Solving Box Motion with Applied Force
Once you integrate, you will get an equation that relates velocity to time (v(t)). You can then use this equation to find the time when the velocity is zero, which is the answer to the first part of the problem.Hope that helps!
uncensored188
A 3.10 box is moving to the right with speed 8.50 on a horizontal, frictionless surface. At t=0, a horizontal force is applied to the box. The force is directed to the left and has magnitude F(t)= (6.00 N/s^2)t^2
What distance does the box move from its position at t=0 before its speed is reduced to zero?
If the force continues to be applied, what is the speed of the box at 4.00s ?
Welcome to PF !
You need to make an attempt at a solution before we can help you. It's in the rules for these forums. It's even true for God. !
What is the 3.1 associated with the box?
It's mass?
It's volume?
It's temperature?​
And what are the units?
Find the acceleration of the box.
How are velocity and acceleration related?
You must show your attempts.
[EDIT Ah. Beat me.]
1.15997\units{m}
3.47\units{m}
11.598\units{m}
10.038\units{m}
all wrong for the first part
Show your work. That way we can better assist you.
its a 3.1 kg box and i have no clue how to approach it
Basically, because of Newton's 2nd law, you know the acceleration as a function of time a(t). How can you use this to figure out the velocity as a function of time v(t)? Hint: what are the definitions of acceleration and velocity?
i know you have to integrate from acceleration to velocity but it is too confusing
Good! Show us the first few steps of the integration that you attempted, up to the point where you got stuck. Explain specifically where you got confused. Then we can help you. We're more than willing to help you learn, but we're not just going to do it for you. Sorry.
can i use the formula ft=mv
6t^3=3.10 * 8.5
and i get that time equals 1.6376 and and i get acceleration is 6t^2/m
what formula do i plug this into, I'm not too good at integrating I'm completely confused
No, you can't, because this is only true if the force is constant. The more general relation is F(t)dt = Δp (impulse is the integral of force with respect to time, and it is equal to the change in momentum).
However, it is not necessary to use impulse and momentum if you don't want to. You can just do what you said you were going to do, which is to integrate the acceleration function with respect to time in order to get the velocity function. Once you have the velocity as a function of time v(t), it should be easy to solve for the value of t at which v(t) = 0. In order to integrate the acceleration function a(t), you must first figure out what it is, and you have done so:
Correct! This is a(t). Now integrate it to get v(t)!
thank you guys very much for your help, I figured it out
after i integrated i used 8.5 for c and and then took the definite integral from 0 to the time i found when velocity is 0. I got the correct answer!
can someone please clarify this to me? I have a problem very similar to this one.
what exactly are you integrating and what do you get once you integrate?
This thread is one year old.
Integrating acceleration gives velocity, i.e, acceleration is the derivative of velocity, so velocity is the anti-derivative of acceleration.
Related to Solving Box Motion with Applied Force
1. What is box motion?
Box motion refers to the movement of a box or object from one position to another.
2. What is applied force?
Applied force is a force that is exerted on an object by another object or by an external source. It can cause an object to accelerate, change direction, or deform.
3. How do you solve for box motion with applied force?
To solve for box motion with applied force, you need to use Newton's second law of motion, which states that the force acting on an object is equal to its mass multiplied by its acceleration. You also need to consider other factors such as friction and air resistance.
4. What is the role of friction in box motion with applied force?
Friction is a force that opposes the motion of an object. In box motion with applied force, friction plays a crucial role in determining the object's acceleration and overall motion. It can either increase or decrease the object's acceleration depending on the direction of the applied force.
5. Can box motion with applied force be solved using other equations?
Yes, there are other equations that can be used to solve for box motion with applied force, such as the work-energy theorem and the principle of conservation of momentum. However, Newton's second law of motion is the most commonly used equation for this type of problem.
