Solving a system of nonlinear equations
In summary, This problem involves solving for unknown quantities ##\theta_i, \theta_j## in a system of ##N## equations. The equations involve known quantities ##N## and ##K##, as well as ##\theta_i, \theta_j##. It is possible to solve this problem numerically by using Newton-Raphson method, but a good starting point may be difficult to obtain. For ##N = 2##, there is either no solution or infinitely many solutions, while for ##N = 3##, an exact and complete solution can be obtained.
dumbperson
77
This is actually not a homework problem, but a problem I'm encountering while working on a little project and I'm not sure if it's even solvable or if it makes sense what I'm doing
1. Homework Statement
First, I have the equation
$$p_{ij} = \frac{1}{2}\left( \tanh{(-\frac{\theta_i + \theta_j}{2} + 2Kp_{ij} )} + 1 \right)$$
where ##1 \leq i,j \leq N##. ##N## and ##K## are known quantities and ##\theta_i, \theta_j## are unknown.
The ##N## equations are $$C_i = \sum_{j\neq i}p_{ij}^* = \frac{N-1}{2} + \frac{1}{2}\sum_{j\neq i} \tanh{\left( - \frac{\theta_i + \theta_j}{2} + 2Kp_{ij}^* \right)}$$
where ##C_i## is a known quantity and ##p_{ij}^*## is the solution to the equation in the problem statement.
I want to solve for ##\theta_i, \theta_j##.
I don't necessarily need to solve this exactly, it can be done numerically.
I first tried to solve this problem by expanding the tanh to first order, which simply gives me a system of ##N## linear equations.
I feel as if this system of equations is only solvable if instead of the ##2Kp_{ij}^*## in the argument of the tanh, I had ##2K\sum_{j\neq i}p_{ij}##. This way, I would have the value of ##\sum_{j\neq i}p_{ij}^* = C_i (\textrm{given})## for every ##i##, I could plug this value into the tanh, and then solve for ##\theta_i##.
Is this problem solvable? Or do I not have enough information. To me it seems that I have ##N## unknown quantities (##\theta_i##) and ##N## equations, which should be doable. or am I missing something?
Newton-Raphson ought to be able to do it, but getting a good starting point might be difficult. One possible way would be to start with an "easy"version, then gradually move to the exact version in a series of steps, using the solution of the previous step as a (hopefully) good starting point for the next step.
For example, you could start with the approximate problem in which ##C_i = \bar{C}## for all ##i = 1,2, \ldots, N##, with ##\bar{C}## equal to the average of the true ##C_i## values. Then all ##p_{ij}## are equal to a common value ##p##, and all ##\theta_i## equal some common value ##\theta## in the solution of the approximate problem. The solution is ##p = \bar{C}/(N-1)## and ##\theta## solves ##2p = 1 + \tanh(2Kp -\theta)##, so is easy to obtain. Then, you can work towards the numerical solution of the true problem by solving a sequence of problems with ##C_i = C_i(t) = (1-t)\bar{C} + t C_i(\text{true})## for a sequence of ##t##-values going from 0 to 1. The solution of the current ##t##-problem can be used as the starting point of the next-##t## problem. It might not work to go all the way from ##t=0## to ##t=1## in one step, but going in several smaller steps ought to work.
Likes Dougias and dumbperson
My response in #2 was a bit too hasty.
For ##N = 2## there is either no solution or infinitely many solutions. Letting ##\theta_i /2 = u_i##, the system for ##N=2## reads as
$$\begin{array}{ccl}2 p_{12} &=& 1 + \tanh( 2 K p_{12} - u_1-u_2)\\
2 p_{21} &=& 1 + \tanh( 2 K p_{21} - u_2 - u_2) \\
C_1 &=& p_{12} \\
C_2 &=& p_{21}
\end{array}
The first two equations are the same, so ##p_{12} = p_{21} = p.## Then the last two equations read as ##C_1 = p## and ##C_2 = p.## If ##C_1 \neq C_2## the system has no solution; if ##C_1 = C_2 = C## then we have ##p = C##, and the first equation gives a simple solution for ##u_1 + u_2##. However, we cannot obtain ##u_1## and ##u_2## separately.
For ##N = 3## we can get an exact, complete solution. First, the ##p_{ij}## equations imply that ##p_{ij} = p_{ji}##, so we have three ##p##-variables ##p_{12}, p_{13}, p_{23}##. The ##p##-##C## equations read as
$$\begin{array}{ccc}
p_{12}+p_{13} &=& C_1\\
p_{12}+p_{23} &=& C_2 \\
p_{13} + p_{23} &=& C_3
\end{array}$$
For given ##C_i## this system has a unique solution for ##p_{12}, p_{13}, p_{23}##, and getting it is just a matter of elementary algebra.
Now each ##u_i + u_j## can be determined by solving the equations connecting the ##p##'s to the ##u##'s:
$$ u_i + u_j = 2Kp_{ij} -\text{arctanh}(2 p_{ij}-1),$$
for ##ij = 12, 13, 23.## In a way similar to the ##p##-##C## equations, these last three equations also have a unique solution that can be obtained by elementary (but increasingly messy) algebra.
For ##N \geq 4## I think you need to start using numerical methods, and you have the correct number of equations and variables to make it probable that the problem is solvable.
Likes dumbperson
Hey Ray, thanks for the answer! The next 2 days I'm quite busy so I'll fully read and think about your answer after that!
I can see how to show that if K<1 (any N), but how do you show it generally?
Good point: for some ##K > 1## and some ##\theta_i, \theta_j## there are three positive roots to the equation
$$2x = 1 + \tanh(2*K*x -(\theta_i + \theta_j)/2),$$
so we could have ##p_{ij}## equal to one of the roots and ##p_{ji}## equal to one of the others. However, I don't see any way of handling such a situation numerically, since requiring two ##p##s to be two separate numerical roots of some common equation is not something that can be implemented in any way that I can see. If we did have multi-armed formulas for the ##p##s, we could set one ##p## to one arm of those formulas and the other ##p## to another arm, but if all we have are numerical methods, I think we are out of luck.
However, at least we can say that there exists a solution in which ##p_{ij} = p_{ji}## for all ##i \neq j.## However, the possible existence of multiple roots---even in this case---could cause real problems for a nonlinear solver such as Newton-Raphson, so it is probably even more important than I first hinted at to sneak up on a solution by small steps from some easily-solved starting approximation.
For the OP: the method I suggested to solve a sequence of problems in working towards the true solution is a well-known technique that falls under the general title of "homotopy method". There is a large literature on this topic, and a Google search under "homotopy method for nonlinear equations" will lead you to numerous relevant sources.
Likes dumbperson
Hey Ray,
In general, we have ##N(N-1)/2## different ##p_{ij}## variables, correct? But we have ##N## amount of ##p-C## equations. So we have the right amount of equations / variables if ##N(N-1)/2 = N##, which is true for ## N =3 ##. Am I missing something or is this then not solvable if ##N\neq 3## ?
dumbperson said:
Hey Ray,
Ah, after solving the ##p-C## equations, we have ##N(N-1)/2 - N## unknown ##p_{ij}## variables left. In total (with the ##u_i##), we have ##N(N-1)/2 - N + N = N(N-1)/2 ## unknown variables left. We have ##N(N-1)/2## equations that connect the ##p##'s to the ##u##'s, so it should be solvable numerically, I guess
Related to Solving a system of nonlinear equations
What is a system of nonlinear equations?
A system of nonlinear equations is a set of two or more equations that contain at least one variable raised to a power other than one or contain variables multiplied together. These equations are not linear, meaning they cannot be graphed as straight lines.
Why is it important to solve a system of nonlinear equations?
Solving a system of nonlinear equations allows us to find the values of the variables that satisfy all of the equations in the system. This is useful in many fields, such as physics, engineering, and economics, where nonlinear relationships are common and need to be accurately modeled and analyzed.
What are the different methods for solving a system of nonlinear equations?
There are several methods for solving a system of nonlinear equations, including substitution, elimination, and graphing. These methods involve manipulating the equations in the system to eliminate one variable and solve for the others.
Can all systems of nonlinear equations be solved?
No, not all systems of nonlinear equations have a solution. Some systems may have no solution, meaning there is no set of values that satisfies all of the equations, while others may have an infinite number of solutions.
What are some applications of solving systems of nonlinear equations?
Solving systems of nonlinear equations is used in a variety of applications, such as optimizing production processes, analyzing financial data, and predicting population growth. It is also essential in fields like computer graphics and computer vision, where complex mathematical models are used to simulate and analyze real-world phenomena.
  • Quantum Interpretations and Foundations
  • Chemistry
