svishal03
- 129
- 1
I'm n facing a runtime error and do not know the reason.Also, I found where is the run time error in the code below but am at no clues, why it is occurring.
Actually when j=2 and i=1, the beta(i,j) is not getting calculated- that is, the print statement for beta(i,j) is not executed when j=2 and i=1. Thouhg the program is done till j=2 and also prints i=1 but does not calculate beta(2,1) as it is not printed. See the code in bold below
Anyone knows why?
Please help if possible!
MODULE DIRECT_METHODS_FOR_SOLUTION_OF_LINEAR_ALGEBRAIC_EQUATIONS
CONTAINS
FUNCTION CroutDecomp(AA,total_rows,total_columns,no_of_equations) !This routine decomposes the 'A' matrix of Ax=b into an upper and lower triangular matrix
!It is to be noted that this function fills in only the combined matrix of 'alpha's' and 'beta's' ; where alpha is the upper triangular matrix and beta is the lower triangular matrix.
!Crout's decomposition carries out 2 steps:
!1) First, for i=1,2,---,j use , beta(i,j)= a(i,j)-(summation over k=1 to i-1)[alpha(i,k)*beta(k,j)
!2)Second, for i=j+1,--N use, alpha(i,k)= 1/beta(j,j)*((a(i,j)-summation over k=1 to j-1 [ alpha(i,k)*beta(k,j)]
INTEGER::total_rows,total_columns ,no_of_equations
REAL aa(total_rows,total_columns)
INTEGER:: i,j,k
REAL ::sum1
REAL alpha(total_rows,total_columns),beta(total_rows,total_columns),decomposed(total_rows,total_columns)
LOOP_COLUMN:DO j=1,total_columns
print*,'inside j' ,j
LOOP_ROWS:DO i= 1,j
print*,'inside i', i
alpha(i,i)=1
sum1=0
INotEqual1:IF(i.NE.1)THEN
print*,'inside prod alpha beta',i,j
LOOP_PROD_ALPHA_BETA:DO k=1,i-1
sum1=sum1+(alpha(i,k)*beta(k,j))
END DO LOOP_PROD_ALPHA_BETA
END IF INotEqual1
beta(i,j)=AA(i,j)-sum1
print*,'printing betaqqqqqqqqqqq',beta(i,j)
decomposed(i,j)=beta(i,j)
print*,'printing decomposed',decomposed(i,j)
END DO LOOP_ROWS
jLessThanNoOfEqns:IF(j.LT.no_of_equations)THEN
LOOP_ROWS_1: DO i=j+1,no_of_equations
sum1=0
jNotEqual1:IF(j.NE.1)THEN
LOOP_PROD_ALPHA_BETA2:DO k=1,j-1
END DO LOOP_PROD_ALPHA_BETA2
END IF jNotEqual1
alpha(i,j)=(1/beta(j,j))*(AA(i,j)-sum1)
decomposed(i,j)=alpha(i,j)
END DO LOOP_ROWS_1
END IF jLessThanNoOfEqns
END DO LOOP_COLUMN
print *,'in CroutDecomp'
!ROW11_LOOP:DO i=1,total_rows
!COLUMN11_LOOP:DO j=1,total_columns
!PRINT*,decomposed(i,j)
!END DO COLUMN11_LOOP
!END DO ROW11_LOOP
CroutDecomp = 20
END FUNCTION CroutDecomp
END MODULE DIRECT_METHODS_FOR_SOLUTION_OF_LINEAR_ALGEBRAIC_EQUATIONS
PROGRAM LINEAR_EQUATIONS_SOLVER
USE DIRECT_METHODS_FOR_SOLUTION_OF_LINEAR_ALGEBRAIC_EQUATIONS
!IMPLICIT NONE
REAL,DIMENSION(100,100)::AA,x
REAL,DIMENSION(100)::b
INTEGER::total_rows,total_columns,no_of_equations,i,j
PRINT*, 'ENTER THE TOTAL NUMBER OF ROWS AND COLUMNS'
READ*, total_rows,total_columns
PRINT*, 'ENTER THE TOTAL NUMBER OF EQUATIONS'
READ*, no_of_equations
PRINT*, 'ENTER THE A MATRIX OF Ax = b'
ROW_LOOP:DO i=1,total_rows
COLUMN_LOOP:DO j=1,total_columns
READ*,AA(i,j)
END DO COLUMN_LOOP
END DO ROW_LOOP
PRINT*, 'ENTER THE b MATRIX OF Ax = b'
READ*,b(i)
END DO ROW_LOOP
x= CroutDecomp(AA,total_rows,total_columns,no_of_equations)
END PROGRAM LINEAR_EQUATIONS_SOLVER
Anyone knows why?
CONTAINS
INTEGER:: i,j,k
REAL ::sum1
LOOP_ROWS:DO i= 1,j
alpha(i,i)=1
sum1=0
END IF INotEqual1
END DO LOOP_ROWS
sum1=0
END IF jNotEqual1
END DO LOOP_ROWS_1
END DO LOOP_COLUMN
!END DO ROW11_LOOP
CroutDecomp = 20
!IMPLICIT NONE
READ*,AA(i,j)
END DO COLUMN_LOOP
END DO ROW_LOOP
READ*,b(i)
END DO ROW_LOOP
