Solve V_A in Circuit with Nodal Analysis
In summary, the conversation discusses the use of nodal analysis to find V_A in a circuit. KVL, KCL, and the equations v = i R and super-node are mentioned as possible methods. A solution is attempted using KVL and KCL equations for V_1 and V_3, and the final result is determined to be V_1 = V_A = 22.34 V.
VinnyCee
489
Use nodal analysis to find [itex]V_A[/itex] in the circuit below.
http://img180.imageshack.us/img180/7004/chapter3problem236vy.jpg
KVL, KCL, v = i R, super-node?
I made a few currents and showed the obvious KVL loop.
http://img201.imageshack.us/img201/4716/chapter3problem23part22nf.jpg
[tex]V_1\,=\,V_A[/tex] <---- Right?
[tex]I_1\,=\,\frac{V_1\,-\,0}{2\Omega}[/tex]
[tex]I_2\,=\,\frac{V_3\,-\,0}{16\Omega}[/tex]
[tex]I_3\,=\,\frac{V_1\,-\,V_2}{4\Omega}[/tex] <------Right?I know KCL for [itex]V_1[/itex]:
[tex]\frac{30\,-\,V_1}{1\Omega}\,=\,\frac{V_1\,-\,0}{2\Omega}\,+\,\frac{V_1\,-\,V_2}{4\Omega}[/tex]
[tex]7\,V_1\,-\,V_2\,=\,120[/tex]I know KCL for [itex]V_3[/itex]:
[tex]\frac{V_1\,-\,V_2}{4\Omega}\,+\,3\,=\,\frac{V_3\,-\,0}{16\Omega}[/tex]
[tex]4\,V_1\,-\,4\,V_2\,-\,V_3\,=\,-48[/tex]For KVL1:
[tex]-V_1\,+\,4\,I_3\,+2\,V_A\,+\,V_3\,=\,0[/tex]
[tex]2\,V_1\,-\,V_2\,+\,V_3\,=\,0[/tex]Now, putting those three EQs into a matrix and rref:
[tex]\left[\begin{array}{cccc}7&-1&0&120\\4&-4&-1&-48\\2&-1&1&0\end{array}\right]\,\,\longrightarrow\,\,\left[\begin{array}{cccc}1&0&0&\frac{648}{29}\\0&1&0&\frac{1056}{29}\\0&0&1&-\frac{240}{29}\end{array}\right][/tex]
This gives me [itex]V_1\,=\,V_A[/itex] equal to 22.34 V.
Thanks for the help mjsd!
all your equations look sound to me..
oh..hang on... 2nd line for KCL for V3 is wrong where is the 48 gone?
Corrected, thanks much!
FAQ: Solve V_A in Circuit with Nodal Analysis
How is nodal analysis used to solve for VA in a circuit?
Nodal analysis is a method used to determine the voltage at a specific node in a circuit. It involves creating a system of equations based on Kirchhoff's Current Law and Ohm's Law, and solving for the unknown node voltage using algebraic manipulation.
What are the steps for performing nodal analysis?
The steps for performing nodal analysis are as follows:
  • Identify the nodes in the circuit
  • Choose a reference node and assign it a voltage of 0
  • Write Kirchhoff's Current Law equations for each non-reference node
  • Substitute in Ohm's Law equations for each resistor in terms of the node voltages
  • Solve the resulting system of equations to find the node voltages
  • Calculate the voltage at the desired node using the node voltages found in the previous step
Can nodal analysis be used for circuits with voltage sources?
Yes, nodal analysis can be used for circuits with voltage sources. The voltage of the source is treated as a known value and is included in the equations for Kirchhoff's Current Law.
Are there any limitations to using nodal analysis?
One limitation of nodal analysis is that it can only be used for circuits with a single reference node. It also becomes more complex as the number of nodes in the circuit increases, making it more time-consuming to solve for the node voltages.
What is the advantage of using nodal analysis over other circuit analysis methods?
Nodal analysis is a systematic and precise method for solving for node voltages in a circuit. It allows for the use of Kirchhoff's Current Law and Ohm's Law to easily determine the voltage at any desired node. It also does not require the use of any assumptions, unlike other circuit analysis methods such as the mesh analysis.
