Solve \(u_{tt} - u_{xx} = \sin(u)\): Let \(u(\xi)\)
  • MHB
  • Thread starter Dustinsfl
  • Tags
    Sine
In summary, we use the chain rule to show that $u_{xx} = u_{\xi\xi}$ and $u_{tt} = c^2u_{\xi\xi}$. Therefore, the equation $u_{tt} - u_{xx} = \sin(u)$ can be rewritten as $(1-c^2)u_{\xi\xi} = \sin(u)$, which is the standard form of the sine Gordon equation. However, there seems to be a sign error, as the original equation was $u_{xx} - u_{tt} = \sin(u)$ rather than $u_{tt} - u_{xx}$.
Dustinsfl
2,281
Consider \(u_{tt} - u_{xx} = \sin(u)\). Let \(u(\xi) = u(x - ct)\).
How do we get \((1 - c^2)u_{\xi\xi} = \sin(u)\)?
u_{\xi\xi} = u_{xx} - c^2u_{tt}
Correct?
Correct?
If $u$ is a function of $\xi$, where $\xi = x-ct$, then the chain rule says that $u_t = \tfrac{\partial u}{\partial t} = \tfrac{du}{d\xi}\tfrac{\partial \xi}{\partial t} = -c\tfrac{du}{d\xi} = -cu_{\xi}.$ The same calculation, repeated, says that $u_{tt} = c^2u_{\xi\xi}.$ In the same way, $u_{xx} = u_{\xi\xi}.$ So the equation $u_{xx} - u_{tt} = \sin u$ becomes $(1-c^2)u_{\xi\xi} = \sin u.$ That is the standard form of the sine Gordon equation, but you seem to have changed a sign somewhere, writing $u_{tt} - u_{xx}$ rather than $u_{xx} - u_{tt}.$
FAQ: Solve \(u_{tt} - u_{xx} = \sin(u)\): Let \(u(\xi)\)
What is the equation being solved?
The equation being solved is utt - uxx = sin(u). This is a partial differential equation (PDE) that involves the second derivative of u with respect to time (t) and space (x).
What does u(ξ) represent?
u(ξ) represents the solution to the given PDE at a specific point in space and time. It is a function of the variables ξ, which can be any point in the spatial domain.
How is this equation typically solved?
This equation is typically solved using numerical methods, such as finite difference or finite element methods. These methods involve discretizing the equation into a system of algebraic equations and solving them iteratively to approximate the solution at each time step.
What is the significance of the sine function in this equation?
The sine function in this equation represents a forcing term or external input that affects the behavior of u. This can represent a variety of physical phenomena, such as a periodic external force or a nonlinear interaction between different parts of the system.
What are some possible applications of this equation?
This equation has many potential applications in physics and engineering, such as modeling wave propagation, heat transfer, and fluid dynamics. It can also be used to study nonlinear behavior and stability in various systems.
