Solve this integral involving a quadratic and linear air resistance equation
The discussion revolves around solving an integral related to a quadratic and linear air resistance equation, specifically the equation -bv - cv² = m(dv/dt). The user struggles to isolate velocity (V) after performing the integration, leading to discrepancies between their result and the expected correct answer. Key points of confusion include the proper application of partial fractions and the handling of logarithmic terms during integration. Ultimately, the correct form of the solution is clarified, revealing that the user's approach was close but contained errors in the exponential arguments and dimensional consistency. The conversation highlights the importance of careful integration techniques and dimensional analysis in solving differential equations.
happyparticle
f = ma
f = -bv -cv²
Hi,
I'm trying to solve this integral and then isolate V, but I can't get the right answer. I don't know where is my errors. I probably muffed the integral.
##-bv -cv² = m\frac {dv}{dt}##
\int_0^t dt = - m \int_{Vo}^v \frac {dv}{bv+cv^2}
I get this after the integration
##t = -m[ln\frac{V}{Vo} - \frac cb ln(\frac {b+cV}{b+cVo})]##
Finally, I get
v = \frac{e^{\frac{-bt}{cm}} VoB}{b +cVo- e^{\frac{-bt}{cm}}VoC}
But the right answer is
v = \frac{b +cVo}{b +cVo- e^{\frac{-bt}{m}}VoC} -1
Likes Delta2
Could these be equivalent?
Likes Delta2
To be honest I was thinking about it, but I don't know how to verify.
Note that
##\large \frac{A}{B}-1 = \frac{A-B}{B}##
In this case B = ##
I don't think it's equivalent.
Sorry, I now see they are not quite the same. I agree with your answer.
Your answer is equivalent to
##\large \frac{b+cV_0}{b+cV_0 - e^{\frac{-bt}{m}}bV_0}-1##
which has a factor of ##b## rather than ##c## in the last terms of the denominator.
[Edit: Your answer is not quite equivalent to this. See other corrections below]
Rats, I just caught something else. Your argument of the exponential should not have ##c## in it.
I think you're missing a factor of ##\frac{1}{b} ## in front of the log in the first term on the right and the second term on the right should not have the factor of ##c## in front of the log.
You can check that the dimensions of the terms in your equation are not consistent.
I'm now getting "their answer".
I don't know where I made a mistake.
##\int_0^t dt = -m \int_{Vo}^V \frac{dv}{bv+cv²}##
##t = -m \int_{Vo}^V \frac{dv}{v(b+cv)}##
Then I did a integration with partial fractions. A = ##\frac1b## B = ##\frac {-c}b##
##t = \frac{-m}b \int_{Vo}^V \frac 1v -\frac cb \int_{Vo}^V \frac{1}{b+cv}##
OK, that looks good. Of course there should be ##dv## in the integrals and the second integral will also have a factor of ##m##.
Be careful with the second integral. Integration will bring in a factor of ##\large \frac1c## which will cancel the ##c## in the fraction ##\large \frac cb##.
Likes happyparticle
I don't get ##\frac 1c##
##t = \frac{-m}b[ln\frac {V}{Vo} - \frac cb ln (\frac{b+cV}{ b+cVo})]##
The only way I see to get ##\frac 1c##
##- \frac cb \frac 1c \int_{Vo}^V \frac {1}{\frac bc + V}##
However, I don't know why I have to do it.
##\large \int \frac{dv}{b+cv}##
If you let ##u = b+cv##, how is ##du## related to ##dv##?
I'm not sure to understand.
##\int \frac{1}{b+cv} dv##
## ln |b +cv|##
That's what I did.
## ln |b +cv|##
That's what I did.
If you differentiate ## ln |b +cv|##, using the chain rule , do you get ## \frac{1}{b+cv} ##?
Likes happyparticle
I found ##\frac {cv}{b+cv}##
You are right.
How can I know I have to do multiply by ##\frac 1c##
You are right.
One way is to check that the original is the derivative of the integral.
Another is a change of variable: ##\int\frac v{b+cv}dv=\int\frac 1c\frac v{b+cv}d(cv)##.
Likes happyparticle
Alright, thanks guys for the help
Likes TSny
Me again, sorry.
I found what you guys said, but I'm still stuck.
##- \frac {tb}{m} = ln \frac {V}{Vo} - \frac {1}{b} ln \frac {\frac bc + V}{\frac bc + Vo}##
I can't do that
##\frac 1b ln(\frac {...}{...})##
The first term on the right should have a factor of ##\frac 1b## just like the last term. The left side should not have the factor of ##b## yet. So you can factor out an overall factor of ##\frac 1b## on the right side and then combine the two log terms. The ##b## in the ##\frac 1b## factor can then be taken to the left side to give the ##b## in ##\frac {tb}{m}##.
I know, but I can't find where I miss it.
You said you got the right answer. Is your A = 1/b and B = -c/b in your integration with partial fractions ?
Yes, your A and B look good. Both A and B have a ##b## in the denominator. This ##b## ends up on the left side to give you the ##b## in ##\frac {tb}{m}##
I already have the ##b## in ##- \frac {tb}{m} ## from ##\frac mb##
Furthermore, I really don't see where I miss the
##\frac 1b##
Earlier you had
Everything here looks good except the last line. There is a missing factor of ##m## in front of the last integral and there should be ##dv##'s in the integrals. The negative sign in ##B = -\frac cb## means that the last integral ends up with a positive sign. Thus, see if you agree that you should get
##t = -\frac mb \int_{Vo}^V \frac {dv}v + \frac{mc}b \int_{Vo}^V \frac{dv}{b+cv}##
EpselonZero said:
Finally, I get
After reviewing everything, I get an answer very close to your answer. The only difference is that your exponential factors have an argument of ##\frac{-bt}{cm}## while it should be ##\frac{-bt}{m}##. You can check that ##\frac{-bt}{m}## is dimensionless.
Also, the "right answer" that you quoted seems to be missing an overall factor of ##\frac bc##. As given, the answer cannot be correct since the left side has dimensions of velocity while the right side is dimensionless. It should be written as $$v = \frac bc \left(\frac{b +cVo}{b +cVo- e^{\frac{-bt}{m}}VoC} -1\right)$$.
Then, this would be equivalent to your way of writing the answer once your argument of the exponential term is corrected. Your way of writing the answer looks nicer.
I must apologize for not seeing this earlier.
Alright, no problem. You helped me a lot.
I found this answer.
## V = \frac {e^{-\frac{tb}{m}}Vo\frac bc}{-e^{-\frac{tb}{m}}Vo+\frac bc + Vo}##
That looks correct.
Likes CPW and happyparticle
Phew! Thanks a lot for your patience.
The form of the solution that appeals to me is:
$$v=\frac{V_0e^{-\frac{bt}{m}}}{1+\frac{cV_0}{b}(1-e^{-\frac{bt}{m}})}$$where the numerator is the solution when c = 0, and the 2nd term in the denominator captures the added drag effect of c not being zero.
Likes TSny and CPW
I can't see where the 1 in the denominator comes from.
Even with all the tries I never found a +/- 1.
Just multiply numerator and denominator of your answer in post #25 by c/b
  • · Replies 69 ·
