Solving a First Order Linear Differential Equation with an Initial Condition
  • MHB
  • Thread starter Cadbury
  • Tags
    Point
In summary, the conversation discusses solving a problem that involves finding a solution passing through a given point. The individual tried to substitute variables and reduce the equation, but was unable to solve it. They then mention using an initial condition to solve the equation and provide the necessary steps to do so.
Cadbury
Hi! So I am solving this problem:
Find the solution that passes through (1,2)
First I tried substituting
x= u+1
y= v+2
dx = du
dy = dv to the equation but I cannot find the solution any help will be appreciated, thank you! :D
Note $2yy' = (y^2)'$, so by setting $u = y^2$, you may reduce your differential equation to the first order linear equation $xu' = u - 2x^3$, or
$$xu' - u = -2x^3.$$
Since you're looking for the solution that passes through $(1,2)$, you have an initial condition $y(1) = 2$. This translates to $u(1) = 4$, since $u = y^2$. Now solve the IVP
$$xu' - u = -2x^3,\quad u(1) = 4.$$
Thank you! :) :) :)
FAQ: Solving a First Order Linear Differential Equation with an Initial Condition
1. What does it mean for a line to "pass through a given point"?
For a line to pass through a given point, it means that the point lies on the line and is a part of the line. In other words, the coordinates of the given point satisfy the equation of the line.
2. Can a line pass through more than one given point?
Yes, a line can pass through multiple given points. As long as the coordinates of the points satisfy the equation of the line, they are all considered to be on the line.
3. What is the equation for a line that passes through a given point?
The general equation for a line is y = mx + b, where m is the slope and b is the y-intercept. To find the equation for a line that passes through a given point, substitute the coordinates of the point for x and y in the equation and solve for m and b.
4. Is it possible for a line to pass through a given point without intersecting other lines?
Yes, it is possible for a line to pass through a given point without intersecting other lines. This can happen when the given point is on a parallel line or on an extension of a line.
5. How do I determine if a line passes through a given point?
To determine if a line passes through a given point, substitute the coordinates of the point into the equation of the line. If the equation is true, then the line passes through the given point. If the equation is false, then the line does not pass through the given point.
