Solving a Triple Integral with $\rho$ Constant
In summary: Read moreIn summary, the conversation revolves around finding the gravitational energy between a mass $m$ and a sphere with radius $a$ and density $\rho$ at a distance $R$. The formula for this is given by the triple integral $-\rho Gm\iiint\frac{r'^2\sin\theta}{\sqrt{R^2 + r'^2 - 2Rr'\cos\theta}}d\theta d\rho dr'$ where $0<r'<a$, $0<\theta<\pi$, and $0<\rho<2\pi$. The conversation discusses different approaches to solving this integral, including integrating for $\rho$ and $\theta$, as well as considering the value
Dustinsfl
2,281
Anyone have any smooth ideas for this triple integral?
The $\rho$ out front is constant.
Re: triple integral
Integrating for $\rho$ (shouldn't that be $\phi$?) is simply multiplying by $2\pi$.
Then integrate with respect to $\theta$.
To do so, consider what $\dfrac{\partial}{\partial \theta}\sqrt{R^2 + r'^2 - 2Rr'\cos\theta}$ is.
You'll be left with a pretty simple expression to integrate with respect to r'.
Finally you'll end up with the gravitational energy between a mass $m$ and a sphere (with radius $a$ and density $\rho$) at a distance R.
Re: triple integral
Yes, it should be $\phi$.
Re: triple integral
I keep ending up with
\begin{alignat*}{3}
V & = & -2\pi\rho Gm\int_0^a\left[\sqrt{1 +\left(\frac{r'}{R}\right)^2-2\frac{r'}{R}\cos\theta}\right|_0^{\pi}dr\\
& = & -2\pi\rho Gm\int_0^a\left[\sqrt{\frac{(r' + R)^2}{R^2}} - \sqrt{\frac{(r' - R)^2}{R^2}}\right]dr\\
& = & -\frac{2\pi\rho Gm}{R}\int_0^a[r' + R - r' + R]dr\\
& = & -4\pi\rho Gm\int_0^a dr\\
& = & -4\pi\rho Gma
\end{alignat*}
Then $\rho = \frac{M}{V}$ so $V = -\frac{4\pi GMm a}{V}$ but I need to conclude $V = -\frac{GMm}{R}$.
Re: triple integral
\begin{alignat*}{3}
& = & -4\pi\rho Gma
\end{alignat*}
Assuming you did the integral right ,it is impossible to get rid of (a) unless you have a value for it. May I ask what is r' ?
Re: triple integral
r' is r
Re: triple integral
Notice \(\displaystyle \sqrt{(r'-R)^2}\not =(r'-R) \) unless r'>R
Re: triple integral
Here is what I am working on. It is on page 1. Maybe there is something you will see that will help.
  • 230 Notes.pdf
Re: triple integral
How can I handle that then?
Re: triple integral
Can we deduce from the figure that R>r' ?
Re: triple integral
No because the differential volume can be anywhere. I just drew so that r' > R. As the distance between the planets go to infinity, $r'\to R$ but even doing that only yields:
-\frac{Gma\pi(a+2R)\rho}{R}
Re: triple integral
Ok,what do you mean by a ? Is it the radius of M ?
Re: triple integral
Yes
Re: triple integral
\begin{alignat*}{3}
V & = & -\frac{2\pi\rho Gm}{R}\int_0^a r'\left[r' + R - \sqrt{(r' - R)^2}\right]dr'\\
& = & \frac{2\pi\rho Gm}{R}\int_0^a 2r'^2dr'\\
& = & -\frac{4Gma^3\rho\pi}{3R}\\
& = & -\frac{GMm}{R}
\end{alignat*}
Since $\rho = \frac{M}{V}$ where $V = \frac{4\pi r^3}{3}$, we have the desired result.
Re: triple integral
Excellent , so you are choosing that R>r' , but what is the meaning of that ? Are you raking some unnecessary restrictions ?
Re: triple integral
If we let $R\to\infty$, then $r'\to R$.
So I took r'=R
Re: triple integral
So I took r'=R
That doesn't look quite correct.
If we let $R\to\infty$, then $r' \le a \ll R$.
But really, there is no need to do this.
Your formula works for any $R$ with $r' \le a \le R$.
Actually, the additionally interesting case is when $R < a$.
You can also calculate what happens then.
It should come out that $V = -\frac 4 3 \pi R^3 \rho \cdot \frac {Gm }{R}$.
That is, the attractive force when inside a solid sphere is completely determined by the subsphere between you and the center.
The forces by the part of the sphere that is on the outside cancel out.
Re: triple integral
How do I go from the first integral to the second then?
\begin{alignat*}{3}
\end{alignat*}
Since $0 < r' < a < R$, we can write $\sqrt{(r' - R)^2} = \sqrt{(R - r')^2} = R - r'$??
Re: triple integral
\begin{alignat*}{3}
\end{alignat*}
If $R \ge r'$, then $\sqrt{(r' - R)^2} = |r' - R| = (R - r')$.
Substitute?
Yes!
FAQ: Solving a Triple Integral with $\rho$ Constant
What is a triple integral with $\rho$ constant?
A triple integral with $\rho$ constant is a mathematical concept used in multivariable calculus to find the volume of a three-dimensional object where the density ($\rho$) is constant throughout the object.
What are the steps to solving a triple integral with $\rho$ constant?
The steps to solving a triple integral with $\rho$ constant are:
  1. Identify the limits of integration for each variable (x, y, and z).
  2. Set up the integrand, which is the function being integrated, with $\rho$ as a constant.
  3. Integrate the innermost integral with respect to x, using the limits of integration for x.
  4. Integrate the resulting expression with respect to y, using the limits of integration for y.
  5. Finally, integrate the resulting expression with respect to z, using the limits of integration for z.
What are some common applications of solving a triple integral with $\rho$ constant?
A triple integral with $\rho$ constant is commonly used in physics and engineering to calculate the mass, volume, or surface area of three-dimensional objects with uniform density. It can also be used in fluid dynamics to calculate the flow rate of a fluid through a given volume.
Can a triple integral with $\rho$ constant be solved using different coordinate systems?
Yes, a triple integral with $\rho$ constant can be solved using different coordinate systems, such as cylindrical or spherical coordinates. The limits of integration and the integrand will vary depending on the coordinate system being used, but the general steps for solving the integral will remain the same.
What are some tips for solving a triple integral with $\rho$ constant efficiently?
Some tips for solving a triple integral with $\rho$ constant efficiently include:
  • Make sure to carefully identify the limits of integration for each variable.
  • Choose the most appropriate coordinate system for the given problem.
  • Simplify the integrand as much as possible before integrating.
  • Use symmetry and other mathematical properties to simplify the integral.
  • Double-check your calculations and make sure to follow the correct order of integration.
