Solving (A+B)^-1: Is A^-1+ B^-1 the Answer?
  • MHB
  • Thread starter roscany
In summary, the statement that $(A+B)^{-1}=A^{-1}+B^{-1}$ is only true if and only if $B^{-1}=-(I + A^{-1}B)^{-1} A^{-1} B A^{-1}$ and this is not always the case. It is important to note that this is only true if $A$, $B$, and $A+B$ are all invertible.
roscany
Does (A+B)^-1= A^-1+ B^-1?
Thanks!
Thanks!
Hi roscany,
Suppose we pick A = B = I, what do you get then?
Assume $A$, $B$, and $A+B$ are invertible, otherwise the inverse would not exist. Let $(A+B)^{-1}=A^{-1}+X$, where $X$ is to be determined.
Multiply both sides by $A+B$:
$I=(A^{-1}+X)(A+B)$
$I=A^{-1}A+A^{-1}B+XA+XB$
$I=A^{-1}B+X(A+B)$
$X(A+B)=-A^{-1}B$
$X=(-A^{-1}B)(A+B)^{-1}$
Recall from above:
$X=(-A^{-1}B)(A^{-1}+X)$
Isolating for $X$...
$X= - (I + A^{-1}B)^{-1} A^{-1} B A^{-1}$
$(A+B)^{-1}=A^{-1}-(I + A^{-1}B)^{-1} A^{-1} B A^{-1}$
Therefore, the original statement is not true in general.
$I=(A^{-1}+X)(A+B)$
$I=A^{-1}B+X(A+B)$
$X(A+B)=-A^{-1}B$
Recall from above:
Wait. (Wait)
Are you saying that $B^{-1}$ does not have to be equal to $-(I + A^{-1}B)^{-1} A^{-1} B A^{-1}$?
Why would that be the case? (Wondering)
I like Serena said:
Wait. (Wait)
I am saying that in general,
Now, the OP's statement that $(A+B)^{-1}=A^{-1}+B^{-1}$ is true if and only if $B^{-1}=-(I + A^{-1}B)^{-1} A^{-1} B A^{-1}$. Since you were able to point out a counter-example, clearly the RHS cannot be simplified to $B^{-1}$.
FAQ: Solving (A+B)^-1: Is A^-1+ B^-1 the Answer?
What is the meaning of (A+B)^-1?
The expression (A+B)^-1 is a mathematical operation known as the inverse of the sum. It is used to find the inverse of a sum of two or more matrices.
What is the importance of finding the inverse of a matrix?
Finding the inverse of a matrix is important in various areas of mathematics and science, such as linear algebra, statistics, and physics. It allows us to solve systems of linear equations, perform matrix operations, and calculate probabilities, among other things.
Is A^-1+ B^-1 the same as (A+B)^-1?
No, A^-1+ B^-1 is not the same as (A+B)^-1. While they both involve finding the inverse of matrices, the former is the sum of two individual inverse matrices, while the latter is the inverse of the sum of two matrices.
How do you solve (A+B)^-1?
To solve (A+B)^-1, you can use the following formula: (A+B)^-1 = A^-1 + B^-1 - (A^-1 x B x A^-1) / (1 + B x A^-1). Alternatively, you can use an online calculator or a software program to compute the inverse of the sum of two matrices.
What are some applications of solving (A+B)^-1?
The inverse of the sum operation has various applications, including solving systems of linear equations, finding the coefficients of a polynomial, calculating the probabilities of independent events, and performing transformations in physics and engineering problems.
