Solving boundary conditions for vibrating beam
In summary, the problem involves solving the equation for transverse vibrations of a Euler-Bernoulli beam fixed at both ends and subject to axial loading. The general solution takes the form of ##y(x) = C_1cosh(αx) + C_2sinh(αx) + C_3cos(βx) + C_4sin(βx)##, where ##C_1##, ##C_2##, ##C_3##, and ##C_4## are constants that need to be found. The boundary conditions are standard, and after substitution, the first two conditions give ##C_1 + C_3 = 0## and ##αC_2 +
ajtgraves
Hi there,
I'm solving the equation for the transverse vibrations of a Euler-Bernoulli beam fixed at both ends and subject to axial loading. It's a similar problem to that described by Rao on page 355 of his book "Vibration of Continuous Systems" (Google books link), except the example he uses is for a simply supported beam.
The general solution takes the form of ##y(x) = C_1cosh(αx) + C_2sinh(αx) + C_3cos(βx) + C_4sin(βx)## ,
where ##C_1##, ##C_2##, ##C_3## & ##C_4## are the constants I need to find. The BCs are standard:
  • ##y(0)=y(L) = 0## (zero displacement at ends)
  • ##y'(0)=y'(L) = 0## (zero gradient at ends)
When I substitute these in the ##y(0)## and ##y'(0)## conditions give ##C_1 + C_3 = 0## and ##αC_2 + βC_4 = 0##, respectively, while the ##y(L)## and ##y'(L)## conditions give:
1) ##C_1cosh(αL) + C_2sinh(αL) + C_3cos(βL) + C_4sin(βL) = 0##
2) ##αC_1sinh(αL) + αC_2cosh(αL) – βC_3sin(βL) + βC_4cos(βL) = 0##
Clearly the first 2 conditions can be used to reduce these last two equations into functions of ##C_1## and ##C_2##only:
3) ##C_1[cosh(αL) - cos(βL)] + C_2[sinh(αL) - (α/β)sin(βL)] = 0##
4) ##C_1[αC_1sinh(αL) + βsin(βL)] + C_2[βcosh(αL) - αcos(βL)] = 0##We can now solve for ##C_1## (or ##C_2##) and use this to write all the terms of the original governing equation in terms of it alone. However, there are two possible expressions for ##C_1## (and ##C_2##), depending on which equation is used. 3) gives:
##C_2 = -C_1[cosh(αL) - cos(βL)] / [sinh(αL) - (α/β)sin(βL)]##
whereas 4) gives:
##C_2 = -C_1[αC_1sinh(αL) + βsin(βL)] / [βcosh(αL) - αcos(βL)]##These are clearly different, but are they both correct? Which one should be used?Many thanks in advance for your help, it would be much appreciated.
ajtgraves said:
Hi there,
where C1 , C2 , C3 & C4 are the constants I need to find. The BCs are standard:
When I substitute these in the ##y(0)## and ##y'(0)## conditions give ##C_1 + C_3 = 0## and ##αC_2 + βC_4 = 0##, respectively, while the ##y(L)## and ##y'(L)## conditions give:1) ##C_1cosh(αL) + C_2sinh(αL) + C_3cos(βL) + C_4sin(βL) = 0##2) ##αC_1sinh(αL) + αC_2cosh(αL) – βC_3sin(βL) + βC_4cos(βL) = 0##Clearly the first 2 conditions can be used to reduce these last two equations into functions of ##C_1## and ##C_2##only:3) ##C_1[cosh(αL) - cos(βL)] + C_2[sinh(αL) - (α/β)sin(βL)] = 0##4) ##C_1[αC_1sinh(αL) + βsin(βL)] + C_2[βcosh(αL) - αcos(βL)] = 0##We can now solve for ##C_1## (or ##C_2##) and use this to write all the terms of the original governing equation in terms of it alone. However, there are two possible expressions for ##C_1## (and ##C_2##), depending on which equation is used. 3) gives:
whereas 4) gives:##C_2 = -C_1[αC_1sinh(αL) + βsin(βL)] / [βcosh(αL) - αcos(βL)]##
I've re-worked your Latex commands slightly to make your post more legible.
Related to Solving boundary conditions for vibrating beam
1. What are boundary conditions for a vibrating beam?
Boundary conditions for a vibrating beam refer to the constraints or limitations placed on the behavior of the beam at its boundaries. This includes restrictions on displacement, slope, and curvature at the fixed ends or points of support.
2. Why is it important to solve boundary conditions for a vibrating beam?
Solving boundary conditions allows us to determine the exact behavior of the beam under given loading and support conditions. This is crucial in engineering and design applications as it ensures the beam can safely withstand the applied forces and meet performance requirements.
3. What methods are used to solve boundary conditions for a vibrating beam?
There are several methods used to solve boundary conditions for a vibrating beam, including the Euler-Bernoulli beam theory, Timoshenko beam theory, and Rayleigh-Ritz method. Finite element analysis is also commonly used in modern applications.
4. What factors influence the boundary conditions for a vibrating beam?
The boundary conditions for a vibrating beam are influenced by several factors, such as the material properties of the beam, its geometry, the magnitude and direction of applied loads, and the type of supports or restraints at its boundaries.
5. Can boundary conditions be changed after solving for a vibrating beam?
In most cases, boundary conditions cannot be changed after solving for a vibrating beam. This is because the beam's response and behavior are dependent on the specified conditions, and any changes would require a new analysis to be performed.
  • Mechanical Engineering
