MHB Solving a Logic Proof: Existential Hypothesis Rule
  • Thread starter Thread starter Fumbles22
    Logic Proof
The discussion centers on the challenges of applying the Existential Hypothesis (EH) rule in logic proofs, particularly when the variable v does not occur freely in certain formulas. Two proofs are presented, with the first proof being favored for its correctness, although concerns are raised about line 10's validity. The EH rule's restrictions are emphasized, noting that v can only occur freely in specific subderivations. Participants clarify the implications of free and bound variables in the context of the proofs, highlighting the complexity of the EH rule compared to others. The conversation concludes with a lighthearted remark about terminology confusion in logic.
Fumbles22
This question is really getting on my nerves. It's 6i) from here:
Right off the bat, it looks like they've thrown me a curveball. The fact that v does not occur free in \psi means that the Existential Hypothesis rule is going to need some care when applied.
I've come up with two possible proofs:
..each in a different colour.
To me, the top proof looks more correct than the bottom. It's just the Existential Hypothesis rule that's throwing me.
For the first proof, I think line 10 is wrong. I need the existential hypothesis rule to depend on all the assumptions where v is free. This happens in lines 1,2 and MAYBE 3. If v is a free variable in line 3, then I'm sorted and everything is right. If it isn't, then I have a problem on my hands.
There's a similar problem for the second proof too.
Useful things:
The far left number show the assumptions a line depends on. The bracketed number is the line number and the far right column is the rules column.
As s = Assumption
UE = Universal Eradicator
Taut = Tautology
CP = Conditional Proposition
EH= Existential Hypothesis
Thanks in advance
I think both proofs are fine. In the first proof, you just do some propositional reasoning, namely, deriving $\neg\psi$ from $\phi$ and $\neg\phi\leftrightarrow\psi$. In the second proof, this subderivation is contracted into one step because you can do arbitrary propositional reasoning in one step.
The restriction on EH, which derives some $\chi$ from $\exists v\,\theta$ and a subderivation of $\chi$ from $\theta$, is that $v$ can occur freely only in $\theta$: it cannot occur freely in $\chi$ nor in other open assumptions of $\chi$ except $\theta$. In your case, $\neg\psi$ has open assumptions $\forall x\,\phi$ and $\neg\phi\leftrightarrow\psi$. The variable $v$ occurs freely in $\neg\phi\leftrightarrow\psi$ but not in $\forall x\,\phi$ or $\neg\psi$. Therefore, the application of EH is justified.
Note that in natural deduction, inference rules come in pairs for every connective. For every connective *, there is *-introduction, whose conclusion has * as the top-level connective, and *-elimination, where one of the premises has * as the top-level connective. So the standard names for UE and EH are universal elimination and existential elimination, respectively. Universal Eradication sounds pretty radical! :)
Why is it that v occurs freely in ?
We know that v is bound in \(\psi\), so how do we know it's free here? \(\neg\phi\leftrightarrow\psi\)
fumbles said:
Why is it that v occurs freely in $\neg\phi\leftrightarrow\psi$?
Strictly speaking, v may not be free in that formula. When I said,
I was describing a typical case. If v occur free neither in $\phi$ nor in $\psi$, then this derivation reduces to propositional reasoning. But if v occurs free in $\phi$, then it also does in $\neg\phi\leftrightarrow\psi$. The point is that EH allows v to occur free in that formula, but not in $\neg\psi$ or other open assumptions of $\neg\psi$.
I think I get it. The Existential Hypothesis rule is quite hard compared to the others.
When I was reading the page, I accidentally read "elimination" as "eradication". Since I was in learning mode, I remembered it as eradication. When I was writing the post I was thinking "it's elimination, not eradication" but then completely forgot at the key moment.
I've finally finished the sheet, which is why I'm a bit late posting this. On to Quantum Phenomena!
Thanks for your help emakarov!
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
