Solve Unit Step Function Algebraically - Help Needed
In summary: Re: Unit step function. help!uhm, please bear for my being ignorant here.When you evaluate the function at x=-1, it gives 0. Why is that different to -1<=x<0? Can you give me an example of numerical computation of the Heaviside step function?
paulmdrdo1
385
How would I go about algebraically (not graphically) performing operations on two or more Heaviside function.H(x) = {0, if x<0
...{1, if x>=0
ex. define the function piecewise and graph.
a.) (x+1)*H(x+1)-x*H(x)
b.) (x+1)*H(x+1)
i'm having a hard time solving this please help me!
Mathematics news on Phys.org
...{1, if x>=0
b.) (x+1)*H(x+1)
Welcome to MHB, paulmdrdo! :)
The Heaviside step function switches value at x=0.
Where does H(x+1) switch value?
So which are the relevant boundaries to consider for (a)?
Following up, what does (a) look like if x is below the lowest boundary?
thanks for the reply! the point of interest in (a) is -1. the function values at x<-1 are all 0.
but I'm still confused with that kind of problem like in (a). could you provide me your solution in problem (a). i just want to compare my thought process with others when I'm solving that. thanks!
The first step in the piecewise solution of (a) is:
(x+1) H(x+1)-x H(x) = \left\{ \begin{aligned}
(x+1) H(x+1)-x H(x) & \qquad \text{if } x< -1 \\
(x+1) H(x+1)-x H(x) & \qquad \text{if } -1 < x< 0 \\
(x+1) H(x+1)-x H(x) & \qquad \text{if } x > 0 \\
\text{special value} & \qquad \text{if } x = -1 \vee x = 0 \\
\end{aligned}\right.
Note that with the Heaviside step function there are a couple more boundary conditions that I'm going to ignore for now, since H(0) is defined to be 1/2.
Can you simplify the piecewise solution?
(x+1) H(x+1)-x H(x) = {0, if x<-1
........{x, if -1<x<0
........{1, x>0
but why did you consider x=-1 and x=0 special value?
........{1, x>0
Can you reevaluate the case -1<x<0?
Hmm, I just found that different sources define H(x) differently.
According to Wolfram $H(0)=\frac 1 2$, but according to wiki $H(0)=1$.
oh! is there another answer to that? how to do that?
hey i just noticed something here
if x=-1 the function value is 0 and when x=0 the fuction value is 1
so we can define the function as
(x+1) H(x+1)-x H(x) = {0, if x<=-1
......{x, if -1<x<0
......{1, x=>0
am I correct?
After closer inspection, in this particular case both answers turn out to be the same:
(x+1) H(x+1)-x H(x) = \left\{ \begin{array}{ll}
0 & \qquad \text{if } x< -1 \\
x+1 & \qquad \text{if } -1 \le x < 0 \\
1 & \qquad \text{if } x \ge 0 \\
\end{array}\right.
Note that the case $-1 \le x < 0$ is different from what you have.
\end{array}\right.
when i evaluated the function at x=-1 it gives 0. why is that different to -1<=x<0?
can you give me example of numerical computation of it?
That is correct.
It isn't.
But you specified for $-1 \le x<0$ the value $x$.
That implies that at $x=-1$ it gives $-1$, which is incorrect.
I like Serena said:
That is correct.
It isn't.
thank you! I'm so amazed! you're so generous in answering me queries! I've never been in a forum like this one. hope you'll continue helping a math learners like me. I can't learn math on my own thanks to MHB! more power. by the way I'm a 6th grader. learning this is so challenging!
I like Serena said:
That is correct.
It isn't.
i have tried other answers
........{x, if -1<=x<=0
........{1, if x>0
and
......{x+1, if -1<=x<=0
......{1, if x>0
also,
......{x, if -1<x<0
......{1, x=>0
are these correct?
........{1, if x>0
and
......{1, if x>0
also,
......{x, if -1<x<0
......{1, x=>0
are these correct?
The place where you put the equalities are not particularly relevant, but the case -1<x<0 really has to read x+1 instead of x.
actually this is the answer i saw on my solution's manual
........{1, if x>0
but I still don't fully understand what are the steps used in solving this.
........{1, if x>0
Then the solutions manual is wrong.
Sorry.
Sorry.
yeah. i also suspected that. now it is confirmed. you told about relevant boundaries I should consider, how would I determine those relevant boundaries?
Just check what your function does at x=-1 and x=0.
When there are "jumps", you should consider what happens exactly at those jumps.
In your case (a) there aren't any jumps, meaning it doesn't matter.
In practice those jumps are usually not particularly relevant for the Heaviside step function.
can you spot what I'm doing wrong.
what i did is I plugged x-values to the function
it turns out that on the interval (-∞ ,-1) the function value is 0. and then on the interval (-1, 0) the function values are the same as the x-values (on the interval(-1,0)) that i started with. and then i graphed it. and on the interval (0,+∞ ) the function values is 1.
the graph of the function looks like continuous. when i try to define it piecewise I don't know how to put my cases correctly.
FAQ: Solve Unit Step Function Algebraically - Help Needed
What is a unit step function?
A unit step function is a mathematical function that takes a value of 0 for all negative inputs and a value of 1 for all positive inputs. It is often represented using the notation u(t) or θ(t).
How do I solve a unit step function algebraically?
To solve a unit step function algebraically, you need to first identify the interval in which the function is defined. Then, you can use the definition of a unit step function to write out the function for that interval. Finally, you can use basic algebraic techniques to simplify the function and solve for the desired value.
Can I use the unit step function to solve real-world problems?
Yes, the unit step function can be used to model and solve various real-world problems, such as modeling the response of an electrical circuit or the growth of a population over time. It is a useful tool in engineering, economics, and other fields.
Are there any limitations to using the unit step function?
While the unit step function is a useful tool, it does have some limitations. It is a discontinuous function, meaning it has abrupt changes at specific points, which may not accurately reflect real-life situations. Additionally, it can only take on two values (0 and 1), so it may not be suitable for modeling more complex systems.
Are there any alternative methods for solving unit step functions?
Yes, there are alternative methods for solving unit step functions, such as using graphical techniques or using software programs like MATLAB or Wolfram Alpha. These methods may be more efficient and accurate for more complex functions and equations.
