How Do You Find a Recurrence Relation for a Power Series Solution of an ODE?
In summary, the problem is that the OP does not know what to do next after getting the powers of n and indicies to match. He has listed his work in getting the powers of n and the indicies to all match. Any help appreciated.
james weaver
28
Solve the DE in terms of a power series
power series
I believe I am doing everything right up until the point where I have to try and find a recurrence relation. I honestly have no idea what to do from there. I've listed my work in getting the powers of n and the indicies to all match. Any help appreciated.
Here is the original DE:
##y^{'}-(x-1)y=0##
##\sum_{n=1}^\infty na_n x^{n-1}-x\sum_{n=0}^\infty a_n x^{n}+\sum_{n=0}^\infty a_n x^{n}=0##
##\sum_{n=1}^\infty na_n x^{n-1}-\sum_{n=0}^\infty a_n x^{n+1}+\sum_{n=0}^\infty a_n x^{n}=0##
##\sum_{n=0}^\infty {(n+1)}a_{n+1} x^{n}-\sum_{n=1}^\infty a_{n-1} x^{n}+\sum_{n=0}^\infty a_n x^{n}=0##
##2a_0+\sum_{n=1}^\infty {(n+1)}a_{n+1} x^{n}-\sum_{n=1}^\infty a_{n-1} x^{n}+\sum_{n=1}^\infty a_n x^{n}=0##
##2a_0+\sum_{n=1}^\infty \left[{(n+1)}a_{n+1} -a_{n-1}+a_n\right]x^n=0####a_0=0##
##a_1=-2a_2##
##a_2=-a_3##
##a_3=-2a_4##
##a_4=-\frac 5 3 a_5##
##a_5=-\frac 9 4 a_6##
And this is where I get stuck.
Likes Delta2
Write down the general equation of the coefficient for a power of x. Then solve for the coefficient with the highest index in terms of the coefficients with lower indices. That gives the recurrence relation that you will need.
Likes Delta2
As it is deduced from the last line of his derivation, in order for that polynomial to be zero for every ##x##, the coefficient of every power ##x^n## must be zero so $$(n+1)a_{n+1}-a_{n-1}+a_n=0$$ is the recurrence relation for ##a_n##. (and ##a_0=0##).
Your constant term looks wrong to me, it should be ##a_0 + a_1##.
It is also unclear to me if your problem is finding the recursion relation itself (as answered above) -since you have quoted several coefficients- or solving the recursion relation.
  • Wow
Likes FactChecker and Delta2
Or is it that better to say that ##a_0## can be any initial value and then ##a_0+a_1=0 \implies a_1= - a_0##. As is typical of these problems, the first few coefficients have to be done carefully as special cases taking the initial conditions into account. Then the general equation of the n'th coefficient can be routinely applied for the coefficients of the higher powers. EDIT: Hopefully, you can see the pattern and put all of the n'th coefficients in terms of ##a_0##.
Assuming that the title has been carefully stated, I interpret the problem as just defining the Taylor series.
Likes Delta2
FactChecker said:
Or is it that better to say that a0 can be any initial value and then a0+a1=0⟹a1=−a0. As is typical of these problems, the first few coefficients have to be done carefully as special cases taking the initial conditions into account. Then the general equation of the nth coefficient can be routinely applied for the coefficients of the higher powers.
This is always the case. However, in this case we have a first order ODE leading to a recursion relation that contains three different coefficients. The first requires a single initial value, which translates to ##a_0## whereas the second requires two. The second (##a_1##) is determined by the differential equation through the constant term. The recursion relation can then be solved by z-transform.
The title just asks to solve the ODE using a power series. I agree that the actual wording of the question makes it seem like the recursion relation is what the OP has trouble with, but the work shown at least partially contradicts this seeing that the OP quotes several coefficients that are actually found. The step from the OP’s expression to the recursion relation is almost infinitesimal.
Likes FactChecker
Yes. It is not clear if the OP was going in the correct direction or if it went in the wrong direction and got stuck.
It's not clear if the title should be taken literally. If so, then the Taylor series is the goal.
The question doesn't actually require that the power series be centered at zero, so it is more natural here to set [itex]y(x) = \sum_{n=0}^\infty b_n(x - 1)^n[/itex]. Also the ODE is easily solved by separation, so you can compare your answer to the power series of that solution.
Likes FactChecker
Good point! Although it is not mentioned in the OP, I wonder if the x-location of initial conditions would make that x value a better place to expand at.
Likes Delta2
FAQ: How Do You Find a Recurrence Relation for a Power Series Solution of an ODE?
What is an ODE?
An ODE, or ordinary differential equation, is a mathematical equation that relates a function to its derivatives. It is commonly used to model natural phenomena in physics, engineering, and other sciences.
What is a power series?
A power series is a series of the form ∑n=0∞ cn(x-a)n, where cn are coefficients and a is a constant. It is a type of infinite series that can be used to represent functions.
How do you solve an ODE in terms of a power series?
To solve an ODE in terms of a power series, you can substitute the power series into the equation and then equate coefficients of the same powers of x. This will result in a system of equations that can be solved to find the coefficients of the power series.
What are the advantages of solving an ODE in terms of a power series?
Solving an ODE in terms of a power series allows for an exact solution, as the power series can be infinitely accurate. It can also be used to solve ODEs that do not have a closed-form solution.
Are there any limitations to solving an ODE in terms of a power series?
Yes, there are limitations. The power series may not converge for all values of x, so the solution may only be valid for a certain interval. Additionally, the process of equating coefficients can be tedious and may not always result in a closed-form solution.
