MHB Solve Volterra Equation: Integral Equation Guide
  • Thread starter Thread starter Dustinsfl
To solve the Volterra integral equation \(f(x) = \sqrt{x} + \lambda\int_0^x\sqrt{xy}f(y)dy\), differentiation is suggested, leading to a first-order ordinary differential equation (ODE). The derived expression for \(f'(x)\) simplifies to a separable form, allowing for integration with the initial condition \(f(0) = 0\). The discussion reveals that substituting \(\frac{f(x) - \sqrt{x}}{\sqrt{x}}\) into the ODE clarifies the relationship between \(f(x)\) and the integral. Ultimately, rewriting the equation in terms of \(h(x) = f(x)/\sqrt{x}\) leads to a simplified form that can be solved with initial conditions.
Dustinsfl
How do I solve the Volterra integral equation?
Re: volterra eq
Have you tried differentiating it?
Re: volterra eq
The derivative is
f'(x) = \frac{1}{2\sqrt{x}} + \lambda\left(xf(x) + \int_0^1\frac{y}{2\sqrt{xy}}f(y)dy\right)
How does this help?
Re: volterra eq
dwsmith said:
The derivative is
How does this help?
Now you can replace the integral in the expression for the derivative by the expression for it you get from the original equation leaving you with a first order ordinary differential equation.
(and you should still have \(x\) as the upper limit in the integral, you will also find things easier if you take the \(x\) outside the integral)
Re: volterra eq
So
\int_0^x\sqrt{y}f(y)dy = \frac{f(x) - \sqrt{x}}{\lambda\sqrt{x}}
Plugging this in we get
f'(x) = \frac{1}{2\sqrt{x}} - \frac{1}{2\lambda\sqrt{x}} + f(x)\left(x\lambda + \frac{1}{2\lambda\sqrt{x}}\right).
IWhat am I suppose to do with the \(f'(x)\) equation? The solution to this ODE isn't trivial.
Re: volterra eq
dwsmith said:
So
Well for \(x>0\), I get:
\[f'(x)=f(x)\left[\frac{1}{2x}+\lambda x\right]\]
which assuming no (further) mistakes in the manipulations is of variables seperable type with initial condition \(f(0)=0\)
Note the derivative is:
\[\frac{d}{d\,x}\,f\left( x\right) = \frac{\lambda\,\int_{0}^{x}\sqrt{y}\,f\left( y\right) dy}{2\,\sqrt{x}}+\lambda\,x\,f\left( x\right) +\frac{1}{2\,\sqrt{x}}\]
Re: volterra eq
\[f'(x)=f(x)\left[-\frac{1}{2x}+\lambda x\right]\]
which assuming no mistakes in the manipulations is of variables seperable type with initial condition \(f(0)=0\)
How did you get that expression?
Re: volterra eq
By substituting \(\frac{f(x) - \sqrt{x}}{\sqrt{x}}\) for \(\lambda \int_0^x\sqrt{y}f(y)dy \) in the expression for the derivative.
Re: volterra eq
Shouldn't it be + not minus? Also, for +, the ODE evaluates to
f(x) = C \sqrt{x} e^{\frac{\lambda x^2}{2}}.
With the IC of \(f(0) = 0\), \(f(x) = C\cdot 0 = 0\).
Re: volterra eq
... probably
Re: volterra eq
Which suggests that we go back to the original integral equation and rewrite it in terms of \(h(x)=f(x)/\sqrt{x}\), which if all has gone well is:
\[h(x)=1+\lambda \int_0^x y\; h(y)\ dy\]
which gives initial condition \(h(0)=1\) and:
\[h'(x) = x h(x)\]
which I think results in \(C=1\).
