0)=12
\end{align*}
assume the first thing to do is $\int$ both sides
I would separate variables, switch dummy variables, and use the boundaries:
\(\displaystyle \int_{y_0}^{y(x)}\,du=\int_0^x \left(16-v^2\right)^{-\frac{1}{2}}\,dv\)
\end{align*}
I don't see why you would need dummy variables...
$\displaystyle \begin{align*} \frac{\mathrm{d}y}{\mathrm{d}x} &= \frac{1}{\sqrt{16 - x^2}} \\ y &= \int{ \frac{1}{\sqrt{16 - x^2}}\,\mathrm{d}x } \end{align*}$
Once you integrate you will have a constant of integration, use your initial condition to determine it.
You don't need them but it helps to distinguish the integrand from the final integral.
the MML sample didn't use dummy vars
but showing 20+ steps I got lost. so want see how this goes
so next
$\displaystyle
\left[u\right]_{12}^{y(x)}
=\left[\arcsin\left(\frac{u}{4}\right)\right]_0^x$
kinda ??
FAQ: Solve the initial value problem
What is an initial value problem?
An initial value problem is a type of mathematical problem that involves finding a function or set of functions that satisfy a given set of conditions. These conditions usually include an equation or system of equations and one or more initial values that must be satisfied by the solution.
What is the process for solving an initial value problem?
The process for solving an initial value problem typically involves using a combination of algebraic manipulation, calculus, and other mathematical techniques. The goal is to find a solution that satisfies both the given equation(s) and the initial values.
What are some common techniques used to solve initial value problems?
Some common techniques used to solve initial value problems include separation of variables, substitution, and using integrating factors. Other techniques that may be used depending on the specific problem include Laplace transforms, power series, and numerical methods.
What are the applications of solving initial value problems?
Solving initial value problems has a wide range of applications in various fields of science and engineering. It can be used to model physical systems, predict the behavior of biological processes, and analyze economic or financial data. It is also an essential tool in solving differential equations, which are used to describe many natural phenomena.
What are some tips for successfully solving initial value problems?
Some tips for successfully solving initial value problems include thoroughly understanding the given conditions, being familiar with the techniques and methods for solving such problems, and practicing regularly. It is also important to carefully check the solution and make sure it satisfies all of the given conditions.
