Solving 2u^2 cos2B/g=0 for B: A Marking Scheme Explained
  • MHB
  • Thread starter markosheehan
In summary, the conversation discusses the equation 2u^2 cos2B/g=0 and the variable being solved for, which is B. The purpose of solving this equation is to find the value of B that satisfies the equation and demonstrate an understanding of the marking scheme. The steps involved in solving this equation include simplifying it, isolating B, and using trigonometric identities to find solutions. Some common mistakes to avoid when solving this equation are not applying trigonometric identities, incorrect isolation of B, and not considering all possible solutions.
Mathematics news on Phys.org
i was just confused on how they got B=45 degrees.
Hello,
I am happy to help explain how the solution for B=45 degrees was obtained.
In this question, we are given the equation 2u^2 cos2B/g=0 and asked to solve for B. To do this, we first need to understand the properties of cosine and how it relates to the value of an angle.
Cosine is a trigonometric function that relates the ratio of the adjacent side to the hypotenuse of a right triangle. In this case, we can rewrite the given equation as cos2B=0. This means that the cosine of 2B is equal to 0.
Now, we know that the cosine of an angle is equal to 0 when that angle is 90 degrees or π/2 radians. This is because at 90 degrees, the adjacent side of a right triangle is equal to 0, making the ratio 0/hypotenuse=0. Similarly, at 270 degrees or 3π/2 radians, the cosine is also equal to 0.
Since we are looking for the value of B, we need to solve for 2B. To do this, we can divide both sides of the equation by 2, giving us B=45 degrees or π/4 radians. This is because 2B=90 degrees or π/2 radians when B=45 degrees or π/4 radians.
I hope this explanation helps you understand how the solution for B=45 degrees was obtained. Please let me know if you have any further questions. Good luck with your studies!
FAQ: Solving 2u^2 cos2B/g=0 for B: A Marking Scheme Explained
What is the equation being solved?
The equation being solved is 2u^2 cos2B/g=0 for B.
What is the variable being solved for?
The variable being solved for is B.
What is the purpose of solving this equation?
The purpose of solving this equation is to find the value of B that satisfies the equation and to demonstrate an understanding of the marking scheme for this type of problem.
What are the steps involved in solving this equation?
The steps involved in solving this equation include simplifying the equation, isolating the variable B, and using trigonometric identities to find the solutions.
What are the common mistakes to avoid when solving this equation?
Some common mistakes to avoid when solving this equation include forgetting to apply the trigonometric identities, not isolating the variable B correctly, and not considering all possible solutions.
