Solving a Quadratic Equation with Two Variables
In summary, the equation $4x^2 + 4xy - 6y - 9 = 9$ can be written in standard form as a quadratic in x. By completing the square and applying the quadratic formula, we get the solution $|2x+y| = y+3$ where x is the variable and y is considered to be a constant. This can also be solved using POLYSMLT on a TI83/84 or equivalent calculator.
Amer
259
Solve for $x$:
$$4x^2 +4xy - 6y - 9 = 9 $$
Mathematics news on Phys.org
I would write the equation as a quadratic in x in standard form:
$\displaystyle 4x^2+4yx-(6(y+3))=0$
Now apply the quadratic formula.
Completing the square
$ (2x)^2 + 2(2x)y -6y - 9 = 0 $
$ (2x+y)^2 -y^2 -6y - 9 = 0 $
$(2x+y)^2 - (y+3)^2 = 0 $
$(2x+y)^2 = (y+3)^2 $
$ 2x+y = |y+3| $
What happened to the 9 originally on the right side?
lol typo
I've made a few of those in my time! (Tauri)
$ 2x+y = |y+3| $
Last line should be:
\(2x+y = \pm(y+3)\)
CB
\(2x+y = \pm(y+3)\)
CB
what is wrong in my solution ?
Amer said:
Solve for x:
Since x is the variable and y is considered to be a constant your solution should read
$$|2x+y| = y+3$$
as CB has pointed out.
Or you can use POLYSMLT if you have a TI83
FAQ: Solving a Quadratic Equation with Two Variables
What is a quadratic equation with two variables?
A quadratic equation with two variables is an equation that contains two unknown variables, usually represented by x and y, and has the form ax^2 + bx + c = 0, where a, b, and c are constants.
How do you solve a quadratic equation with two variables?
To solve a quadratic equation with two variables, you can use the quadratic formula: x = (-b ± √(b^2 - 4ac)) / 2a. Simply plug in the values for a, b, and c and solve for x.
Can a quadratic equation with two variables have more than two solutions?
Yes, a quadratic equation with two variables can have up to two real solutions. However, it is possible to have complex solutions as well.
Can a quadratic equation with two variables have no solutions?
Yes, a quadratic equation with two variables can have no real solutions. This happens when the discriminant, b^2 - 4ac, is negative and therefore the square root in the quadratic formula results in a complex number.
How do you graph a quadratic equation with two variables?
To graph a quadratic equation with two variables, you can create a table of values by assigning different values to x and solving for y. Then plot these points on a coordinate plane and connect them with a smooth curve. Alternatively, you can use a graphing calculator to graph the equation.
