Solving a Quartic Equation with Large Coefficients
  • MHB
  • Thread starter anemone
In summary: although this problem may be more difficult than that which would typically be encountered in an elementary algebra course, finding the roots of polynomials is a topic in algebra.
anemone
MHB
POTW Director
3,883
115
Hi MHB,
I have tried my very best to solve for $x$ in this problem, a quartic with a very large coefficient of $x^2$ but a small coefficient of $x^4$ and $x$ ,but ended up failing miserably...
I began to think it is a function that has no real roots because it just makes me feel better to think of it that way! But seriously though, I think it's a doable problem, but it's just that my ability to solve it is limited.
Could anyone show me the correct approach to crack it?
Thanks in advance.
Problem:
Find all real roots of the quartic $x^4-(2k + 1)x^2 -x + k^2+ k - 1 = 0$ correct to 4 decimal places, where $k= 10^{10}$.
Mathematics news on Phys.org
Let $f(x) = x^4-(2k + 1)x^2 -x + k^2+ k - 1$ (where for the moment $k$ is just a large positive number). Then $f(k^{1/2}) = -k^{1/2} - 1 < 0$. But $f$ is positive at $x=0$ and also as $x\to\infty$. So $f$ must have a real root between $0$ and $k^{1/2}$, and another real root greater than $k^{1/2}$.
My next move would be to let $x=k^{1/2}+y$ and get an equation for $y$. I would hope to get some information indicating that $y$ is approximately $\pm k^\alpha$, for some value of $\alpha$ less than $1/2$. But I don't have time to do that just now.
anemone said:
Hi MHB,
Thanks in advance.
Problem:
My two cents:
If we assume that all of the roots are much smaller than \(\displaystyle k^2\) then we can approximate the equation as
\(\displaystyle x^4 - (2k + 1)x^2 + k^2 = 0\)
This is a biquadratic equation; Use \(\displaystyle y = x^2\), (which gives \(\displaystyle y^2 - (2k + 1)y + k^2 = 0\)), solve for y using the quadratic formula, then take the square root to get it back in terms of x. It turns out that my assumption is a good one.
-Dan
is this a pre-algebra or algebra level problem?
Yes, although this problem may be more difficult than that which would typically be encountered in an elementary algebra course, finding the roots of polynomials is a topic in algebra.
Thank you Opalg for the reply...
I see that if I let $x=k^{1/2}+y$, then I get
$f(x)=f(k^{1/2}+y)$
$\;\;\;\;\;\;\;=(k^{1/2}+y)^4-(2k+1)(k^{1/2}+y)^2-(k^{1/2}+y)+k^2+k-1$
$\;\;\;\;\;\;\;=y^4+4\sqrt{k}y^3+(4k-1)y^2-(2\sqrt{k}+1)y-\sqrt{k}$
And if I let $y=1$, I get
$f(x)=f(k^{1/2}+1)=1+4\sqrt{k}+4k-1-2\sqrt{k}-1-\sqrt{k}=4k+\sqrt{k}-1>0$
Hence, another root will be in between $\sqrt{k}$ and $\sqrt{k}+1$, i.e. 100,000 and 100,001.
That is the far that I can get, Opalg, without finding the real roots of them.
topsquark said:
My two cents:
-Dan
Hey Dan,
Thank you for the reply...I understand of your approach and you have pointed out something very insightful to me, that is to leave out all other insignificant values when we're dealing with the addition and/or subtraction of some larger values. :)
This is an algebra problem, Paul!:eek:
$f(x)=f(k^{1/2}+y)$
Since $k$ is going to be enormously larger than $y$, I prefer to write this in powers of $k$, namely $$f(k^{1/2}+y) = 4y^2k + (4y^3-2y-1)k^{1/2} + (y^4-y^2-y-1).$$
You can take $y$ very much smaller than that. For example, if $y = -\frac12k^{-1/4}$ then you find that $f(k^{1/2}+y) = k^{1/4} -1 -\frac14k^{-1/2} + \frac1{16}k^{-1} > 0$, so (putting $k=10^{10}$) there is a root between $99\,999.9971883$ and $100\,000$. Also, the derivative $f'(x)$ is approximately $-4k^{3/4}$ at that point, which is large enough to ensure that the root occurs between $99\,999.99718$ and $99\,999.99719$. So the smaller root should be $99\,999.9972$ to four decimal places.
The larger root will also be extraordinarily close to $100\,000$, and I think it will be $100\,000.0028$ to four decimal places.
  • SolvingQuarticEquations.pdf
Ops...I think this is one of the unforgivable mistake that I made, given I have read what topsquark has suggested...(Angry)
Hmm...I think there is a miscalculation to the $x$ value because I think $99\,999.99718$ should be $99\,999.99842$.
I see I see...I understand it now, Opalg!
Since we have $f(\sqrt{k}+0)<0$, we need to pick one negative $y$ value that is so small such that when we subtracted it from $\sqrt{k}$, it will give us
i) $f(\sqrt{k}+y)>0$,
ii) a value $(\sqrt{k}+y)$ that deviates only slightly from $10000$.
We could work further from that to find an educated guess for another negative $y$ value to deduce the smaller positive root for $x$, correct to 4 decimal places, as wanted.
And thank you for given me the first good estimation of the $y$ value, i.e. $y = -\frac12k^{-1/4}=-0.001581$...
And below is my working to find the smaller positive root of the equation:
$\small f(10^{5}-0.001581) = 4(0.001581)^2(10^{10}) + (4(0.001581)^3-2(0.001581)-1)10^{5} + ((0.001581)^4-(0.001581)^2-(0.001581)-1)>0$
$\small f(10^{5}-0.001579) = 4(0.001579)^2(10^{10}) + (4(0.001579)^3-2(0.001579)-1)10^{5} + ((0.001579)^4-(0.001579)^2-(0.001579)-1)>0$
$\small f(10^{5}-0.001578) = 4(0.001578)^2(10^{10}) + (4(0.001578)^3-2(0.001578)-1)10^{5} + ((0.001578)^4-(0.001578)^2-(0.001578)-1)<0$
Hence, we can say that there is a root in between $(99999.998419, 99999.998422)$ and we can conclude by now the smaller positive root, correct to 4 decimal places is $x=99999.9984$.:)
Prove It said:
You can use this method:
https://www.physicsforums.com/attachments/1488
Thank you so much for the pdf file, Prove It!:)
Ahem, yes. The trouble, as so often, is that I can't do basic arithmetic. I wanted to find $\bigl(10^{10}\bigr)^{1/4}$ on my calculator, and I made the mistake of thinking that $10\times\frac14 = 2.25.$ (Blush) (Fubar)
The answer should indeed be $99\,999.99842$, and the larger root should be $100\,000.00158$.
anemone, this kind of problem is interesting. would you be kind to tell me from what algebra book did you get this problem? because the one I'm currently using contain boring exercise.
I'm very sorry to tell you that all of the problems that I post here, whether they are challenge problems or problems with which I need to ask for help come from a collection of problems that I have written out in my book. And to be completely honest with you, I have to then try to recall from memory where I copied them from if someone helping me asks for the source of the problem, with no guarantee of success.
FAQ: Solving a Quartic Equation with Large Coefficients
What is a quartic equation?
A quartic equation is a polynomial equation of the form ax4 + bx3 + cx2 + dx + e = 0, where a, b, c, d, and e are constants and x is the variable. It is also known as a fourth-degree equation.
How do you solve a quartic equation?
There are several methods for solving a quartic equation, including factoring, using the quadratic formula, and using the Ferrari's method. However, these methods can be lengthy and complex. A more efficient and accurate method is to use a computer or calculator to find the roots of the equation.
What is the fundamental theorem of algebra for quartic equations?
The fundamental theorem of algebra states that a quartic equation has exactly four complex roots, including both real and imaginary roots. This means that every quartic equation can be solved, although some solutions may involve complex numbers.
Can a quartic equation have more than four roots?
No, a quartic equation can only have four roots, as stated by the fundamental theorem of algebra. However, some roots may be repeated, resulting in fewer distinct roots.
What are the applications of quartic equations in science?
Quartic equations have various applications in different fields of science, such as physics, engineering, and chemistry. They can be used to model the motion of objects, analyze electric circuits, and predict the behavior of chemical reactions. They are also used in areas such as signal processing, control systems, and computer graphics.
