Solving a PDE in four variables without separation of variables
In summary, the conversation discusses the equation for the dynamics of a variable K within a cylinder with specific length, radius, and angular range. The speaker needs to solve this equation subject to certain boundary conditions, but does not want to use separation of variables. They mention that partial differential equations can be very complicated and suggest finding a Green's function or making a smart ansatz as possible approaches.
highflyyer
28
Within a cylinder with length ##\tau \in [0,2\pi]##, radius ##\rho \in [0,1]## and angular range ##\phi \in [0,2\pi]##, we have the following equation for the dynamics of a variable ##K##:
$$\left( - \frac{1}{\cosh^{2} \rho}\frac{\partial^{2}}{\partial\tau^{2}} + (\tanh\rho + \coth\rho)\frac{\partial}{\partial\rho} + \frac{\partial^{2}}{\partial\rho^{2}} + \frac{1}{\sinh^{2} \rho}\frac{\partial^{2}}{\partial\phi^{2}} - m^{2} \right) K = \frac{\partial K}{\partial u}.$$
Here, ##u### is the time variable. I need to solve this differential equation subject to the boundary conditions
$$K(\tau = 0) = K(\tau = 2\pi) = 0$$
$$K(r = 1) = 0$$
$$K(\phi=0) = K(\phi=2\pi)$$
$$K(u = \infty) = 0$$
The first two boundary conditions simply state that the variable ##K## vanishes at the boundary of the cylinder, the third boundary condition is simply a periodic boundary condition on the angular coordinate and the final condition simply states that the variable ##K## must vanish at late times.
How do I solve this differential equation analytically without using separation of variables?
Can you give a bit more context, please? Is that a physics problem? And why would you not want to separate variables?
Likes highflyyer
This is, in fact, a physics problem. The physics is that the cylinder is a radially cut-off (at radius ##\rho=1##) anti-de sitter cylinder in global coordinates.
Please ignore the following (in italics) if you are not interested. This is just motivation and is just some dense physics that's of little use to solving the differential equation above :
I am solving for the heat kernel ##K## taking inspiration from section 1.1 of the paper https://arxiv.org/abs/0804.1773.
As stated in that paper, the computation of the one-loop correction in equation (1.9) requires a computation of the spectrum ##\lambda_{n}##. The computation of the spectrum can be circumvented if we solve equation (1.11) for the heat kernel and plug it into the equation just above equation (1.11). Using separation of variables is just going to lead us back to equation (1.9) and defeat the purpose of using the heat kernel approach.
What I am looking for is some means of solving the differential equation analytically without separation of variables. That's all. Please do not let the abstruse physics that I wrote in this post deter you from adding any useful hints to solving the very simple differential equation above.
Thanks in advance for any useful comments. :)
highflyyer said:
What I am looking is some means of solving the differential equation analytically without separation of variables. That's all.
Then all I can tell you is this: Partial differential equations are really complicated. As a general rule, many of the most common PDE's (Schrödinger, Boltzmann, Laplace, Einstein, Navier-Stokes...) have entire books written on the solution of just this particular PDE and still in most cases you have to use numerical methods. If you have a good intuition about the physics of the system you can make a smart ansatz that maybe solves the PDE. Sometimes you can do a Greens function that just leaves you with a complicated integral. But you need to find the Greens function for this particular PDE.
Likes highflyyer
If Green's function analysis just leaves a complicated integral, I'd rather skip that approach.
Is there any way this equation looks similar to one of the many PDEs that's already been solved?
Related to Solving a PDE in four variables without separation of variables
1. How do you solve a PDE in four variables without separation of variables?
Solving a PDE in four variables without separation of variables requires the use of advanced techniques such as the method of characteristics, Green's functions, or numerical methods. These techniques involve transforming the PDE into a system of ordinary differential equations and then using specific algorithms to find a solution.
2. Can you give an example of a PDE in four variables that cannot be solved using separation of variables?
Yes, the wave equation in four variables is an example of a PDE that cannot be solved using separation of variables. This is because the wave equation involves two time variables, making it impossible to separate the variables to solve for each one individually.
3. What is the advantage of solving a PDE in four variables without separation of variables?
Solving a PDE in four variables without separation of variables allows for a more general solution, as separation of variables is only applicable to certain types of PDEs. This approach also allows for the inclusion of more complex boundary conditions and initial conditions, making it more applicable to real-world problems.
4. What are some common challenges when solving a PDE in four variables without separation of variables?
One common challenge is the complexity of the equations involved, which often require advanced mathematical techniques and numerical methods. Another challenge is the need for a thorough understanding of the problem and the PDE in order to choose the most appropriate approach for solving it.
5. Are there any real-world applications for solving a PDE in four variables without separation of variables?
Yes, there are many real-world applications for solving PDEs in four variables without separation of variables. Some examples include modeling fluid dynamics, heat transfer, and electromagnetic fields in complex systems such as aircrafts, vehicles, and electronic devices. This approach is also used in economic and financial modeling, as well as in the study of biological systems.
  • Differential Equations
