I Solve the system of linear equations
chwala
TL;DR Summary
Looking at this now- refreshing on rref kindly see attached.
This is fine but i have my own approach as follows;
##\begin{pmatrix}
-7 & -6 & -12 & -33 \\
5 & 5 & 7& 24 \\
1 & 0 & 4 & 5
\end{pmatrix} ## → Row 1 times 5 and row 2 times 7...
##\begin{pmatrix}
-35 & -30 & -60 & -165 \\
35 & 35 & 49& 168 \\
1 & 0 & 4 & 5
\end{pmatrix}## →
##\begin{pmatrix}
0 & 5 & -11& 3 \\
1 & 0 & 4 & 5
\end{pmatrix}## → Row 1 minus row 2...
##\begin{pmatrix}
1 & 0 & 4& 5 \\
0 & 5 & -11 & 3
\end{pmatrix} ## → R3 and R2 switch...
##\begin{pmatrix}
0 & -30 & 80 & 10 \\
0 & 5 & -11 & 3
\end{pmatrix} ## → R3 times 6 then subtract from R2
##\begin{pmatrix}
0 & 0 & 14 & 28
\end{pmatrix} ##
##14x_3=28, x_3=2##
##-30x_2+160=10##
##x_2=5##
##-35x_1-30x_2-60x_3=-165##
##-35x_1-150-120=-165##
##-35x_1=105##
##x_1=-3##.
I fully understand the author's approach of having the leading elements for every row being ##1## conforming with the Row reduced echelon form...
just sharing...cheers
As long as you know what is going on with the arithmetic, anything that works and that you can easily tackle "tags all the bases".
When attacking such problems in the workplace, there's little point to doing it manually - use a software tool.
As an additional exercise, you might want to code this up as a function - or set it up in a spread sheet (ex, Excel) where the matrix values can be changed and the output recomputed and displayed automatically.
True, i know software can help in most of math problems... e.g multiplying matrices, finding determinants of matrices, diagonalize matrices etc...and many other math areas... but i prefer in most cases to use my human capabilities; it does wonders to my cognition/processing speed in dealing practically with life challenges... That's why i like doing Math.
Cheers mate.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
