scarecrow425
- 1
using kirchhoff's rules, determine the current through and voltage drop across each resistor in the accompanying figure.
V=IR, potential voltage ( voltage drop )= current * resistance
Voltage in series Vt=V1 + V2 + V3...
Current in series It = I1 = I2 = I3...
Resistance in series Rt= R1 + R2 + R3...
Voltage in parallel Vt= V1 + V2 + V3..
Current in parallel It = I1+ I2 + I3..
Resistance in parallel 1/Rt= 1/R1 + 1/R2...
these are the equations we've been using in class
i wasnt sure how to start this problem since i don't have any similar examples to look at. but what i did was add the two voltages of the batteries to get a total of 25 V. i also assumed that resistors 2 and 3 were in parallel, and together were in series with resistor 1. making the total resistance 10. ( 1/6 + 1/3 = 3/6 ; 1/(3/6) = 2 ; 8+2 = 10) so that gave me a current of 2.5. so i got the current through R1 to be 2.5 amps, thecurrent through R2 to be .833 and the current through R3 to be 1.67.
the voltage drop across R1 to be 20 V (2.5 amp * 8 ohms), across R2 to be 5 and across R3 to be 5
im pretty sure i didnt do it right but I am not sure how i should set up the problem. in class our teacher gave us an example like this one with two batteries. but i got confused when he was drawing the arrows for the direction of the current. he drew current flowing from A to B, but also from B to A. i tried to figure it out doing that but it seems too complicated. i always end up with current flowing into a battery through the wrong end. can someone please show me how to set it up correctly? thanks
