Solve x/y+y/z+z/x for Real Numbers with 24,10
  • MHB
  • Thread starter anemone
In summary, the equations provided are used to solve for the value of $\frac{x}{y}+\frac{y}{z}+\frac{z}{x}$.
anemone
MHB
POTW Director
3,883
115
Let $x,\,y,\,z$ be real numbers satisfying
$\dfrac{(x+y)(y+z)(z+x)}{xyz}=24$
$\dfrac{(x-2y)(y-2z)(z-2x)}{xyz}=10$
Find $\dfrac{x}{y}+\dfrac{y}{z}+\dfrac{z}{x}$.
Mathematics news on Phys.org
Hi anemone,
Thanks for the challenge. :)
Simplifying the first equation we get,
\[\frac{x+y}{z}+\frac{x+z}{y}+\frac{y+z}{x}=22\]
Simplifying the second equation we get,
\[\frac{2x-z}{y}+\frac{2y-x}{z}+\frac{2z-y}{x}=\frac{17}{2}\]
Adding these two equations we get,
\[\frac{x}{y}+\frac{y}{z}+\frac{z}{x}=\frac{17}{6}\]
Sudharaka said:
Hi anemone,
\[\frac{$\dfrac{x+y}{z}+\dfrac{x+z}{y}+\dfrac{y+z}{x}+
\dfrac{2x-z}{y}+\dfrac{2y-x}{z}+\dfrac{2z-y}{x}=22+\dfrac{17}{2}$
$\rightarrow 3\left(\dfrac{x}{y}+\dfrac{y}{z}+\dfrac{z}{x}\right)=\dfrac{61}{2}$
$\therefore \dfrac{x}{y}+\dfrac{y}{z}+\dfrac{z}{x}=\dfrac{61}{6}$}{z}+\frac{x+z}{y}+\frac{y+z}{x}=22\]
Hi Sudharaka, :)
Thanks for participating. You've used a systematic approach to solve for this challenge. Unfortunately you've made a minor addition error, but it is a good solution nevertheless. Well done, Sud!
anemone said:
Hi Sudharaka, :)
Ah... silly algebra... :p
I would first analyze the given information and understand the equations provided. The first equation states that the product of the three expressions, (x+y), (y+z), and (z+x), when divided by the product of x, y, and z, is equal to 24. Similarly, the second equation states that the product of the three expressions, (x-2y), (y-2z), and (z-2x), when divided by the product of x, y, and z, is equal to 10.
To solve for the required expression, $\dfrac{x}{y}+\dfrac{y}{z}+\dfrac{z}{x}$, I would first manipulate the given equations to get rid of the fractions. For the first equation, I would multiply both sides by xyz to get:
$(x+y)(y+z)(z+x)=24xyz$
Similarly, for the second equation, I would multiply both sides by xyz to get:
$(x-2y)(y-2z)(z-2x)=10xyz$
Next, I would expand the expressions on both sides of the equations and simplify to get:
$(x^2y+xy^2+2xyz+y^2z+yz^2+xz^2+2xyz)=24xyz$
$(x^2y-2xy^2-4xyz+2y^2z-4yz^2+8xyz-2xz^2)=10xyz$
By comparing the coefficients of the like terms, I would get the following system of equations:
$x^2y+xy^2+y^2z+xz^2=22xyz$
$x^2y-2xy^2+2y^2z-2xz^2=14xyz$
I would then solve this system of equations to get the values of x, y, and z. Once I have these values, I can substitute them in the expression $\dfrac{x}{y}+\dfrac{y}{z}+\dfrac{z}{x}$ to get the final answer.
In conclusion, to find the value of $\dfrac{x}{y}+\dfrac{y}{z}+\dfrac{z}{x}$ for the given equations, I would first manipulate the equations to get rid of the fractions and then solve the resulting system of equations to find the values of x, y, and z
FAQ: Solve x/y+y/z+z/x for Real Numbers with 24,10
What is the given equation?
The given equation is x/y + y/z + z/x = 24/10.
What are the real numbers?
The real numbers are all the numbers that can be found on the number line, including both positive and negative numbers, fractions, decimals, and irrational numbers.
How do I solve this equation?
To solve this equation, you can use algebraic techniques such as combining like terms, factoring, and solving for the unknown variables. You can also use the quadratic formula or the rational root theorem if necessary.
Are there any restrictions on the values of x, y, and z?
Yes, there are restrictions on the values of x, y, and z in this equation. Since division by zero is undefined, the denominators y and z cannot equal zero. Additionally, the variables must be real numbers, so they cannot be imaginary or complex numbers.
What is the solution to this equation?
The solution to this equation is not a single number, but rather a set of real numbers that satisfy the equation. This set of solutions can be represented in interval notation or as a graph on the number line.
