Solve Vertical Tangent: y-e^(xy) + x = 0
  • MHB
  • Thread starter grgrsanjay
  • Tags
    Tangent
In summary, the curve $\displaystyle y-e^{(xy)} + x=0$ has a vertical tangent at the point (1,0) and the equation of the curve is $y=\frac{1-x^2}{x}$. To find this point, implicit differentiation was used to get $y'=\dfrac{ye^{xy}-1}{1-xe^{xy}}$. The point of the vertical tangent is where the denominator of $y'$ is equal to zero, leading to the equation $e^{xy}=\dfrac{1}{x}$. Solving this equation with the original equation gives the solution (1,0).
grgrsanjay
The curve $\displaystyle y-e^{(xy)} + x=0 $ has a vertical tangent at which point??
I started to differentiate it, then equating dy/dx to 0, then how should i proceed??
Find where $y'$ is not defined. It is not where it is zero.
Sorry...i did the same,typed wrongly
i equated the denominator to zero.i got $ xe^{xy} = 1 $
then what?
Yea,yea got it dy/dx=0, so the equation is of the form x = a
y=0
substituting it at this $ xe^{xy} = 1 $,we getx=1
So, point is (1,0)
hmm...i stumbled to a easy question :(
Hello, grgrsanjay!
I had an idea . . . then hit a wall.
Maybe someone can carry on ?
The curve .$\displaystyle y-e^{xy} + x=0 $ has a vertical tangent at which point?
Differentiate implicitly: .$y' - e^{xy}(xy' + y) + 1 \;=\;0 \quad\Rightarrow\quad y' - xy'e^{xy} - ye^{xy} + 1 \;=\;0 $
. . . . . $ y' - xy'e^{xy} \;=\; ye^{xy} - 1 \quad\Rightarrow\quad y'(1-xe^{xy}) \;=\; ye^{xy}-1 $
. . . . . $y' \;=\;\dfrac{ye^{xy} - 1}{1 - xe^{xy}} $The curve has a vertical tangent where the denominator equals zero:
. . . $ 1 - xe^{xy} \:=\:0 \quad\Rightarrow\quad e^{xy} \:=\:\dfrac{1}{x} $Substitute into the original equation (?)
. . . $ y - \frac{1}{x} + x \:=\:0 \quad\Rightarrow\quad y \:=\:\dfrac{1-x^2}{x}$Does this help?
soroban said:
Hello, grgrsanjay!
Hmm. $xy=\ln(1/x)$, so $y=\ln(1/x)/x$. Therefore, solve the following simultaneously:
\begin{align*}
y&=\frac{1-x^{2}}{x}\\
y&=\frac{\ln(1/x)}{x}.
\end{align*}
Hence
$$\frac{1-x^{2}}{x}=\frac{\ln(1/x)}{x}\implies 1-x^{2}=\ln(1/x)\implies e^{1-x^{2}}=1/x\implies e^{x^{2}-1}=x.$$
There look to be two solutions, but I think you might have to find one of them numerically.
Thanks for your help!
I Understood it :)
FAQ: Solve Vertical Tangent: y-e^(xy) + x = 0
What does it mean to find the vertical tangent of a curve?
Finding the vertical tangent of a curve involves determining the slope of the curve at a point where the slope is undefined, or the curve is vertical. This is typically done by taking the derivative of the curve at the given point.
How do you solve for the vertical tangent of a curve?
To solve for the vertical tangent of a curve, we can follow the steps of finding the derivative of the curve, setting the derivative equal to undefined, and solving for the x value that makes the derivative undefined. This x value will be the point where the curve has a vertical tangent.
What is the significance of finding the vertical tangent of a curve?
The vertical tangent of a curve indicates a point where the curve changes direction abruptly. This can provide valuable information about the behavior of the curve and can help us understand the characteristics of the curve.
What is the role of e^(xy) in the equation y-e^(xy) + x = 0?
The term e^(xy) is a mathematical function known as the exponential function. In this equation, it is used to model the behavior of a curve and can help us determine the slope of the curve at a given point. It is an important part of the equation and cannot be ignored when solving for the vertical tangent.
Can we find the vertical tangent of any curve?
Yes, the vertical tangent can be found for any curve as long as the curve is differentiable. This means that the curve has a well-defined slope at every point. However, some curves may have multiple vertical tangents or no vertical tangents at all, depending on their behavior.
