Solving a Vector Triangle Differential Equation
The discussion focuses on solving a vector triangle differential equation derived from a circular path at angle theta. The equation can be rearranged to express (r thetadot)^2 in terms of other variables, leading to a quadratic form. Participants suggest using the small k approximation to simplify the equation and retain relevant terms up to k^2. It is noted that while the presence of a sin(theta) * thetadot term complicates direct application of the quadratic formula, it can still be managed by manipulating the equation. The overall goal is to integrate the solution from theta = 0 to theta = 2pi.
phantomvommand
See picture below
Cosine rule,
Speed vector equation
By considering a vector triangle at any point on its circular path, at angle theta from the x -axis,
We can obtain that:
(rw)^2 + (kV)^2 - 2(rw)(kV)cos(90 + theta) = V^2
This can be rearranged to get:
(r thetadot)^2 + (kV)^2 + 2 (r* thetadot)(kV)sin theta = V^2.
I know that I must somehow solve this differential equation in theta, and integrate from theta = 0 to theta = 2pi.
How do I solve this equation?
Thank you!
Likes Fikremariam
You are told k is very small, so you need to make an approximation.
And you know the extra is of order k2, so you know which terms to keep.
I would start by solving the quadratic.
Likes phantomvommand
Thank you! I was thinking that the quadratic equation formula couldn’t be applied to solve for thetadot because there is a sintheta*thetadot term. This doesn’t pose a problem I suppose?
You can solve the quadratic for ##\dot\theta##, creating a trig term inside a square root. But then you can use the small k approximation to get rid of the square root. You may need to use it again. Just make sure to keep terms up to k2.
