Solving Complex Polynomial Equations
In summary, this stunned me. I stare at these problem for a while and tried my best to factor it but no success. Please help me solve this.
paulmdrdo1
385
this stunned me. i stare at these problem for a while and tried my best to factor it but no success. please help me solve this.
1. $x^3+x^2y^2+x^2+xy+y^3+4y-3xy^2-12x$
2. $3x^2+7xy-3xz-2yz+4y^2-6z^2$
Mathematics news on Phys.org
Not complete solution but outline of solution
put in descending power of x
x^3 + x^2(y^2+1) + x(y-3y^2 – 12) + y(y^2+4)
as y^2 + 4 cannot be factored further it shall be product of a linear and quadratic in x
so (x+/-(y^2 + 4))(x^2 +/- y+ cx) - not pssible as it gives x^2y^2or (x+/-y))(x^2 + cx +/- (y^2+4)
where c does not conatain x but may contain y
now you can take (x+y)(x^2 + cx + y^2 + 4)
and (x-y)(x^2 + cx - y^2 - 4) and one of them is the result
I would look at a factorization of the form:
\(\displaystyle \left(x^2+y+ax \right)\left(x+y^2+b \right)\)
Expand, and then compare coefficients.
Here I would try the form:
\(\displaystyle (ax+by+cz)(dx+ey+fz)\)
$\displaystyle \left(x^2+y+ax \right)\left(x+y^2+b \right)$ -->expanding this i would get,
$x^3+x^2y^2+bx^2+xy+y^3+by+ax^2+axy^2+abx$
then what's next?
then what's next?
Equate that to the original polynomial and equate corresponding coefficients.
what do you mean to equate? set them equal to each other?
Yes, and then set the corresponding coefficients equal to one another, and solve the resulting simultaneous system.
you mean like this,
$x^3+x^2y^2+x^2+xy+y^3+4y-3xy^2-12x=x^3+x^2y^2+bx^2+xy+y^3+by+ax^2+axy^2+abx$
what's next after this?
paulmdrdo said:
you mean like this,
I would subtract terms common to both sides:
\(\displaystyle x^2+4y-3xy^2-12x=(a+b)x^2+by+axy^2+abx\)
Now, can you find $a$ and $b$?
$a=-3, b=4$
what's next?
how did you know that $x^3+x^2y^2+x^2+xy+y^3+4y-3xy^2-12x$ would factor to this form $\displaystyle \left(x^2+y+ax \right)\left(x+y^2+b \right)$ are you using trial and error? tell me what the trick is please.
Plug those values into:
and you will have successfully factored the polynomial.
yes MARKFL i can do that. but some steps aren't still clear to me.
like how did you decide that $x^3+x^2y^2+x^2+xy+y^3+4y-3xy^2-12x$ would have this factored form $\displaystyle \left(x^2+y+ax \right)\left(x+y^2+b \right)$. i know that if we expand this it would be like the original polynomial, but the point that i need an answer to is how did you, in the first place decide it's going to be in that form? what rule or trick are you using? in what way do you look at the polynomial to come up that some specific technique should be used.
i want to know the trick on how to determine what would the factored form of my original polynomial be. especially when it comes to this messy type of polynomial. do i need to use trial and error of jumbling/grouping the terms then factor it?
please bear with me. i find your steps interesting that's why i want to fully comprehend and adopt it. thanks!:)
I noticed that:
\(\displaystyle \left(x^2+y \right)\left(x+y^2 \right)=x^3+x^2y^2+xy+y^3\)
This leaves us with:
\(\displaystyle x^2+4y-3xy^2-12x\)
So the first two terms could be obtained by adding a constant in the second factor, and the last two terms could be obtained by putting a constant times $x$ in the first factor, given the constant in the second factor. some people prefer to try grouping, but I find this method easier for me.
what if the polynomial is given in this way? what would you do first?
$xy+x^2+y^3+4y-3xy^2-12x+x^3+x^2y^2$
The process would be the same...sometimes you have to tinker a bit to see how you want to group the terms. There are other ways to go about it; we each develop our own style that works best for us.
FAQ: Solving Complex Polynomial Equations
What are complex polynomial equations?
Complex polynomial equations are equations that contain variables raised to positive integer powers, as well as complex coefficients and constants. They can be written in the form of ax^n + bx^(n-1) + ... + cx + d = 0, where a, b, c, and d are complex numbers and n is a positive integer.
How do you solve complex polynomial equations?
To solve complex polynomial equations, you can use various methods such as factoring, completing the square, or using the quadratic formula. You may also use numerical methods such as Newton's method or the bisection method to approximate the roots of the equation.
What is the fundamental theorem of algebra in relation to solving complex polynomial equations?
The fundamental theorem of algebra states that every polynomial equation of degree n has n complex roots, where some roots may be repeated. This means that for a polynomial equation of degree n, there will be n solutions or roots, which may be complex numbers.
Can complex polynomial equations have real solutions?
Yes, complex polynomial equations can have real solutions. This occurs when the coefficients and constants in the equation are all real numbers, and the roots of the equation happen to be real numbers as well.
Are there any specific techniques or strategies for solving complex polynomial equations?
There are various techniques and strategies for solving complex polynomial equations, such as using the rational root theorem, grouping terms, or using the substitution method. It is important to practice and understand these techniques to effectively solve complex polynomial equations.
