Solving a Difficult DE with TI-NSPIRE: Is it True?
  • MHB
  • Thread starter karush
In summary, a solution to the differential equation ${a}^{2}{u}_{xx}={u}_{t}$ is given by $u=\left(\pi/t\right)^{1/2}e^{{-x^2 }/{4a^2 t}}, \ \ t>0$. However, the TI-Nspire returned a complicated answer for $u_{xx}$ and it does not seem to be true for the given differential equation. The derivative $u_t$ was also different and complicated, leading to the conclusion that the differential equation is not true.
karush
MHB
3,269
Given
$${a}^{2}{u}_{xx}={u}_{t}$$
Is
$$u=\left(\pi/t\right)^{1/2}e^{{-x^2 }/{4a^2 t}}, \ \ t>0 $$
A solution to the differential equation
$${u}_{xx }$$
Was kinda hard to get, the TI-NSPIRE returned a very complicated answer
and it doesn't look like the differential equation is true
karush said:
Given
Is
$${u}_{xx }$$
Well if $\displaystyle \begin{align*} u = \left( \pi\,t \right) ^{\frac{1}{2}}\,\mathrm{e}^{-\frac{x^2}{4\,a^2\,t}} \end{align*}$? then what is $\displaystyle \begin{align*} u_t \end{align*}$? What is $\displaystyle \begin{align*} u_{x\,x} \end{align*}$? Is the DE true in this case?
$${u}_{xx}=\d{^2 }{x^2 }\left(u\right)=
\left(\frac{{x}^{2}\sqrt{\frac{\pi}{t}}}{4 a^4 t^2 }
-\frac{\sqrt{\frac{\pi}{t}}}{2{a}^{2}t} \right)
\cdot e^{\frac{x^2 }{4{a}^{2}t}}$$
This is what the TI-Nspire returned for $U_{xx}$
$u_t$ looked more complicated and was very different so assume DE is not true
I like to see how these derivatives were derived but that a ton of latex
FAQ: Solving a Difficult DE with TI-NSPIRE: Is it True?
What is a difficult DE?
A difficult DE, or differential equation, is an equation that involves a function and its derivatives. These equations can be challenging to solve because they often involve complex mathematical operations and require advanced problem-solving skills.
Can a TI-NSPIRE calculator solve difficult DEs?
Yes, a TI-NSPIRE calculator has the ability to solve difficult DEs using its built-in Differential Equations Solver. This allows users to input the DE and the initial conditions, and the calculator will provide a solution in the form of a graph or a function.
How accurate are the solutions obtained from TI-NSPIRE?
The solutions obtained from TI-NSPIRE are typically very accurate. However, it is important to note that these solutions are approximations and may not be exact. It is always recommended to double-check the solution using other methods or software.
Is it necessary to have prior knowledge of differential equations to use TI-NSPIRE?
While having prior knowledge of differential equations can be helpful, it is not necessary to use TI-NSPIRE. The calculator has a user-friendly interface and provides step-by-step instructions on how to input the DE and initial conditions. However, a basic understanding of calculus and functions is beneficial.
Can TI-NSPIRE solve all types of differential equations?
No, TI-NSPIRE may not be able to solve all types of differential equations. It is limited to first-order and second-order DEs with constant coefficients. It may also struggle with more complex DEs that involve multiple variables or non-constant coefficients. In these cases, it is best to consult a mathematician or use other software.
