Solving a Jet Speed Problem: Tokyo to Bangkok Distance and Time
  • Thread starter supernova1203
  • Tags
    Word problem
In summary, the conversation discusses a problem where a jet flies from Tokyo to Bangkok, and then back to Tokyo. The distance is 4800 km and on the return trip, the speed is decreased by 200 km/h. The difference in the times of the flights is 2 hours. The conversation goes on to discuss various equations and attempts at solving the problem, ultimately arriving at the correct equation: 4800/(x-2) - 4800/x = 200 km/h, where x represents the time in hours. The conversation also includes a discussion about learning LaTex and resources for doing so.
supernova1203
210
A jet flew from Tokyo to Bangkok, a distance of 4800 km. On the return trip, the speed was decreased by 200km/h. If the difference in the times of the flights was 2 hours, what was the jet's speed from Bangkok to Tokyo?
Distance=(speed)(time)
Time=Distance/Speed
Speed=Distance/Time
On sample questions they showed us how to solve a problem like this, i attempted to solve it in a similar manner however as you will see i was unable to
Let x represent speed
D=4800 Speed=? Time =?
Distance Speed Time
A to B 4800 x 4800/x (since time = d/s)
Tokyo
to Bangkok
B to A 4800 (x-200) 4800/(x-200)
Bangkok Since on return
to Tokyo trip speed was
reduced by 200
Time -2
4800/x +4800/(x-200)=-2
Lowest common denominator = x(x-200)
Here we multiply everything by x(x-200)
4800/x*x(x-200)+4800/(x-200)*x(x-200)=-2x(x-200)
Here some of the variable cancel out and the calculations are made and we are left
with the end result which is
4800x-960000+4800x=-2x(x-200)
4800x-960000+4800x=-2x^2+400x (On next step the 2x^2 and the right side is moved to
2x^2-400x+4800x-960000+4800x=0 the left side, hence the change in signs)
2x^2-400x+4800x+4800x-960000=0
Basically at this point my calculations got sketchy because there were several ways of going about this problem at this point, also I believe i had made some errors early in my calculations.
Sorry if it isn't very coherent i did my best to make it so, but I just got LaTex(Tex) and i didnt have the time to learn it just yet, also ms word won't let me paste the equations as they are here without altering them.
Thanks in advance and for bearing with me @_@
Time=Distance/Speed
Speed=Distance/Time
Distance Speed Time
Tokyo
to Bangkok
reduced by 200
Time -2
I think this line is wrong. What you're after is 4800/x-200 - 4800/x = 2, as the slower speed takes 2 hours longer, where x here is the time. Can you solve this equation?
Or if it helps you understand it better in terms of writing it out in the difference from the base case, you could arbitrarily say that 4800=v*t. Then 4800=(v-200)*(t+2) to take into account both the slower speed and longer duration. You can then substitute, reduce, and use the ratio t=4800/v to solve for v (quadratic would have two answers, only one makes sense since you're dealing with positive distance).
Hm... i believe that makes sense, i recall them solving a similar problem previously this way, Thanks!
Almost...
4800 represents distance in km.
So, if x is time (in hours) then 4800/x would represent km/hr.
Therefore, you are finding the difference between 2 velocities, which we know is 200 km/hr.
The correct equation is:
[tex]\frac{4800}{x - 2} - \frac{4800}{x} = 200~km/hr[/tex]
zgozvrm said:
Almost...
You are, of course, right. Or change the word time for speed in my answer ;)
zgozvrm said:
Almost...
Is there a resource from where i can learn LaTex? I got it i just have no clue as to how to start and where to begin? I use ms word for most of the work but if i copy paste, the format changes... @_@
I thought there was a tutorial here, but I can't seem to find it.
Otherwise, try Google!
(Also, you can click the "Quote" button on a post that has LaTex to see how it was entered).
For many examples, see the PF sticky here:
https://www.physicsforums.com/showthread.php?t=8997
Thanks a bunch! I have a feeling ill end up needing it eventually :)
Related to Solving a Jet Speed Problem: Tokyo to Bangkok Distance and Time
1. What is the distance between Tokyo and Bangkok?
The distance between Tokyo and Bangkok is approximately 2,500 miles.
2. What is the average flight time from Tokyo to Bangkok?
The average flight time from Tokyo to Bangkok is around 7-8 hours.
3. How is the jet speed problem solved for this distance?
The jet speed problem can be solved by using the formula Distance = Speed x Time. In this case, the distance is 2,500 miles and the time is 7-8 hours, so the speed would be calculated as 2,500 miles / 7-8 hours = 312.5 - 357.1 miles per hour.
4. What factors affect the jet speed for this route?
The jet speed for this route can be affected by various factors such as wind speed, air traffic, and the type of aircraft being used.
5. How does the jet speed problem impact the efficiency of air travel?
The jet speed problem is an important consideration in air travel as it directly affects the time and cost of flights. By solving this problem, airlines can optimize their routes and schedules for better efficiency.
