Solve Trigonometric Sum: Find S Value
In summary, a trigonometric sum is an equation that involves adding or combining trigonometric functions. To solve a trigonometric sum, one can use identities and formulas to simplify the equation and find the value of the variable. The value of s in a trigonometric sum refers to the solution or answer to the equation. Some common strategies for solving trigonometric sums include using identities, the unit circle, and trigonometric ratios and inverse functions. A trigonometric sum can have multiple solutions, especially when involving periodic functions, and it is important to specify the range or use a period to find all possible solutions.
MarkFL
MHB
13,288
It can be shown that the following sum:
\(\displaystyle S=\sum_{k=1}^{89}\left(\sin^6\left(k^{\circ}\right)\right)\)
is rational. Find the value of $S$. (Callme)
Mathematics news on Phys.org
My solution:
My plan is first to reduce the power of both $\sin^6 x$ and $\cos^6 x$ in their sum, this gives
$\begin{align*}\sin^6 x+\cos^6 x&=\sin^4 x(1-\cos^2 x)+\cos^4 x(1-\sin^2 x)\\&=\sin^4 x+\cos^4 x-(\sin x \cos x)^2(\sin^2 x+\cos^2 x)\\&=\dfrac{(3-4\cos 2x+\cos 4x)+(3+4\cos 2x+\cos 4x)}{8}-\dfrac{\sin^2 2x}{4}\\&=\dfrac{3+\cos 4x}{4}-\dfrac{1-\cos 4x}{8}\\&=\dfrac{5}{8}+\dfrac{3\cos 4x}{8}\end{align*}$
Group the given sum as follows we see that
$\sin^6 1^{\circ}+\sin^6 2^{\circ}+\cdots + \sin^6 88^{\circ}+\sin^6 89^{\circ}$
$=(\sin^6 1^{\circ}+\sin^6 89^{\circ})+(\sin^6 2^{\circ}+\sin^6 88^{\circ})+\cdots+(\sin^6 44^{\circ}+\sin^6 46^{\circ})+(\sin^6 45^{\circ})$
$=(\sin^6 1^{\circ}+\cos^6 1^{\circ})+(\sin^6 2^{\circ}+\cos^6 2^{\circ})+\cdots+(\sin^6 44^{\circ}+\cos^6 44^{\circ})+\left(\dfrac{1}{\sqrt{2}}\right)^6$
$=\left(\dfrac{5}{8}+\dfrac{3\cos 4^{\circ}}{8}\right)+\left(\dfrac{5}{8}+\dfrac{3\cos 8^{\circ}}{8}\right)+\cdots+\left(\dfrac{5}{8}+\dfrac{3\cos 176^{\circ}}{8}\right)+\dfrac{1}{8}$
$=44\left(\dfrac{5}{8}\right)+\dfrac{3}{8}((\cos 4^{\circ}+\cos 176^{\circ}+)+(\cos 8^{\circ}+\cos 172^{\circ})+\cdots+(\cos 88^{\circ}+\cos 92^{\circ}))+\dfrac{1}{8}$
$=44\left(\dfrac{5}{8}\right)+\dfrac{3}{8}(0)+\dfrac{1}{8}$
$=\dfrac{221}{8}$
$\therefore S=\dfrac{221}{8}$
we have
$\sin^6 x + \cos^6 x$
= $(\sin ^2x + \cos^2x)^3 - 3 \sin ^2 x \cos^2 x(\sin ^2 x + \cos^2 x)$
= $1- 3 \sin ^2 x \cos^2 x$
= $ 1- \dfrac{3}{4}(2 \sin x\, \cos\, x)^2 $
= $1- \dfrac{3}{4}(sin ^2 2x)$
= $1- \dfrac{3}{8}(2 sin ^2 2x)$
= $1- \dfrac{3}{8}(1- cos 4x)$
= $ \dfrac{5}{8}+\dfrac{3}{8}\cos 4x$
as $\sin \,x^{\circ} = \cos \, (90-x)^{\circ}$
now
$S=\sum_{k=1}^{89}\left(\sin^6\left(k^{\circ}\right)\right)$
= $\sin^6 45^{\circ} + \sum_{k=1}^{44}\left(\sin^6\left(k^{\circ}\right)+\cos^6\left(k^{\circ}\right)\right )$
= $\dfrac{1}{8} + \sum_{k=1}^{44}(\dfrac{5}{8}+\dfrac{3}{8}\cos\,4k^{\circ})$
= $\dfrac{221}{8} + \dfrac{3}{8} \sum_{k=1}^{44}(\cos\,4k^{\circ})$
now as $cos 4^{\circ} + cos 4 * 44^{\circ} = 0$ so on so sum of the cosines is zeo so result = $\dfrac{221}{8}$hence $S = \dfrac{221}{8}$
Note: As I was solving Anemone beat me to it.
Thank you anemone and kaliprasad for participating! (Sun)
My solution is essentially the same:
I first used the co-function identity:
\(\displaystyle \sin\left(90^{\circ}-x\right)=\cos(x)\)
to express the sum as:
\(\displaystyle S=\sum_{k=1}^{44} \sin^6\left(k^{\circ}\right)+\sin^6\left(45^{\circ}\right)+\sum_{k=1}^{44} \cos^6\left(k^{\circ}\right)\)
Hence:
\(\displaystyle S=\sum_{k=1}^{44}\left(\sin^6\left(k^{\circ}\right)+\cos^6\left(k^{\circ}\right)\right)+\frac{1}{8}\)
Now consider the following (sum of 2 cubes and a Pythagorean identity):
\(\displaystyle \sin^6(x)+\cos^6(x)=\sin^4(x)-\sin^2(x)\cos^2(x)+\cos^4(x)\)
Now, if we write everything in terms of sine, we obtain:
\(\displaystyle 3\sin^4(x)-3\sin^2(x)+1\)
Factor and use a Pythagorean identity:
\(\displaystyle 1-3\sin^2(x)\cos^2(x)\)
Apply double-angle identity for cosine:
\(\displaystyle \frac{4-3\left(1-\cos^2(2x)\right)}{4}\)
\(\displaystyle \frac{4-3\sin^2(2x)}{4}\)
Double-angle identity for cosine:
\(\displaystyle \frac{8-3\left(1-\cos(4x)\right)}{8}\)
\(\displaystyle \frac{3\cos(4x)+5}{8}\)
Hence, we now have:
\(\displaystyle S=\frac{1}{8}\sum_{k=1}^{44}\left(3\cos \left(4k^{\circ}\right)+5\right)+\frac{1}{8}\)
\(\displaystyle S=\frac{1}{8} \left(3\sum_{k=1}^{44} \left(3\cos \left(4k^{\circ} \right) \right)+44\cdot5+1 \right)\)
\(\displaystyle S=\frac{1}{8} \left(3\sum_{k=1}^{44} \left(\cos \left(4k^{\circ} \right) \right)+221 \right)\)
Now, observe that:
\(\displaystyle \cos\left(180^{\circ}-x\right)=-\cos(x)\)
And we may write:
\(\displaystyle S=\frac{1}{8} \left(3\sum_{k=1}^{22} \left(\cos \left(4k^{\circ} \right)-\cos \left(4k^{\circ} \right) \right)+221 \right)\)
The sum goes to zero, and we are left with:
\(\displaystyle S=\frac{221}{8}\)
FAQ: Solve Trigonometric Sum: Find S Value
What is a trigonometric sum?
A trigonometric sum is an equation that involves adding or combining trigonometric functions, such as sine, cosine, and tangent.
How do you solve a trigonometric sum?
To solve a trigonometric sum, you can use trigonometric identities, such as the Pythagorean identities and sum and difference formulas, to simplify the equation and find the value of the variable.
What is the value of s in a trigonometric sum?
The value of s in a trigonometric sum refers to the solution or answer to the equation, usually representing an angle or a side length in a triangle.
What are some common strategies for solving trigonometric sums?
Some common strategies for solving trigonometric sums include using trigonometric identities, applying the unit circle, and using trigonometric ratios and inverse trigonometric functions.
Can a trigonometric sum have multiple solutions?
Yes, a trigonometric sum can have multiple solutions, especially when the equation involves periodic functions like sine and cosine. It is important to specify the range of solutions or use a period to find all possible solutions.
