Telemachus
- 835
- 30
Hi there. Well, I'm stuck with this problem, which says:
When p=0 the Bessel equation is: [tex]x^2y''+xy'+x^2y=0[/tex]
Show that its indicial equation only has one root and find the Frobenius solution correspondingly. (Answer: [tex]y=\sum \frac{(-1)^n}{ 2^{2n}(n!)^2 }x^{2n} [/tex]
Well, this is what I did:
At first I normalized the equation:
[tex]y''+\frac{y'}{x}+y=0[/tex]
Then
[tex]P(x)=\frac{1}{ x} \rightarrow xP(x)=1[/tex]
[tex]Q(x)=1 \rightarrow x^2Q(x)=x^2[/tex]
So x=0 is regular singular point.Then the indicial equation is: [tex]\alpha(\alpha-1)+p_0\alpha+q_0=0 \rightarrow \alpha^2-alpha+\alpha=0 \rightarrow \alpha=0[/tex]
[tex]y=\sum_{n = 0}^\infty a_n x^n \rightarrow y'=\sum_{n = 1}^\infty a_n n x^{n-1} \rightarrow y''=\sum_{n = 2}^\infty a_n n(n-1) x^{n-2}[/tex]
Then
[tex]x^2y''+xy'+x^2y=\sum_{n = 2}^\infty a_n n(n-1) x^n+ \sum_{n = 1}^\infty a_n n x^n+\sum_{n = 0}^\infty a_n x^{n+2} = \sum_{n = 2}^\infty a_n n(n-1) x^n+ \sum_{n = 1}^\infty a_n n x^n+\sum_{n = 0}^\infty a_{n-2}x^n[/tex]
So from here I took
[tex]a_n n(n-1)+a_{n-2}=0[/tex]
[tex]a_n=\frac{-a_{n-2}}{n(n-1)},n=2k \rightarrow a_{2k}=\frac{-a_{2k-2}}{2k(2k-1)}[/tex]
Then I've made some iterations, but I can't find the form that the problem gives as the answer, some of the iterations:
[tex]a_2=\frac{-a_0}{2 },a_4=\frac{a_0}{4.3.2 },a_6=\frac{-a_0}{6.5.4.3.2 } [/tex]
So the answer I seem to get is [tex]a_{2k}=\frac{(-1)^k}{(2k)!}a_0 [/tex]
But I should get [tex]\sum \frac{(-1)^n}{ 2^{2n}(n!)^2 }a_0[/tex] or something like that, which is how the answer the problem gives looks like.
I'm probably doing something wrong, but I couldn't figure it out what it is.
Bye there, thanks for helping!
Then
Then
So from here I took
