MHB Solving 0x10 + 0xfe: What's the Answer?
  • Thread starter Thread starter Amathproblem22
In this discussion, the focus is on performing arithmetic with 8-bit unsigned values in hexadecimal format. The initial question involves calculating the sum of 0x10 and 0xFE. The correct answer is identified as 0x0E, which equals decimal 14. The conversation clarifies that hexadecimal numbers use the prefix 0x and operate in base 16, where values range from 0 to 255 for 8-bit unsigned integers. The concept of overflow is emphasized, explaining that when the sum exceeds the maximum value of 255, it wraps around rather than resetting to zero. Examples are provided to illustrate how calculations differ between 8-bit and 16-bit systems, highlighting the importance of understanding overflow in hexadecimal arithmetic.
Amathproblem22
Question: With 8-bit unsigned values, 0x10 + 0xfe =
Answer: 0x0e, which is decimal 14.What I know;
The prefix 0x is used in code to indicate that the number is being written in hex. Base 16.
I also am aware that with 8-bit unsigned values it goes from a range of 0 to 255.
Need help with:
Is this working? 10+f = (10+15, the base system is 16 so this is bigger so resets?) 0?
0+e(14)=14, meaning 0x0e I have probably done the working wrong so that's why I need help. Thanks.
Technology news on Phys.org
Hint: if you use 16bit -
1) 0x10 + 0xfe = 0x10e
2) 0x20 + 0xfe = 0x11e
And in 8 bit:
1) 0x10 + 0xfe = 0x0e
2) 0x20 + 0xfe = 0x1e
So it is more about overflow than reset.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
