Solving a Trigonometric Integral
In summary,The function he is trying to integrate is a cosine, and in order to solve for it, he needs to use integration by parts. Once he has obtained the equation for the cosine, he can use Eddybob's method to simplify the equation.
yanic
Can anyone please help to solve this following integral?
∫(sin(x)-sin^2 (x)/√(sin^2 (x)+c)) dx
c is a constant
Re: integral
c is a constant
Integral belongs to calculus...
is this what you want to integrate?
\(\displaystyle \int\frac{\sin(x)-\sin^2(x)}{\sqrt{\sin^2(x)}}+c\)
Regards,
\(\displaystyle |\pi\rangle\)
Re: integral
Please check the JPG file for the correct expression of
the function.
Best...
Re: integral
pape said:
https://www.physicsforums.com/attachments/1302
the function.
Best...
"And what I have found so far is" What is "what you have found"? How did you get this line? What does it mean?
How does the derivative relate to the given problem?
Please be more specific.
-Dan
Re: integral
-Dan
Please check the attached file.
I hope that I have been more specific this time.
Regards
Re: integral
You can start by substituting $u=\sin(x)$ to obtain
$$\int u-\frac{u^2}{\sqrt{u^2+c}}\, du$$
From there you can try integration by parts.
Re: integral
If \(\displaystyle u= \sin(x)\) Then \(\displaystyle du=\cos(x)\,dx\) which is not same as that function he wants to integrate?
Regards,
Re: integral
Hello,
Integration by part leads to a more complicated expression at the end for the finding of the primitive.
Do you have any other suggestion please?
Regards
Re: integral
pape said:
Hello,
Regards
Unfortunately, that's because the primitive is quite complex...
Incidentally, if you apply Eddybob's method, but set \(\displaystyle c=b^2\,\), so that \(\displaystyle b=\sqrt{c}\,\), you can take the constant outside of the square root... ;)
FAQ: Solving a Trigonometric Integral
What is a trigonometric integral?
A trigonometric integral is an integral that involves trigonometric functions, such as sine, cosine, or tangent. It is a way of finding the area under a curve that contains trigonometric functions.
Why is solving a trigonometric integral important?
Solving a trigonometric integral is important because it allows us to evaluate the area under a curve and solve problems in fields such as physics, engineering, and economics. It also helps in understanding the behavior of trigonometric functions.
What are the common techniques for solving a trigonometric integral?
The common techniques for solving a trigonometric integral include substitution, integration by parts, and trigonometric identities. These techniques can be used to simplify the integral and make it easier to solve.
What are the challenges in solving a trigonometric integral?
The challenges in solving a trigonometric integral include identifying the appropriate technique to use, dealing with complex expressions and multiple trigonometric functions, and recognizing the limits of integration.
Are there any tips for solving a trigonometric integral?
Yes, some tips for solving a trigonometric integral include using trigonometric identities to simplify the integral, choosing the right substitution, breaking down the integral into smaller parts, and practicing regularly to improve problem-solving skills.
