Solve Work Rate Problem: 6 Men Colouring 36m Cloth in x Days
  • MHB
  • Thread starter NotaMathPerson
  • Tags
    Rate Work
In summary: Yes, it is possible. However, this is not the most efficient way to solve the problem. It is important to understand the formula and reasoning behind it in order to solve similar problems in the future.
NotaMathPerson
83
if 4 men can colour 48 m of cloth in 2 days, in how many days can 6 men colour a 36 m cloth?
Can you give me a general method on solving this problem? Thanks!
Mathematics news on Phys.org
I would solve this by computing how many m. of cloth 1 man colors in 1 day...
I found that one man can do 6m of cloth a day. By 48/(8) =6
If one man can do 6m a day then 6 men can do 36m in one day.
But I want some formula or something that would generalize the process. I having difficulty doing that.
Hello guys!
As I was searching on the net for a general formula to solve this problem I stubled upon this
M1*H1*D1*E1*W2=M2*H2*D2*E2*W1
Where M = # of men; D = # of days; H = # of hours ;W = # something done; E = efficiency.
Now if I will relate it to the problem above
M1 = 4 men, W1 = 48 m, D1 = 2 days.
M2 = 6, W2 = 36m, D2 = ? days.
From here it is only a matter plugging in the given to get 1 day as an answer.
Now my questions are
1. What do we call the value when we multiply out both sides of M1*H1*D1*E1*W2=M2*H2*D2*E2*W1(what is the unit or name associated to it?)
2. Why the W2 is on the left hand side? Same with W1 that is on right hand side of the eqn.
3. Why do we equate M1*H1*D1*E1*W2=M2*H2*D2*E2*W1?
Please I need to learn this. Kindly explain. Thanks!
The amount of work that gets done can be assumed to be proportional to the number of men working and the length of time they work:
\(\displaystyle W_n=kM_nt_n\)
Thus, given two groups of men working (presumably all at the same rate), we may state:
\(\displaystyle k=\frac{W_1}{M_1t_1}=\frac{W_2}{M_2t_2}\implies W_1M_2t_2=W_2M_1t_1\)
Both sides would have units of "man-days of work."
From this, we may write:
\(\displaystyle t_2=\frac{W_2M_1t_1}{W_1M_2}\)
Plugging in the values from the original problem, we find:
\(\displaystyle t_2=\frac{36\cdot4\cdot2}{48\cdot6}=1\)
Hello!
What does the efficiency mean in the formula?
NotaMathPerson said:
Hello!
I would say efficiency is related to the amount of work done per man-time...so let's put efficiency $E$ into the equation:
\(\displaystyle W_n=kE_nM_nt_n\)
Dimensional analysis shows that $k$ is now dimensionless (before, $k$ included efficiency)...and so we can now state:
\(\displaystyle k=\frac{W_1}{E_1M_1t_1}=\frac{W_2}{E_2M_2t_2}\implies W_1E_2M_2t_2=W_2E_1M_1t_1\)
Can it be tripple ratio?
4:48:2 = 6:36:x
men to meter ratio defined;
12:2 = 6:x
mean & extreme
x = 12/12 = 1
1 day is the answer
is it possible??
FAQ: Solve Work Rate Problem: 6 Men Colouring 36m Cloth in x Days
What is a work rate problem?
A work rate problem is a type of mathematical problem that involves determining the amount of work that can be completed in a given amount of time, based on the rate of work of the individuals involved. It is commonly used in fields such as engineering, physics, and economics.
What is the scenario in the "6 Men Colouring 36m Cloth in x Days" problem?
In this problem, there are 6 men who are working together to color a 36m cloth. The goal is to determine how many days it will take them to complete the task.
How do you solve a work rate problem?
To solve a work rate problem, you need to use the formula: Work = Rate x Time. In this case, the work is known (36m of cloth), and the rate is the combined rate of the 6 men. By setting up and solving the equation, you can determine the time it will take to complete the task.
What is the formula for solving the "6 Men Colouring 36m Cloth in x Days" problem?
The formula for solving this problem is: 36m = (6 men's combined rate) x (x days). This can be rearranged to solve for x: x = 36m / (6 men's combined rate). This will give you the number of days it will take the 6 men to color the 36m cloth.
How do you find the combined rate of the 6 men?
The combined rate of the 6 men can be found by adding together their individual rates. For example, if each man can color 6m of cloth in one day, the combined rate would be 6 men x 6m per day = 36m per day. This combined rate can then be used in the formula to solve for the number of days it will take to color the 36m cloth.
