Graduate Solving a power series
The discussion focuses on calculating the sum of the power series ∑(x^n)/(2n+1) and determining its radius of convergence. The radius of convergence, R, is found to be 1 using the ratio test, confirming that the series converges for |x| < 1. Participants suggest techniques for finding the sum, including relating the series to the arctanh function and employing differentiation to derive a differential equation. The conversation emphasizes the importance of manipulating the series and exploring textbook methods for summation. Overall, the series converges within the specified interval, and further techniques can be applied to find its sum.
ILY
The question was: calculate the following sum within its open interval of convergence after determining the radius of convergence:
##\sum_{n=0}^{+\infty} \frac{x^n}{2n+1}##
##\textbf{Finding the radius of convergence:}##
I believe I followed the correct steps, but I got stuck solving it. Here's what I've done so far:
We use the ratio test to determine the radius of convergence. The formula for the radius of convergence, R, is:
##\frac{1}{R} = \lim_{n \to \infty} \left| \frac{a_{n+1}}{a_n} \right|##
In this case, the general term ##a_n = \frac{x^n}{2n+1}##. Applying the ratio test:
##\frac{1}{R} = \lim_{n \to \infty} \left| \frac{\frac{x^{n+1}}{2(n+1)+1}}{\frac{x^n}{2n+1}} \right|##
Simplifying:
##\frac{1}{R} = \lim_{n \to \infty} \left| \frac{x^{n+1}(2n+1)}{(2n+3)x^n} \right|##
##\frac{1}{R} = \lim_{n \to \infty} \left| \frac{x(2n+1)}{2n+3} \right|##
Now, as ##n \to \infty##, ##\frac{2n+1}{2n+3} \to 1##. Therefore:
##\frac{1}{R} = |x| \cdot 1 = |x|##
Thus, the series converges when |x| < 1, and the radius of convergence is R = 1.
I think this is correct, but I got stuck while solving it. If anyone could help me, it would be greatly appreciated!
Fixed all of your LaTeX, which was technically correct but used incorrect delimiters. Here at PF the delimiters are ##, for inline LaTeX, and $$, for standalone LaTeX. See the LaTeX Guide at the link in the lower left corner of this pane.
I don't see anything wrong in the work you show.
By "solving it," I presume you mean finding the sum of the series. What are some of the techniques shown in your textbook for finding the sum of a convergent power series? Your textbook might have some examples.
Consider <br /> \operatorname{arctanh}(x) = \sum_{n=0}^\infty \frac{x^{2n+1}}{2n+1}, \quad |x| &lt; 1. Now you just have to manipulate the power so that it is n rather than 2n+1. Can you see how to do that? I would start with 0 \leq x &lt; 1, and then try ot extend the result to -1 &lt; x &lt; 0.
Alternatively, if <br /> f(x) = \sum_{n=0}^\infty \frac{x^n}{2n+1} then <br /> f&#039;(x) = \sum_{n=0}^\infty \frac{nx^{n-1}}{2n+1} so that <br /> 2xf&#039;(x) + f(x) = \sum_{n=0}^\infty x^n = \frac{1}{1 - x} is a differential equation which can be solved for f subject to f(0) = 1.
There are probably loads of proofs of this online, but I do not want to cheat. Here is my attempt: Convexity says that $$f(\lambda a + (1-\lambda)b) \leq \lambda f(a) + (1-\lambda) f(b)$$ $$f(b + \lambda(a-b)) \leq f(b) + \lambda (f(a) - f(b))$$ We know from the intermediate value theorem that there exists a ##c \in (b,a)## such that $$\frac{f(a) - f(b)}{a-b} = f'(c).$$ Hence $$f(b + \lambda(a-b)) \leq f(b) + \lambda (a - b) f'(c))$$ $$\frac{f(b + \lambda(a-b)) - f(b)}{\lambda(a-b)}...
  • · Replies 19 ·
  • · Replies 17 ·
