Solved: Velocity of Isolated System in Different Inertial Sys.
In summary, the conversation discusses the velocity of components in an isolated system in different inertial reference frames, specifically in the ##x## direction. The discussion includes the concept of relative velocity and whether there is a time in which the velocity of each component in the system is not less than ##v## in the ##x## direction. The conversation also touches on the conservation of momentum and the fact that velocity is not an invariant quantity. The conclusion is that if all components are at rest relative to each other, then they must all be moving at the same velocity in the other inertial reference frame.
liuxinhua
79
TL;DR Summary
A problem of an isolated system's velocity in different inertial systems, in special relativity
##\ \ \ \ \ ## In the inertial reference frame ##K##, the velocity of each component of an isolated system in ## x## direction is zero at a certain time.
##\ \ \ \ \ ## The inertial reference frame ##K'## moves to the right at velocity ##v## relative to the inertial reference frame ##K## in ## x## direction,
##\ \ \ \ \ ## In the inertial reference system ##K'##, whether there is such a time, at this time, the speed of each component of the isolated system is not less than ##v## in ## x## direction, and at least part of it is greater than ##v## in ## x## direction.
liuxinhua said:
In the inertial reference frame ##K##, the velocity of each component of an isolated system in ##x## direction is zero at a certain time.
So the "system" you are talking about has more than one component, and these components have different ##x## coordinates at the time you are talking about?
liuxinhua said:
The inertial reference frame ##K'## moves to the right at velocity ##v## relative to the inertial reference frame ##K## in ##x## direction
Ok.
If you don't know whether there is such a time, how can you say what happens at such a time?
liuxinhua said:
the speed of each component of the isolated system is not less than ##v## in ##x## direction, and at least part of it is greater than ##v## in ##x## direction.
Are you asking if this is true, or claiming that it is true? If you are asking, the answer is no, it isn't true, at least not necessarily (it could be in some cases, but from the information you have given it will not always be true). If you are claiming it, you are mistaken.
In any case, what's the point? Do you have a question?
I meet a problem.
##\ \ \ \ \ ####\ \ \ \ \ ##the "system" we are talking about has more than one component, and these components have different ## x## coordinates at the time we are talking about.
##\ \ \ \ \ ## The inertial reference frame ##K'## moves to the left at velocity ##v## relative to the inertial reference frame ##K## in ## x## direction. ##\ \ \ \ \ ##In the first floor, left is written as ##right##, which should be ##left ##.
##\ \ \ \ \ ## In the inertial reference system ##K'##, whether there is such a time, ##\ \ \ \ \ ## I find there exist a time,
##\ \ \ \ \ ## ## Result## :At some time, in the inertial reference system ##K'##, the velocity of each component of the isolated system is not less than ##v## in ## x## direction, and at least part of it is greater than ##v## in ## x## direction.
Velocity is not a conserved quantity.
For an isolated system, momentum is a conserved quantity.
But I always feel that this ##Result## should not exist.
I think, it is no different from the following:
##\ \ \ \ \ ## In the inertial reference frame ##K##, the velocity of each component of an isolated system in ## x## direction is zero at a certain time. All components of the system are in the same ##y-z## plane.
##\ \ \ \ \ ## This is relative to the inertial reference system ##K##.
But I really can't give a reason.
If all components are at rest relative to each other (in ##K##), then they must all be moving at ##v## in ##K'##. If you get something different you must be doing something wrong.
Velocity is never an invariant quantity:
##v' = v + V## (Newtonian)
##v' = \frac{v + V}{1 + vV/c^2}## (SR)
Where ##V## is the relative velocity between frames of reference.
Likes Ibix
@liuxinhua Is this what you meant?
If you have a system of equal mass particles, then in Newtonian physics conservation of momentum implies conservation of total velocity. Because the common mass cancels in conservation of momentum.
But, in SR, it is the total sum of ##\gamma_n v_n## that is conserved when you cancel the common mass.
liuxinhua said:
In the inertial reference system ##K'##, whether there is such a time, I find there exist a time,
"Whether there is such a time" and "I find there exist a time" contradict each other. I assume you mean the latter.
liuxinhua said:
At some time, in the inertial reference system ##K'##, the velocity of each component of the isolated system is not less than ##v## in ##x## direction, and at least part of it is greater than ##v## in ##x## direction.
As I said before, this "Result" is not correct--it does not follow from your previous statements.
liuxinhua said:
I always feel that this Result should not exist.
It doesn't. See above.
Having all components of the system in the same ##y-z## plane is an additional condition that you can choose to put into your scenario, over and above the first one. But it does not follow from the first one.
I'll state the whole problem tomorrow.
Let me rephrase the problem first.
##\ \ \ \ \ ## In the inertial reference frame ##K##, the velocity of each component of an isolated system in ## x## direction is zero at a certain time, the "system" has more than one component, and these components have different ## x## coordinates at the time.
##\ \ \ \ \ ##Is this possible? ## Result1## (call it as Result1):At some time, in the inertial reference system ##K'##, the velocity of each component of the isolated system is not less than ##v## in ## x## direction, and at least part of it is greater than ##v## in ## x## direction.
I feel that this ##Result1## should not exist.
But I have meet ##Result1##, so I ask you "Does the ##Result1## can exist?"
In the inertial reference frame ##K##, the velocity of each component of an isolated system in ## y## direction is different at the certain time,
Can you sure: the velocity of each component of the isolated system is not less than ##v## in ## x## direction, they must all be moving at ##v## in ##K'## in ## x## direction. (SR)
Or sure it maybe wrong.
I mean that this ##Result1## should not exist. But I have meet ##Result1##, so I ask you "Does the ##Result1## can exist?"
This is not required in the scenario, all components of the system is not in the same ##y-z## plane.
I only mean :
I think, there is no difference between the following two sentences:
##\ \ \ \ \ ## In the inertial reference frame ##K##, the velocity of each component of an isolated system in ## x## direction is zero at a certain time, the system’s components have different ## x## coordinates at the time.
##\ \ \ \ \ ## In the inertial reference frame ##K##, the velocity of each component of an isolated system in ## x## direction is zero at a certain time, all components of the system are in the same ##y-z## plane at this time.
That's why I think ## Result1## shouldn’t exist. Of course, that's not a good reason.
Does anyone have reason to say that ## Result1## cannot exist.
This makes no sense. Why would part of the system have velocity greater than ##v## and part less than ##v##?
What calculations led you to that conclusion?
May be related to
In other words, up to now you've just been wasting our time with an incomplete description of whatever it is you're asking about? Then this thread is closed.
Likes weirdoguy
Related to Solved: Velocity of Isolated System in Different Inertial Sys.
1. What is an isolated system?
An isolated system is a physical system that does not interact with its surroundings in any way. This means that there are no external forces acting on the system and no energy is exchanged with the surroundings. In other words, the total momentum and energy of the system remain constant.
2. How is velocity calculated in an isolated system?
In an isolated system, the total momentum remains constant. This means that the initial momentum of the system is equal to the final momentum. Velocity is calculated by dividing the total momentum by the total mass of the system.
3. What is an inertial frame of reference?
An inertial frame of reference is a coordinate system in which Newton's laws of motion are valid. In other words, an object in an inertial frame will remain at rest or in uniform motion unless acted upon by an external force.
4. How does the velocity of an isolated system change in different inertial frames?
The velocity of an isolated system remains constant in all inertial frames. This is because the total momentum of the system remains constant, regardless of the frame of reference used to measure it.
5. Can the velocity of an isolated system be greater than the speed of light?
No, the velocity of an isolated system cannot exceed the speed of light. According to Einstein's theory of relativity, the speed of light is the maximum speed at which any object can travel. This applies to all inertial frames of reference, including isolated systems.
