Solving a Trigonometric Equation
In summary, the given equation is transformed into an identity by factoring and using the Pythagorean identity. This shows that the equation is true for all values of x in the domain.
thorpelizts
solve for
tan^4x + tan^2x = sec ^4x - sec^2x
i solved and ended up with RIHS= tan^4x?
Mathematics news on Phys.org
re: Solving a Trignometric Equation
We are given to solve:
$\displaystyle \tan^4(x)+\tan^2(x)=\sec^4(x)-\sec^2(x)$
I would arrange as:
$\displaystyle \tan^4(x)-\sec^4(x)+\tan^2(x)+\sec^2(x)=0$
Factor:
$\displaystyle (\tan^2(x)+\sec^2(x))(\tan^2(x)-\sec^2(x))+\tan^2(x)+\sec^2(x)=0$
$\displaystyle (\tan^2(x)+\sec^2(x))((\tan^2(x)-\sec^2(x))+1)=0$
Now, since $\displaystyle \tan^2(x)+1=\sec^2(x)$ we have:
$\displaystyle 0=0$
which means the original equation is an identity, i.e., it is true for all values of x in the domain.
Were you supposed to prove the identity is true instead of solving the equation?
yeah, thx
thorpelizts said:
solve for
If You apply the basic definitions the 'equation' becomes...
$\displaystyle \frac{\sin^{4} x}{\cos^{4} x} + \frac{\sin^{2} x}{\cos^{2} x} = \frac{1}{\cos^{4} x} - \frac{1}{\cos^{2} x} \implies \frac{\sin^{4} x-1}{\cos^{4} x} + \frac{\sin^{2} x+1}{\cos^{2} x}=0 \implies$
$\displaystyle \implies \frac{\sin^{2} x -1+ \cos^{2} x}{\cos^{4} x} =0 \implies \frac{0}{\cos^{4} x}=0$
... anf that is an identity, i.e. any x satisfies the 'equation'...
Kind regards
$\chi$ $\sigma$
I like to begin with the left side, and try to manipulate it so that the right side results. I think I would first factor the left side to get:
$\displaystyle \tan^2(x)(\tan^2(x)+1)$
Now, use the Pythagorean identity $\displaystyle \tan^2(x)+1=\sec^2(x)$ and see where this leads you...
FAQ: Solving a Trigonometric Equation
What is a trigonometric equation?
A trigonometric equation is an equation that involves trigonometric functions such as sine, cosine, and tangent. It typically involves finding the unknown angle or side length in a triangle.
What are the steps for solving a trigonometric equation?
The steps for solving a trigonometric equation are:
1. Rewrite the equation using trigonometric identities, if necessary.
2. Simplify the equation by combining like terms.
3. Isolate the trigonometric function by moving all other terms to the other side of the equation.
4. Solve for the unknown angle or side length using inverse trigonometric functions.
5. Check your answer by plugging it back into the original equation.
What are some common trigonometric identities used in solving equations?
Some common trigonometric identities used in solving equations include:
- Pythagorean identities: sin²x + cos²x = 1 and tan²x + 1 = sec²x
- Double angle identities: sin2x = 2sinx*cosx and cos2x = cos²x - sin²x
- Half angle identities: sin²(x/2) = (1 - cosx)/2 and cos²(x/2) = (1 + cosx)/2
What are the possible solutions to a trigonometric equation?
The possible solutions to a trigonometric equation depend on the domain and range of the trigonometric function. In general, there can be infinite solutions for trigonometric equations. However, if the domain is restricted, there may be a finite number of solutions.
When do extraneous solutions occur in trigonometric equations?
Extraneous solutions occur when a value satisfies the equation but is not a valid solution. This can happen when taking the inverse of a trigonometric function, as it may introduce additional solutions that do not work in the original equation. It is important to always check for extraneous solutions when solving trigonometric equations.
