Solving a system of equations with numeric variables - Fortran
In summary: Final solution is:' print 5,x print * end subroutine gauss(a,ia,n,l,s) !Ga
leogt11
Hello,
I've been trying to solve a system of equations but I'm getting a lot of troubles when I tried to insert inside a matrix a numeric variable. This is my code. I've tried both schemes, i.e., (1) introducing all elements of the matrix by hand (real numbers) and (2) introducing numeric variables inside the matrix that are the result of other calculations. I've called this numeric variable c. Under the first scheme (1) the code is working but when I replace this by numeric variable it doesn't compile anymore. I would really appreciate if somebody could help me with this. Thank you
program DD
parameter (n=6, ia=6)
integer :: i, j
!integer :: n, ai
dimension a(ia,n),b(n),r(n),l(n),s(n),x(n)
dimension aa(ia,n),e(n)
real :: c
!Matrix that contains a numeric varibable
c=10.25d0
a(1,:) = (/c, 0d0, 0d0, 120d0, 49.4d0, 37d0/)
a(2,:) = (/0.429, 0.273, 0.0, 0.0, 0.775, 0.885/)
a(3,:) = (/0.0, 0.0, 0.111, 1.0, 0.225, 0.075/)
a(4,:) = (/0.571, 0.727, 0.889, 0.0, 0.0, 0.04/)
a(5,:) = (/1.0, -1.9, 0.0, 0.0, 0.0, 0.0/)
a(6,:)=(/0.0, -0.61, 0.0, 0.0, 1.0, 0.0/)
b =(/14.75, 0.375, 0.075, 0.55, 0.0, 0.0/)
!Matrix constructed by introducing all values by hand (Code working under this scheme)
!a(1,:) = (/10.25d0, 0d0, 0d0, 120d0, 49.4d0, 37d0/)
!a(2,:) = (/0.429, 0.273, 0.0, 0.0, 0.775, 0.885/)
!a(3,:) = (/0.0, 0.0, 0.111, 1.0, 0.225, 0.075/)
!a(4,:) = (/0.571, 0.727, 0.889, 0.0, 0.0, 0.04/)
!a(5,:) = (/1.0, -1.9, 0.0, 0.0, 0.0, 0.0/)
!a(6,:)=(/0.0, -0.61, 0.0, 0.0, 1.0, 0.0/)
!b =(/14.75, 0.375, 0.075, 0.55, 0.0, 0.0/)
!save a
do 2 i=1,n
do 2 j=1,n
aa(i,j) = a(i,j)
2 continue
call gauss(a,ia,n,l,s)
call solve(a,ia,n,l,b,x)
print *,' Initial solution is:'
print 5,x
print *
do 4 k=1,5
call residual(aa,ia,n,b,x,r)
print *,' At iteration',k
print *,' Residual vector is:'
print 5,r
call solve(a,ia,n,l,r,e)
print *,' Error vector is:'
print 5,e
do 3 i=1,n
x(i) = x(i) + e(i)
3 continue
print *,' Solution is:'
print 5,x
write(*,'(/a,3f12.2)')' x1= ',(x(1))
write(*,'(/a,3f12.2)')' x2 = ',(x(2))
write(*,'(/a,3f12.2)')' x3 = ',(x(3))
write(*,'(/a,3f12.2)')' x4 = ',(x(4))
write(*,'(/a,3f12.2)')' x5 = ',(x(5))
write(*,'(/a,3f12.2)')' x6 = ',(x(6))
print *
4 continue
5 format (3x,4(e13.6,2x))
stop
end
subroutine residual(a,ia,n,b,x,r)
!Residual vector r = b-Ax
dimension a(ia,n),b(n),r(n),x(n)
double precision sum
do 3 i=1,n
sum = 0.0
do 2 j=1,n
sum = sum + a(i,j)*x(j)
2 continue
r(i) = b(i) - sum
3 continue
return
end
dimension a(ia,n),l(n),s(n)
real max
do 2 i=1,n
l(i) = i
s(i) = 0.0
do 2 j=1,n
s(i) = max(s(i),abs(a(i,j)))
2 continue
do 4 k=1,n-1
rmax = 0.0
do 3 i=k,n
r = abs(a(l(i),k))/s(l(i))
if (r .gt. rmax) then
j = i
rmax = r
endif
3 continue
lk = l(j)
l(j) = l(k)
l(k) = lk
do 4 i = k+1,n
xmult = a(l(i),k)/a(lk,k)
a(l(i),k) = xmult
do 4 j = k+1,n
a(l(i),j) = a(l(i),j) - xmult*a(lk,j)
4 continue
return
end
subroutine solve(a,ia,n,l,b,x)
!LUx = b
dimension a(ia,n),l(n),b(n),x(n),z(4)
do 3 i=1,n
sum = b(l(i))
do 2 j=1,i-1
sum = sum - a(l(i),j)*z(j)
2 continue
z(i) = sum
3 continue
do 5 i=n,1,-1
sum = z(i)
do 4 j=i+1,n
sum = sum - a(l(i),j)*x(j)
4 continue
x(i) = sum/a(l(i),i)
5 continue
return
end
This are the errors that I'm getting
Compilation error time: 0 memory: 4032 signal:0
prog.f95:35.19:
do 2 j=1,n
Warning: Obsolescent feature: Shared DO termination label 2 at (1)
prog.f95:103.19:
do 2 j=1,n
prog.f95:119.23:
do 4 i = k+1,n
Warning: Obsolescent feature: Shared DO termination label 4 at (1)
prog.f95:122.26:
do 4 j = k+1,n
prog.f95:14.20:
Error: Element in REAL(4) array constructor at (1) is REAL(8)
prog.f95:86.16:
r(i) = b(i) - sum
Warning: Possible change of value in conversion from REAL(8) to REAL(4) at (1)
Technology news on Phys.org
You have REAL(8) constants in the first row of matrix a and REAL(4) constants elsewhere.
Try making the first row of matrix a all of type REAL (4). Or, if you are worried about the precision of the result, make everything REAL (8).
How do I make the first row of matrix a all of type REAL (4). You mean like this real*4 :: c
prog.f95:9.12:
real*4 :: c
Error: GNU Extension: Nonstandard type declaration REAL*4 at (1)
prog.f95:43.19:
prog.f95:9.12:
real*4 :: c
prog.f95:43.19:
You're missing the parentheses.
real(4) :: c
Also, and this is very important, you cannot do what you're trying to do. You have a variable named c in your array. You didn't say, but I would guess that you are trying to write a program that solves for c. Fortran doesn't work this way.
Since you haven't given c a value by either initialization or assignment, c will have whatever value is lying around in the memory that is set aside for c. Any calculation you do will be with this "garbage" value.
c is assigned a value of 10.25d0
IDK why the constants in the first row of the a matrix are assigned real(8) values, but these should probably be expressed as real(4) constants.
I missed that line of the code...
Please be more diligent; you are mixing various programming practices and not even good ones.
You are mixing F77 and F90 practices.
Please do not use " dimension " alone to declare variables without using a type...these variables end up being the size of the default REAL..whatever that is...could be 4 or 8 bytes depending on compilation flags. The lowercase "L" ends up as integer, of course.
The use of " d " at the end of a number is for double precision, but you did not define any "double precision " variables, all you defined were REAL
real*4 is correct to define a scalar of 4 bytes long; real(4) is an array of reals of the default size.
Related to Solving a system of equations with numeric variables - Fortran
1. How do I solve a system of equations with numeric variables in Fortran?
To solve a system of equations with numeric variables in Fortran, you will need to use the built-in subroutine "SLATEC" or "NLIN", depending on the complexity of your system. These subroutines use numerical methods such as Gaussian elimination or Newton's method to find a solution for the system of equations.
2. What is the syntax for solving a system of equations in Fortran?
The syntax for solving a system of equations in Fortran can vary depending on the specific subroutine you are using. However, in general, you will need to declare your variables, input the coefficients and constants of each equation, and then call the appropriate subroutine to solve the system. It is important to refer to the documentation for the specific subroutine you are using for the exact syntax.
3. Can I solve a system of equations with both real and complex variables in Fortran?
Yes, Fortran supports both real and complex variables, so you can solve a system of equations with both types of variables. However, you will need to use different subroutines depending on the type of variables involved. For real variables, you can use "SLATEC" or "NLIN", while for complex variables, you will need to use "ZLAIT" or "ZNLIT".
4. Are there any limitations to solving a system of equations in Fortran?
While Fortran is a powerful language for solving mathematical equations, there are some limitations to keep in mind. For example, some subroutines may not be able to handle extremely large or small numbers, so it is important to check the documentation and make sure your equations are within the acceptable range for the subroutine you are using. Additionally, some subroutines may require a certain number of equations and variables, so you may need to adjust your system accordingly.
5. Can I use user-defined functions in Fortran to solve a system of equations?
Yes, user-defined functions can be used in Fortran to solve a system of equations. These functions can be defined using the "FUNCTION" keyword and called within your main program or subroutine. However, it is important to ensure that your function is properly defined and returns the correct values as this can affect the accuracy of your solution.
