Solve the initial value problem
In summary, you solved the homework equations for y1 and y2 by finding C1 and C2, which were both 28 and -26.
ver_mathstats
260
y1'=-13y1+4y2
y2'=-24y1+7y2
y1(0)=5, y2(0)=2
Here is what I have:
y'=[-13 4, -24 7]y
I change it to A=[-13 4, -24 7]
My eigenvalues are λ=-1 and λ=-5.
My basis are [1/3 1] and [1/2 1].
Now I have to find u'=Du, which is:
[u1', u2'] = [-1 0, 0 -5][u1, u2]
Which then yields:
u1'=-1u1
u2'=-5u2
With these solutions:
u1=C1ex
u2=C2e2x
Now I obtain y=Pu, which is:
y=[1/3 1/2, 1 1][C1ex, C2e2x]
y=[(C1ex/3) + (C2e2x/2), C1ex + C2e2x]
Now I have:
y1=(C1ex/3) + (C2e2x/2)
y2=C1ex + C2e2x
Apply initial conditions to obtain:
y1=(C1/3) + (C2/2)=5
y2= C1 + C2=2
I solved and obtained:
C1=28
C2=-26
y1=(28ex/3) - (26e2x/2)
y2=28ex - 26e2x
Would this be right or did I make a mistake?
Thank you.
y1'=-13y1+4y2
y2'=-24y1+7y2
y1(0)=5, y2(0)=2
y'=[-13 4, -24 7]y
Which then yields:
u1'=-1u1
u2'=-5u2
u1=C1ex
u2=C2e2x
Now I have:
y2=C1ex + C2e2x
y2= C1 + C2=2
C1=28
C2=-26
y2=28ex - 26e2x
Thank you.
You can check it for yourself: just plug your solution into the DE system to see if it works. Checking your solution that way is something you should get in the habit of doing always, every single time.
Related to Solve the initial value problem
What is an initial value problem?
An initial value problem is a type of mathematical problem that involves finding a function that satisfies a given differential equation, along with a set of initial conditions. The initial conditions typically specify the value of the function and its derivatives at a specific point.
What is the process for solving an initial value problem?
The process for solving an initial value problem involves first identifying the differential equation and the initial conditions. Then, using techniques such as separation of variables, substitution, or variation of parameters, the differential equation is solved to find the general solution. Finally, the initial conditions are used to determine the specific solution that satisfies both the differential equation and the initial conditions.
What are some common techniques for solving initial value problems?
Some common techniques for solving initial value problems include separation of variables, substitution, variation of parameters, and the method of undetermined coefficients. Each of these techniques has its own advantages and is used depending on the form of the differential equation.
Why are initial value problems important in science?
Initial value problems are important in science because many natural phenomena can be described using differential equations. By solving initial value problems, scientists can predict the behavior of these phenomena and make informed decisions based on the results.
What are some real-world applications of solving initial value problems?
Solving initial value problems has many real-world applications, such as predicting population growth, modeling the spread of diseases, analyzing chemical reactions, and understanding the behavior of electrical circuits. It is also used in fields such as physics, engineering, and economics to study various systems and their behaviors.
