Solve $x^4+4x^2+6=x$ for all Complex Numbers
  • MHB
  • Thread starter anemone
In summary, the process for solving this equation involves isolating the variable x using algebraic manipulations and then using methods such as factoring, completing the square, or using the quadratic formula to find solutions. There are no restrictions on the values of x for which this equation can be solved, and it can be solved without using complex numbers if the solutions are real numbers. However, if the solutions are complex numbers, complex numbers must be used in the solution process. This equation has four solutions, but some may be repeated or complex. There is no one "best" method for solving this equation, and the most appropriate method depends on the equation and the solver's preferences. It is important to be familiar with multiple methods and know when to
anemone
MHB
POTW Director
3,883
115
Solve for all complex numbers $x$ such that $x^4+4x^2+6=x$.
Mathematics news on Phys.org
My solution:
I would arrange the equation as:
\(\displaystyle x^4+4x^2-x+6=0\)
Then I would assume a possible factorization of the form:
\(\displaystyle x^4+4x^2-x+6=\left(x^2+ax+2\right)\left(x^2+bx+3\right)\)
Expand the right side:
\(\displaystyle x^4+4x^2-x+6=x^4+(a+b)x^3+(ab+5)x^2+(3a+2b)x+6\)
Equating the right coefficients yields the linear system:
\(\displaystyle a=-b\)
\(\displaystyle 3a+2b=-1\)
This implies $a=-1,\,b=1$ and so we have:
\(\displaystyle x^4+4x^2-x+6=\left(x^2-x+2\right)\left(x^2+x+3\right)=0\)
Application of the quadratic formula on each quadratic factor in turn yields:
\(\displaystyle x=\frac{1\pm\sqrt{7}i}{2}\)
\(\displaystyle x=\frac{-1\pm\sqrt{11}i}{2}\)
Very well done, MarkFL!:cool:
My solution:
Completing the square on the LHS we get:
$(x^2+2)^2+2=x$, so
$(x^2+2)^2+2-x=0$,
$(x^2+2)^2-x^2+x^2+2-x=0$,
$(x^2+2+x)(x^2+2-x)+x^2+2-x=0$ and this can be easily factorized as
$(x^2+2-x)(x^2+2+x+1)=0$
$(x^2+3+x)(x^2+2-x)=0$ and solving each factor for the corresponding complex solutions we get
$x=\dfrac{1\pm i\sqrt{7}}{2}$ or $x=\dfrac{-1\pm i\sqrt{11}}{2}$.
FAQ: Solve $x^4+4x^2+6=x$ for all Complex Numbers
What is the process for solving this equation?
The process for solving this equation involves using algebraic manipulations to isolate the variable x on one side of the equation. Then, we can use various methods such as factoring, completing the square, or using the quadratic formula to find the solutions.
Are there any restrictions on the values of x for which this equation can be solved?
No, there are no restrictions on the values of x for solving this equation. It can be solved for all complex numbers.
Can this equation be solved without using complex numbers?
Yes, this equation can be solved without using complex numbers if the solutions are real numbers. However, if the solutions are complex numbers, then complex numbers must be used in the solution process.
How many solutions does this equation have?
This equation has four solutions, as indicated by the exponent of 4 in the equation. However, some solutions may be repeated or may be complex numbers.
Is there a specific method that is best for solving this equation?
There is no one "best" method for solving this equation. The most appropriate method will depend on the specific equation and the preferences of the solver. It is important to be familiar with multiple methods and know when to apply them in order to efficiently solve the equation.
