Solving a Riccati Differential Equation
In summary, we are given a Riccati equation and have to solve it using the substitution method. We need to find the derivative of \(y(x)\) and show that it satisfies a differential equation for \(w(x)\). Then, we solve for \(w(x)\) and find the general solution for \(w(x)\). Finally, we use the substitution to find the general solution for \(y(x)\) and simplify it by combining integration constants.
Sudharaka
MHB
1,568
Hi everyone, :)
Continuing from http://www.mathhelpboards.com/f17/method-reduction-order-variation-parameters-4574/ thread, my friend gave me another question. He wants to check his work specifically on parts a) and d). So I will only focus on those parts.
Question Summary:
Given the Riccati equation,
\[\frac{dy}{dx}+e^{-x}y^2+y+e^x=0\]
we have to solve it using the substitution,
\[y(x)=\frac{e^x}{w}\frac{dw}{dx}\]
a) Show that,
\[\frac{dy}{dx}=e^x\left[\frac{1}{w}\frac{d^{2}w}{dx^2}-\frac{1}{w^2}\left(\frac{dw}{dx}\right)^2+\frac{1}{w}\frac{dx}{dx}\right]\]
b) Show the differential equation for \(w(x)\) is,
\[\frac{d^{2}w}{dx^2}+2\frac{dw}{dx}+w=0\]
c) Find the general solution of the differential equation you found in part b).
d) Use \(\displaystyle y(x)=\frac{e^x}{w}\frac{dw}{dx}\) to find the general solution of \(y(x)\) of the original Riccati equation. Simplify this expression as much as possible. You should be able to combine the two integration constants from part c) into one single integration constant.
For part a),
Use the product rule of differentiation.
\begin{eqnarray}
\frac{dy}{dx}&=&\frac{e^x}{w}\frac{d^{2}w}{dx^2}+ \frac{dw}{dx}\frac{d}{dx}\left(\frac{e^x}{w}\right)\\
&=&\frac{e^x}{w}\frac{d^{2}w}{dx^2}+ \frac{dw}{dx} \left(\frac{e^x}{w}-\frac{e^x}{w^2}\frac{dw}{dx}\right)\\
&=&e^x\left(\frac{1}{w}\frac{d^{2}w}{dx^2}-\frac{1}{w^2}\left(\frac{dw}{dx}\right)^2+\frac{1}{w}\frac{dw}{dx} \right)\\
\end{eqnarray}
For part b),
Substitute \(\displaystyle y(x)=\frac{e^x}{w}\frac{dw}{dx}\) and the above result we obtained for \(y'(x)\) in the Riccati equation. Simplify the get the desired result.
For part c),
This is a second order, linear, homogeneous differential equation with constant coefficients. Therefore you can use the trial solution \(w(x)=Ae^{mx}\) where \(m\) is to be determined. The characteristic equation will be,
\[m^2+2m+1=0\Rightarrow m=-1\]
Therefore,
\[w(x)=(A+Bx)e^{-x}\]
where \(A\) and \(B\) are arbitrary constants.
For part d),
Substituting the above result in \(\displaystyle y(x)=\frac{e^x}{w}\frac{dw}{dx}\) we get,
\[y(x)=\frac{e^x}{(A+Bx)e^{-x}}\frac{d}{dx}\left[(A+Bx)e^{-x}\right]\]
\[\Rightarrow y(x)=\left(\frac{B-A-Bx}{A+Bx}\right)e^{x}\]
Dividing the denominator and numerator by \(B\) and substituting \(\displaystyle C=\frac{A}{B}\) we get,
\[y(x)=\left(\frac{1-C-x}{C+x}\right)e^{x}=\left(\frac{1}{C+x}-1\right)e^{x}\]
FAQ: Solving a Riccati Differential Equation
What is a Riccati differential equation?
A Riccati differential equation is a first-order nonlinear differential equation of the form y' = a(x) + b(x)y + c(x)y2. It is named after Italian mathematician Jacopo Riccati, who studied its properties in the 18th century.
How do you solve a Riccati differential equation?
There is no general method for solving Riccati differential equations. However, there are some special cases where an exact solution can be found, such as when a(x) and b(x) are constants. In most cases, numerical methods or special functions such as the Lambert W function are used to approximate the solution.
What are the applications of solving a Riccati differential equation?
Riccati differential equations have many applications in physics, engineering, and finance. They can be used to model a variety of physical phenomena, such as population growth, chemical reactions, and electrical circuits. In finance, they are used to model interest rates and stock prices.
Can a Riccati differential equation have multiple solutions?
Yes, a Riccati differential equation can have multiple solutions. This is because it is a nonlinear equation, meaning that there is no one-to-one correspondence between the input and output. In some cases, there may even be an infinite number of solutions, making it difficult to determine the exact solution.
Is there a connection between Riccati differential equations and linear differential equations?
Yes, there is a connection between Riccati differential equations and linear differential equations. In some cases, a Riccati differential equation can be converted into a linear differential equation by making a suitable substitution. This allows for the use of known methods for solving linear equations, making the solution process easier.
