Solving Complex Expressions for Scientists
In summary: This is why I found it unnecessary in this case. Am I missing something?You can find more values if you take one turn or several turns..My Professor told m that..In summary, the author suggests that z can be found using the following equation: z=(1-i)^{i-1} where 1-i=\sqrt{2}\left(\cos\left(-\frac{\pi}{4}+2k\pi \right)+i\sin\left(-\frac{\pi}{4}+2k\pi \right) \right), which becomes e^{\frac{1}{2}\ln(2)-\frac{\pi}{4}i}e
shen07
54
How to go about solving this one?
(1-i)-1+i
so far i have tries using the famous Uv=ev(ln(U)
im stuck where i get
e-1/2ln(2)+(pi/4)-2kpi*ei(-1/2ln(2)+(pi/4)-2kpi)
You have a good approach, but I think you have made an algebraic slip somewhere. To avoid a complex argument for the natural log function, I wrote:
\(\displaystyle z=(1-i)^{i-1}\)
\(\displaystyle 1-i=\sqrt{2}\left(\cos\left(-\frac{\pi}{4} \right)+i\sin\left(-\frac{\pi}{4} \right) \right)=\sqrt{2}e^{-\frac{\pi}{4}i}=e^{\frac{1}{2}\ln(2)-\frac{\pi}{4}i}\)
Hence:
\(\displaystyle z=\left(e^{\frac{1}{2}\ln(2)-\frac{\pi}{4}i} \right)^{i-1}=e^{\frac{\pi}{4}-\frac{1}{2}\ln(2)}e^{\left(\frac{\pi}{4}+\frac{1}{2}\ln(2) \right)i}=\frac{e^{\frac{\pi}{4}}}{\sqrt{2}}\left(\cos\left(\frac{\pi}{4}+\frac{1}{2}\ln(2) \right)+i\sin\left(\frac{\pi}{4}+\frac{1}{2}\ln(2) \right) \right)\)
Hence:
Yeah that's right but however i have to include the 2K\(\displaystyle {\pi}\)
I see this as wholly unnecessary, but write it in if it is required.
I think it becomes necessary if we study complex numbers , Of course we always consider the Principle Logarithm if we are working on the real numbers .
\(\displaystyle 1-i=\sqrt{2}\left(\cos\left(-\frac{\pi}{4}+2k\pi \right)+i\sin\left(-\frac{\pi}{4}+2k\pi \right) \right)=\sqrt{2}e^{-\frac{\pi}{4}i+2k\pi i}=e^{\frac{1}{2}\ln(2)-\frac{\pi}{4}i}e^{2k\pi i}=e^{\frac{1}{2}\ln(2)-\frac{\pi}{4}i}\)
I think the OP talks about the logarithm since $a^b$ is actually a multivalued function in the sense that b is a complex number .
Consider the simpler example
\(\displaystyle \Large i^i = e^{i\log(i)}=e^{i(\ln(1)+(\frac{\pi}{2}+2k\pi) i )}=e^{-\frac{\pi}{2}-2k\pi }\)
Ofcourse we could do
\(\displaystyle \Large i^i= (e^{i\frac{\pi}{2}})^i=e^{-\frac{\pi}{2}}\)
But this will be not complete since it only gives the solution when \(\displaystyle k=0\).
So then the complete solution is:
\(\displaystyle z=\frac{e^{\frac{\pi}{4}(8k+1)}}{\sqrt{2}}\left( \cos\left(\frac{\pi}{4}(8k+1)+\frac{1}{2}\ln(2) \right)+i\sin\left(\frac{\pi}{4}(8k+1)+\frac{1}{2}\ln(2) \right) \right)\) ?
W|A told me only when $k=0$ is this a solution. (Giggle)
My apologies for any confusion I caused to the OP.(Doh)
Also i would like to add something
e2k\(\displaystyle {\pi}\)i=cos(2k\(\displaystyle {\pi}\))+isin(2k\(\displaystyle {\pi}\))= 1
\(\displaystyle {\forall} k {\in} {\mathbb{z}}\)
but
e2k\(\displaystyle {\pi}\)\(\displaystyle {\neq}\)1
FAQ: Solving Complex Expressions for Scientists
What is a complex expression?
A complex expression is a mathematical expression that involves multiple operations and variables. It can also include functions and nested expressions.
Why is it important to evaluate complex expressions?
Evaluating complex expressions allows us to simplify and solve mathematical problems with multiple operations and variables. It also helps us better understand the relationships between different parts of an expression.
How do you evaluate a complex expression?
To evaluate a complex expression, you must follow the order of operations, which is parentheses, exponents, multiplication and division (from left to right), and addition and subtraction (from left to right). You also need to substitute any given values for the variables in the expression.
What are some common mistakes when evaluating complex expressions?
Some common mistakes include not following the order of operations, forgetting to substitute values for variables, and making calculation errors. It is also important to pay attention to negative signs and parentheses.
Why is it helpful to simplify complex expressions?
Simplifying complex expressions can make them easier to understand and work with. It can also help us identify patterns and relationships between different parts of the expression, which can be useful in solving more complex problems.
