Solvent Effects on Carbazole-Based Hole Transporting Materials
The discussion centers on the effects of solvents on the optical properties of carbazole-based hole transporting materials. The researcher is using toluene, chlorobenzene, and dichloromethane to dissolve these materials and seeks advice on additional reactions to consider and the most suitable solvent for dissolving these organic compounds. Responses suggest consulting scholarly research papers or a specialist for detailed insights, as the inquiry lacks specificity regarding the definition of "optical properties." There is an emphasis on the need for clarity in the research question to obtain more targeted assistance.
EL AALLAOUI Najla
Hello everybody ,
In my research study, i am focusing the interprete the effect of solvent on opticals propertie of carbazole based hole transporting materials ,In order to dissolve this materials in different Concentration of solvents ; I have been using Toluene , chlorobenzene and dichloromethane . Is there any further reactions that I should take note and Which solvent that is suitable the most in dissolving this organic compounds ithat I mentioned earlier?
Thank you for your helps .
Chemistry news on Phys.org
The answer to this sort of question is most likely to be found in scholarly research papers. You need a specialist for this sort of question. Even google scholar is much more likely to turn up more useful information. Or ask your supervisor.
The question is so vague that there's no way to answer this. What specifically do you mean by "optical properties"?
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
