Solving a Heat Equation with $\sin \pi x$
In summary, the conversation discusses how to solve a specific type of heat equation with a source term $\sin \pi x$. The suggested solution is to transform the PDE to another form without the source term and then find the appropriate coefficient to cancel it out. The full solution involves differentiating and solving for the coefficients $a(t)$ and $b(t)$, which can be easily solved.
madflame991
Hi!
I need to find out how to solve this type of heat equations:
$$\large \frac{du}{dt} - \frac{d^2u}{dx^2} = \sin \pi x$$
$$\large u|_{t=0} = \sin 2\pi x $$
$$\large \large u|_{x=0} = u|_{x=1} = 0$$
I know what the solution to this but I can't solve it myself.
The problem is that all over the net I stumble upon heat equations of only this form:
$$ \large \frac{du}{dt} = k \frac{d^2u}{dx^2}$$
And I can't figure out what am I supposed to do with $\sin \pi x$
Thx!
The idea here is try and transform your PDE to another PDE without the source term ($\sin \pi x$) and yet retain the BC.s If you try a tranformation of the form
$u = v + a \sin \pi x$
you'll notice that $u(0,t) = 0$ and $u(1,t) = 0$ remain unchanged i.e. $v(0,t) = 0$ and $v(1,t) = 0$. Now find $a$ such that the source term cancels.
Thanks for answering. Now I'm going to post the full solution; who knows, someone else might benefit from it.
Note that the procedure below might only work only if we're dealing with $sin$ or $cos$
The solution will be of this form (I do not know from where were you supposed to come up with this form)
$$u(x,t) = a(t) sin \pi x + b(t) sin 2 \pi x$$
Having this in mind we now only differentiate
$$a'(t) sin \pi x + a(t) \pi^2 sin \pi x + b'(t) sin 2 \pi x + b(t) 4 \pi ^2 sin 2 \pi x = sin \pi x$$
From this we come up with this:
\begin{cases}
a'(t) + \pi^2a(t) = 1 \\
a(0) = 0
\end{cases}
and
\begin{cases}
b'(t) + 4\pi^2b(t) = 0 \\
b(0) = 1
\end{cases}
Which are pretty easy to solve.
FAQ: Solving a Heat Equation with $\sin \pi x$
What is a heat equation?
A heat equation is a mathematical equation that describes how heat is distributed in a given system over time. It takes into account factors such as temperature, heat transfer, and heat sources or sinks.
How is the heat equation solved using $\sin \pi x$?
The heat equation can be solved using the method of separation of variables, where the solution is expressed as a product of two functions: one that depends on time and one that depends on space. $\sin \pi x$ is one of the possible solutions for the spatial function, satisfying the boundary conditions of the system.
What are the applications of solving a heat equation with $\sin \pi x$?
The heat equation is used in various fields such as physics, engineering, and mathematics to understand heat distribution in different systems. Solving it with $\sin \pi x$ allows for the prediction and analysis of heat distribution in systems with periodic boundaries, such as a circular rod or a square plate.
Are there any limitations to using $\sin \pi x$ to solve the heat equation?
Using $\sin \pi x$ to solve the heat equation is limited to systems with periodic boundaries and constant heat sources or sinks. It may not accurately represent the behavior of heat in systems with irregular boundaries or varying heat sources.
How does solving the heat equation with $\sin \pi x$ contribute to scientific research?
Solving the heat equation with $\sin \pi x$ provides a mathematical model for understanding and predicting heat distribution in various systems. This can aid in the design and optimization of heat transfer processes in engineering applications, as well as in the study of thermal behavior in physical systems.
