Solve the initial value problem?
In summary, the method of successive approximations is used to solve the initial value problem y'=2t(1+y), y(0)=0. This involves finding a sequence of functions that converges to the solution, and can be done by first guessing a solution that satisfies the initial conditions, then iterating to find the next function in the sequence. While there may be simpler methods to solve this problem, the method of successive approximations was specifically requested.
Success
75
Solve the initial value problem y'=2t(1+y), y(0)=0 by the method of successive approximations.
I don't know how to do this problem but I think there's integral involved in it. Please help me. Thanks.
Does it have to be done by the method of successive approximations? I mean, it looks fairly simple to just say
$$\frac{dy}{dt}=2t+2ty \\ \frac{dy}{dt}-2ty=2t \implies \frac{d\mu}{dt}=-2t\mu \implies \mu=c_1e^{-t^2} \\ \frac{d}{dt}\left[c_1e^{-t^2}y\right]=2c_1te^{-t^2} \\ y = 2e^{t^2}\int te^{-t^2}dt \\ y = 2c_2e^{t^2}-1 \\ 0 = 2c_2-1 \implies c_2=\frac{1}{2} \\ y(t)=e^{t^2}-1.$$
Isn't the equation separable if you wanted to solve it analytically?
[tex] \frac{dy}{dt}=2t(1+y) \\
\frac{dy}{1+y}=2t dt \\
\ln|1+y|=t^2+C \\
y+1=\pm e^C e^{t^2} [/tex] and using the initial condition gives [tex] y=e^{t^2}-1 [/tex]
\ln|1+y|=t^2+C \\
...But it's more fun to do it the long way! :-p
I need to start seeing when there's an easier way to solve differential equations.
As a side note, ##\frac{d}{dx}\ln{x}=\frac{1}{x}\implies\int\frac{dx}{x}=\ln{x}+C##. No need for absolute values unless you are adamant about ignoring complex numbers.
Alright. Let's do it the OP's way. Suppose we have a solution ##y##. Then, for ##\frac{dy}{dt}=f(t,y(t))=2t(1+y)##, we have that ##\displaystyle y=\int\limits_{[t_0,t]}f(x,y(x)) \, dx##. We thus approach by the method of approximations. Define ##\displaystyle y_1=\int\limits_{[t_0,t]}f(x,0) \, dx = \int\limits_{[t_0,t]}2x\, dx = t^2-t_0^2## and ##\displaystyle y_n=\int\limits_{[t_0,t]}f(x,y_{n-1}) \, dx##.
Is everything clear so far? How might you continue this approach, Success?
Seeing as it's been almost a day, I will suggest that we set ##t_0=0## and point out that ##\displaystyle y_n = \sum_{k=1}^{n}\left[\frac{t^{2k}}{k!}\right]##.
Mandel, what's y1 and yn then in this problem?
Sucess, you have received several hints right now. I would like to hear some kind of effort from you first before we continue.
y=2 integral of t(1+y)dt from 0 to t. Now I need y1 and y2, I'll try. Give me some minutes.
y=2 integral of (t+ty)dt from 0 to t. How to integrate this?
You don't. y is an unknown function of t. You cannot integrate an unknown function!
People have been trying to tell you to separate the y and t terms:
If dy/dt= t(1+ y) then dy/(1+ y)= t dt.
[tex]\int \frac{dy}{1+ y}= \int t dt[/tex].
Start with the simplest method first. In this case, it's easy to see by inspection that the equation is separable. The two factors on the right side were already separate functions of y and t, so multiplying out the two factors made it less obvious that separation could be used.
All of the hints so far are completely off course because they don't address the central issue of using the method of successive approximations. This approach finds a sequence of functions that hopefully converge to the solution. It is very reminiscent of fixed point iteration.
Start with some guess, call it y0(t), that satisfies the initial conditions. There's an obvious one here: y0(t)=0. Next iterate by solving dyn+1(t)/dt = 2t(1+yn), yn+1(0)=0. The first step is easy: Just solve dy1(t)/dt=2t(1+0)=2t, y1(0)=0. Then keep iterating. You should see a power series arising.
Thank you guys. The one HS-Scientist did was very understandable.
I suspect you won't get very much credit if you submit his solution. While it is the solution to the initial value problem, it does not use the method of successive approximations.
But why do we must use a hard method when we can do it using the easier one?
Because sometimes there is no clear-cut analytic solution.
Which is something that was nagging me in the back of my mind.
Aside from what D H mentioned, because that is the method requested in the problem statement (emphasis added).
As an example of how to use the method of successive approximations, consider the ODE y'=y, y(0)=1. Note that this is not the problem posed in the OP. Success, it's up to you to adapt this to the problem at hand.
What this method does is to build a sequence of functions y0(t), y1(t), y2(t), etc., each step being a bit closer to the solution than the previous. The relation between successive approximations is yn'(t) = yn-1(t) such that yn(0)=1. The starting point is a constant function that satisfies the initial condition. In this example, y(0)=1, so y0(t) = 1. This gives the conditions for the next approximation: y1'(t)=1, y1(0)=1. The solution to this IVP is y1(t)=1+t. The next iteration yields y2(t)=1+t+t2/2, the next y3(t)=1+t+t2/2+t3/6.
Notice how each step builds toward toward the infinite series [itex]y(t)=\sum_{n=0}^{\infty} \frac{t^n}{n!}[/itex]
FAQ: Solve the initial value problem?
What is an initial value problem?
An initial value problem is a type of differential equation that involves finding a function that satisfies a given set of conditions, usually in the form of an initial value, at a specific point. The solution to an initial value problem is a function that satisfies both the differential equation and the initial value.
How do you solve an initial value problem?
To solve an initial value problem, you can use a variety of techniques such as separation of variables, integrating factors, or using a specific method for a particular type of differential equation. The goal is to find a function that satisfies both the differential equation and the initial value.
What is the importance of solving initial value problems?
Solving initial value problems is essential in many fields of science and engineering. It allows us to model and predict the behavior of various systems, such as population growth, radioactive decay, and electrical circuits. It also helps us understand the underlying principles and relationships between variables in these systems.
What are the common mistakes when solving initial value problems?
Some common mistakes when solving initial value problems include errors in the initial conditions, mistakes in the algebraic manipulations, and not checking the solution for accuracy. It's essential to double-check all calculations and make sure the solution satisfies both the differential equation and the initial value.
Can you provide an example of solving an initial value problem?
Sure, one example of solving an initial value problem is finding the function that satisfies the differential equation dy/dx = x + y with the initial condition y(0) = 1. Using the method of separation of variables, we can solve this problem and find the solution y = 2e^x - x - 1. This solution satisfies both the differential equation and the initial condition.
