Solve this two equations with two unkown of different degrees
  • Thread starter racer
  • Tags
    Degrees
In summary, the conversation discusses solving a system of equations with two unknown variables, x and y. Two methods were presented, including using A and B as new variables to solve for x and y, and using the factorization of x^n + y^n and x^n - y^n. The conversation also includes some errors and corrections, as well as some personal reflections on the beauty of mathematics.
racer
39
Hello there
Anyone who can solve this problem is to me a genius in math.
X^2 + Y^2 = 25
X^3 + Y^3 = 91
Find X and Y
I know that X or Y will be 3 or 4 but I don't know how to solve that equation.
thanks
Mathematics news on Phys.org
Let [tex]x+y = A[/tex] and [tex]xy = B[/tex]. Then
[tex]A^2 - 2B = 25[/tex]
[tex]A^3 - 3AB = 91[/tex]
[tex]AB = 25A - 91[/tex]
[tex]B = 25 - \frac{91}{A}[/tex]
[tex]A^2 + \frac{192}{A} - 50 = 25[/tex]
[tex]A^3 - 75A + 192 = 0[/tex]
You already observed that $A=7$ is a solution, which helps us factor this.
[tex](A - 7)(A^2 + 7A - 26) = 0[/tex]
Now we can use the quadratic formula to do the last bit. The possibilities are
[tex]A = 7, \frac{-7 \pm 3\sqrt{17}}{2}[/tex]
I don't really want to find the values of $x$ and $y$ that give the other two roots. But if you want to do it, just plug into find $B$, and then you have values for X + Y and XY, so you can solve for X in terms of Y, plug into the other equation, and solve for Y (it will be a quadratic).
Doing it for 7 would be like:
A = 7
So B = 25 - 91/7 = 25 - 13 = 12.
We have X + Y = 7 and XY = 12. Then X = 7 - Y, so (7-Y)Y = 12, or Y^2 - 7Y + 12 = 0, or (Y-3)(Y-4) = 0. Then Y = 3 or Y = 4, and that gives X = 4 or X = 3.
There may be a simpler way than what I did, but basically you're going to have to do a lot of algebraic manipulation no matter what.
[tex]x^2 + y^2 = 25[/tex]
[tex]y = \sqrt{25-x^2}[/tex] and [tex]y = -\sqrt{25-x^2}[/tex]
Can you go from there?
Xevarion
Thanks a lot, your answer really impressed me and made me love mathematics more than ever.
Feldoh
I don't think so, I tried but usually it ends up 25 = 25 :D
racer said:
Xevarion
Feldoh
Xevarion's way is better however mine still works. You seem to be using the solutions of y I found to solve
[tex]y^2+x^2=25[/tex]
Which will give you 25=25
Feldoh
Yeah, I've used the solutions of y you found.
can you write your way please?
You can put it into the other equation. However I didn't do this way because then you get a very high degree equation with X. Even knowing the solutions X=3 and X=4 might leave it pretty hard to factor. But Feldoh's method probably can still work. (I'm just too lazy to try it :P)
The reason I introduced A and B was so that you can solve for things twice, which means each time the degree is smaller (3 for A and 2 for X, if you recall).
Sorry to be offtopic but Xevarion do you post on the AOPS forums?
Xevarion
Your solution was amazing but you made one mistake
you wrote 192 instead of 182 but you apparently
calculated it using 182 because you wouldn't get that answer if did 192.
Your answer really taught me something, it is that math is not superficial science where someone just replace uknowns with their values but it is knowing things from every side and angle.
I am very impressed, do you have a B.S in math?
I think it works but the answer would be so long.
One might wonder how Xevarion pulled that one out of his hat.
I suspect he essentially thought of the polynomial factorization:
[tex]x^{3}+y^{3}=(x+y)(x^{2}-xy+y^{2})[/tex]
Thus, using x+y and xy as new variables is a quite natural choice.
Perhaps he had a different first idea..
It's essentially the same as what I did. The factorizations of [tex]x^n + y^n[/tex] and [tex]x^n - y^n[/tex] are very useful.
racer: hehe, thanks. Actually my university gives an AB degree for math (what's called BA elsewhere maybe). And I'll have it in a year and a half, if all goes well. ;-)
FAQ: Solve this two equations with two unkown of different degrees
What are the two equations with two unknowns of different degrees?
The two equations with two unknowns of different degrees are algebraic equations that involve two variables, such as x and y, where the degrees of the variables are different. For example, one equation may have a variable with a degree of 2 (x²) while the other equation has a variable with a degree of 1 (y).
How do I solve two equations with two unknowns of different degrees?
To solve two equations with two unknowns of different degrees, you can use the method of substitution or the method of elimination. In the substitution method, you solve one equation for one variable and then substitute that value into the other equation to solve for the other variable. In the elimination method, you manipulate the equations to eliminate one of the variables and then solve for the remaining variable.
Can I use a graphing calculator to solve two equations with two unknowns of different degrees?
Yes, you can use a graphing calculator to solve two equations with two unknowns of different degrees. Many graphing calculators have a feature that allows you to input two equations and find the point of intersection, which represents the solution to the system of equations.
Do I need to have both equations in the same form to solve them?
No, you do not need to have both equations in the same form to solve them. You can use the method of substitution or the method of elimination to solve the equations, even if they are in different forms. However, it may be easier to solve the equations if they are in the same form, such as standard form or slope-intercept form.
What if the two equations have no solution?
If the two equations have no solution, it means that the lines represented by the equations are parallel and will never intersect. This can happen when the equations have the same slope but different y-intercepts. In this case, there is no solution that satisfies both equations simultaneously.
